When driving around 15 to 40 mph i can feel a sharp shake coming from the drivers side wheel area so i checked it out and there is a loose rod or main drive that runs back towards the engine that i wiggle with no problem, i do my own work on my vehicles and this is a new car to me and not sure what the parts are or what im getting into. didnt know if it would be as easy as removing the rotor and brake system to get back to work on a cv joint or U joint. any help would be great!!
Sounds like the tie rod is bad. Easyest way to tell is to jack up car on that side until tire is off the ground. tie rod end will pivot from side to side,this is normal but if it moves up and down this would indicate that it is bad. If it is please replace as soon as you can for this is very dangerous. If it would come apart you would lose control of car..Now replacing it is not that hard of a job. First remove pin that runs through bolt on bottom of tie rod. Then remove nut. Now the tie rod end has splines on it that holds it into place and just trying to pull it out doesnt work. Place something like large screwdriver or pry bar between tie rod end and where in goes into assemble. Now while prying down use a hammer and hit the side of assemble where tie rod bolt goes through. may have to hit it quite hard and remember keep prying down while you do this. It will simply pop up out of assembly. Please do not hit bottom of bolt to try to pop it out for this in alot of cases will smash end of bolt and cause it to flare out making it hard to pull out once loose. Now that it is out you will need to take it loose from the arm. Use a pair of vise grips of pipe wrench to hold arm and loosen set nut behind tie rod end and screw tie rod out. replace with new one ,tighten nut,put tie rod end into hole but on nut and tighten then be sure to put pin through bolt,may have to turn nut to line it pin up with hole. When pin is through bend it out around nut. The pin is what keeps the nut from coming loose...Hey your done...Anytime you replace a tie rod end you will need to have your car realined.......please rate this post and good luck and hope the info is helpful
SOURCE: 71 Super Beetle has the shakes
Have you rotated the tyres?have the shock aborbers been checked.Warped drums would show up in the wear pattern left inside the drum and on the shoes.You could take a wheel off spin the brake drum and with a felt pen slowly let the pens tip touch the edge of brake drum.hold pen in the same place without moving it and it will show up high and low sections if any.Are all the bushes(suspension in a servicable condition?Sounds like anti sway or stabiliser bushes may need looking at as your problem is when you accelerate,not so much pressure on the bushes,sometimes vibates and more vibration when you brake when its under a higher amount of stress.Could be a bent rim Could be need wheels balanced.Have you correctly adjusted your brake shoes?Therse a slot in the back of the wheel hub assembly
SOURCE: When appling brakes on a 2000 Jeep Grand Cherokee, steeing wheel
Jeep has a tech service bulletin about the front calipers needing to be replaced in order to stop the vehicle from warping the front rotors.
SOURCE: violent shake
My Death Wobble started immediately after I installed a set of Coil Spring Spacers (to lift 1.75 inches) on my 2005 Jeep Wrangler X. Turned out, the DW was because while changing the height, I also lowered the CASTER angle in the front end. So, to fix it, I could have purchased a set of eccentric bolts for $50+. Instead I went out and purchased a piece of 1.5 inch flat bar for $10 from OSH. I cut out 4 1.5 inch squares. Then i drilled 7/16 inch holes centerline, but close to one side (in exactly the same place) on all for squares. I then removed the lower control arm bolts, nuts and washers. I installed these square offset washers I made so the front axle would be pushed forward (to increase the Caster angle). The toe setting changed a bit, so I reset them to about 1/8 inch toe in. After driving my Jeep, I noticed there is no more DW. The steering wheel was off center, but after 3 attempts, I have that perfectly centered. I have every intension of having the alignment checked, but not till after I find the new tires I want. If anyone is interested, I can draw out and photograph the cure and send it to you. My e-mail is bb62471(at)yahoo(dot)com.
SOURCE: Front end knocking from 97 sebring
Move it to 3rd instead of drive and see if you still have the noise. May be transmission related since you have replaced everything else.
SOURCE: 92 Lebaron front end shakes when pressing on the accelerator and.
Your CV joints are totally shot. Repair ASAP.
