Question about Sony CCD-TRV228E Camcorder
Recoding and viewing
When i play back recording i have done i just get a blue screen however if i rewind,Fast forward or pause i get the picture? any idea? i know its recording fine as well as i have played tape that i recoded. they just won't play back on viwing screen, unless i do the above? anyone help!
  • 24 Answers
Sir , the lcd flap of the camera has been spoilr\ed due to this the image is not coming on lcd , only u have to take the image through view fider , lcd fpc has to be changed / repaire u can contact me also omaxphoto@yahoo.co.in
Posted on Mar 28, 2007
How to rewind/fast forward trough currently listening segment?
Touch the screen, and 'reverse', 'pause', and 'forward' icons will momentarily appear on the lower portion of the screen. Before the icons vanish, touch either the forward or reverse icon and continue to hold your finger on the icon without lifting it off of the screen. Fast forward or rewind will then begin, at a rate of 5 seconds per second held. I am told after holding for 15 seconds or longer the speed of the fast forward may increase (true for other Coby models I have owned), but so far I have had no luck getting this to occur with my MP828.
Jun 23, 2012 | Coby MP828 layer
I am trying to find out what the blue symbols on the function keys of my sk 9020 keyboard stand for
The blue keys serve as a secondary function for your volume control, monitor controls and pause play fast forward rewind (in media mode). In order to use the blue keys that are numbered from F1 to F12, you must depress and hold the Fn key that is located at the bottom left side of the keyboard. Here is a way to test it: Open up any file that plays sound for longer than 1 minute (60 seconds). While this file is playing, hold down the Fn key and simultaneously press F8 and listen to the volume get louder or Fn and F7 together and listen to the sound get lower. The picture of the crescent moon F1 will adjust the brightness of your screen. F2 will magnify your screen. F3 will take you to your email. F4 will take you to your internet home page. F6 will mute the volume. F7 will lower the volume. F8 will raise the volume. F9 will rewind your video playing. F10 will stop the video. F11 will pause or play the video. F12 will fast forward the video.
Mar 06, 2012 | Gateway (7001434) Keyboard
I do not know how to use it, i have the manual, but i do not find it
The recorder takes 2 AAA batteries. Press Menu/Folder (on the right above the jogdial (Stop, Rewind, Fast Forward, Play)) to select the folder to add a new recorded item. (The folders are A,B,C, or S. Folder S will come up with a date and you can select another date for the recording.) Folders A, B and C can hold 100 files each; Folder S has 365 dates which can hold 15 items each.
Press and hold the Menu/Folder button for a second or longer. The Screen should show the Mode menu. Press Play and then the Fast Forward and Rewind buttons to set the recording quality. HQ is the high quality recording and will fill up the available storage on the organizer more rapidly. LP will record for the longest period.
Set the Microphone sensitivity by pressing and holding Menu/Folder. Then press the Fast Forward or Rewind button until Mic appears on the display. Then press Play and use the Fast Forward or Rewind buttons to select Low or High sensitivity. (An external mic often gives better results.)
Once you have set the folder for the next recording and the recording quality and microphone sensitivity, press Rec (center above the jogdial) to start recording. Press Stop to end the recording or Rec to pause it. (It will stop if the Pause is longer than 10 minutes.) Press Display to see how much longer you can record before using up the available storage space.
To play back a record, locate the item in the folder then press Play.
The manual for the Olympus VN-1800 is available from the Olympus support site: http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=841 . The direct link to the English version of the manual is http://www.olympusamerica.com/files/oima_cckb/VN-900_VN-1800_VN-3600_Instructions_EN.pdf .
I hope this helps.
Aug 30, 2011 | Olympus VN-1800 Digital Voice Organizer
When we Fast Forward or Rewind the screen turns blue
try to not fast foward and see what happens
Apr 15, 2008 | Televison & Video
Cannot play tape.
Sometimes that happens to me too. What I do is just push play, then fast forward, and normally if you watch it, the picture starts to come back. Just keep fast forwarding until you can see all of the picture, and you should be fine.
Mar 24, 2008 | Panasonic PV-GS19 Mini DV Digital...
VHS tape won't play or rewind
I work at the History Channel and have  a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
Feb 28, 2008 | Televison & Video
No Picture on playback
alignment is offset, should be easy fix with you local electronics repair place....if you need a cost estimate let me know model
Jan 20, 2008 | Video Cameras
No Picture, sound or anything during playback...
cleaning cassette may help - if the picture comes back but soon goes blue screen ? your heads need thorough cleaning or replacement ;
Jul 30, 2007 | Canon ZR100 Mini DV Digital Camcorder
Sony CCD-TRV228E Camcorder Logo
129 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Jose Ma DM.
Jose Ma DM.
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
