Question about Dryers
GE Gas dryer getting too hot
Our gas dryer is hooked up to a BBQ propane tank with an appliance regulator. When we turn the dryer on the plate in the back of dryer gets so hot it burns your hand and scorches the clothes. We can hear the gas the gas click on and off. What could the problem be? And how can we fix it?
  • Dryers Master
  • 17,827 Answers
You did not post the make and model but you cannot use a natural gas appliance on a propane system. The orifice jets are not the same size and you could be letting too much propane into the burners.
Posted on Feb 16, 2018
2 Suggested Answers
  • 111 Answers
SOURCE: GE Gas dryer getting too hot
The gas burner valve is not the correct one for LP gas. You have to convert the valve as well as the orifices. The clicking is because it is over heating and cycling on and off o the high limit (safety thermostat)
Posted on Dec 19, 2008
I hooked a thermador cooktop to a BBQ propane tank. The flames are large for a second and make a puff sound and the shrink to nothing. All 5 burners do the same.
It does sound like a faulty regulator, propane operates at 2.75kpa and if the existing regulator is for natural gas it is only 1.1kpa.
If you are operating off a bulk tank the regulator on the tank may be high pressure then the secondary regulator on the appliance may be to bring it down further. See if you can get a manometer and check it all out before doing any regulator removing.
Apr 05, 2014 | Thermador Cooktops
After running for a few minutes, my bottle top heaters start flaring and burning irregularly. The same thing happen when I hooked it up to another heater. Also when I turn the gas off it takes a lot of...
Are the propane tanks fitted with a pressure regulator?
The propane gas regulator is one of the most important parts of a propane gas system (or a compressed natural gas system as well).
The purpose of the regulator is to control the flow of gas and lower the pressure from the tank to the appliance(s) in the gas system.
The regulator not only acts as a control regarding the flow and distribution of propane (or CNS) but also as a safety barrier between the high pressure of the tank and the end use appliance(s).
Without it, you can cause serious damage to the appliance's gas valve and create a disaster- fire or explosion.
Nov 30, 2013 | Mr. Heater Model MH12TS - Single Tank-top...
Hooked up bbq propane tank and smell gas?
I would turn the gas on and spray soapy water at the fittings if bubbles appear that is where your leak is. if it is leaking in the lines. turn gas off un screw fittings and wrap them with teflon or what some call plumbers tape they are both the same thing and very inexpensive. if it is at the valve on the tank I would get a different tank
Jul 26, 2012 | Grilling
Liquid Propane vs. Propane (like used for BBQ)
They are the same thing.
The propane you buy for your BBQ is liquid in the bottom of the tank. At the top, it comes out as a gas, which you run through a regulator and then into your grill. If you by some chance turn the tank sideways, the valve inside will shut and keep the liquid propane from coming out. If it did you could have a serious fire.
However, there is a difference between what most folks call "Natural Gas" and propane. If you have gas piped into your home, it's natural gas and not propane.
Natural gas dryers won't run right on propane (LP Gas) and vice versa. There is usually a conversion kit you can buy to switch them over.
Oct 14, 2009 | Dryers
Dec 18, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
BBQ Galore Capt'n Cook 4 burner gas grill won't get hot.
Most modern gas regulators have a safety feature to prevent gas left on. If you shut off the tank first and then turn off the burners, it will trigger and keep the gas flow at a very reduce flow to prevent you from turning on the tank again with the burners left on and not realizing it. Turn everything off and then turn on tank first, followed by the burners and this will solve most problems of a low flame or a bbq that won't get hot.
Dec 05, 2008 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
No gas getting to bbq
I switched to the new style 20# tank with the new turn-on knob.  I couldn't get enough gas pressure to the BBQ burners for all three burners to light or to keep a strong flame on even one burner.  The new style tanks have a safety valve on the inside of the tank that shuts the gas off if you turn the knob on too fast because the safety valve thinks there is leak.  Shut everything off and then try turning the knob on real slow, especially at first, before turning it all the way on.  If that doesn't work (it didn't for me), then replace the large plastic connection valve knob (female end) that attaches the regulator to the tank.  Mine was for the old style tank and was black (low pressure).  I went to a propane company and had them replace it with a green knob (higher pressure).  Took it home and WALA!  Everything works fine now.  But it was very frustrating trying to figure why I couldn't get any gas to the burners after buying a brand new tank.  I hope this helps solve your problems.
Sep 15, 2008 | BBQ Guys BBQ400C/G42 Grill
Gas BBQ - Won't light
hi Be sure the thermostat or heat dial is set properly. If the appliance has a pilot light, be sure it's working. make sure that you connected the pipeline correctly open the faucet of the tank try to fire it up ? working ? good... NO???? close everything(faucets,plugs...) your new tank that you connected is empty.... it happens.... have a good 1
Apr 06, 2006 | Barbeques Galore Turbo Classic 3-Burner...
Dryers Logo
83 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
