Question about Candy CN126 Front Load Washer
How do i fit a new door seal???
I need to now how to fit a new door seal please.
    President:
  • 1,462 Answers
Disconnect from mains not that easy first time. undo clip holding seal to cabinet. peel off seal and push inside drum remove top.i remember seal is held to tub by a giant jubilee clip but varies with model. undo clip and remove seal complete. fitting is more difficult lubricate slot that fits flange of tub with washing-up fluid - essential start at top fit an inch or so of slot onto tub flange. work in both directions forcing slot onto flange with thumbs as you go round. refit giant jubilee clip. refit seal to cabinet and refit cabinet clamp. test for leaks on rinse as water level is higher. this job is a knack so persevere
Posted on Mar 28, 2007
Whirlpool Front Loading Duet Washing Machine Plastic at drum front shredding
i think your talking about the rubber door seal????
you can change this yourself,,,under the seal on the case is a wire spring unhook it and the door seal will fold inside the washer,,,on the inner drum you will find the other wire spring undo this as well and pull the old door seal out through the hole in the door,,,the new seal is fitted to the iner drun first so you need to turn the new seal inside out to fit it,,,push the seal into the washer and fit the inner wire first then unfold the seal and fit it over the outer door so you can fit the wire spring,,,
easy after you have fitted a fuw 100?
Aug 21, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
ICE DOOR SEAL IS LOOSE AND NOT SEALING CAUSING FROST BUILDUP
This is the step you will use to repair your ice door seal that is loose.
There are screws under the fold of the freezer door gasket that holds the brace for the gasket in place. Lift the rubber gasket to expose the screw head, one section at a time. Just loosen the screw, and do not take it completely out.
As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
Check the seal by closing the door. You should have a nice, tight seal.
Good luck.
  • Step 4 Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7rn3O8
  • Step 3 Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7gYaZ2
  • Step 2 As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
  • Step 5 fix-freezer-door-seal-1.5-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/k5/eg/fix-freezer-door-seal-1.5-800X800.jpg'); }); Keep the gasket clean to last longer. Check the seal by closing the door. You should have a nice, tight seal.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7JfY8i
    Jun 22, 2010 | Refrigerators
    How can I fit a bottom door seal on a Brandt dishwasher please. My dishwasher is leaking but the door seal and gaskets are intact although the sealant which held the gaskets in place has disintegrated....
    If the bottom seal is definitely worn then it is quite a simple job.The seal is just pushed into a groove at the bottom of the door,as you pull the old one out be very careful as the edge of the groove is like a knife edge,the new seal will push in gently starting from one end and keep pushing into the groove try not to stretch the seal in length.Another thing to check first is check the bottom spray arm for splits on the edges as this could be directing the water onto the door,if there are splits then the arm will need replacing.
    Hope this helps.
    May 27, 2010 | Dishwashers
    Replaced door seal now door is difficult to close.
    Sometimes, it is hard to close door after fitting a new seal.
    Make sure you have got it fitted correctly round the flange on the front of the cabinet, and that the retaining clamp is securely fastened.
    Try smearing the door glass with washing up liquid, this can help to close the door more easily
    Please rate my solution.
    Thankyou.
    Feb 13, 2010 | Ariston Technologies Washing Machines
    Fit a new door on a washing machine
    You need to remove the wire clamp that holds the door seal on to the front of the cabinet, then pull seal off.
    This will give you access to the door hinge assy, then you can replace the door complete.
    Thankyou.
    Jan 27, 2010 | Hotpoint Washing Machines
    Rubber seal damaged. needs to be replaced kenmore model 970-c44052-00 How do I remove sides to get at it?
    there is no need to remove the side to replace the door seal, just behind the door seal there is a spring clip undo this and fold the seal into the drum were you should see another spring clip undo that as well and the door seal comes out from the front through the hole in the door, to refit a new fold the seal till its inside out and fitted on the inner drum first fit the inner clip then pull it through the door hole and fit the outer spring clip out side the door
    Dec 06, 2009 | Kenmore 43142 Front Load Washer
    Fit a new door hinge
    Remove the wire clamp securing rubber seal to front of washer, pull seal of front of washer, this will give you clear access to tjhe door hinge, ondo the 2 screws securing the door hinge, remove door ,and seperate the 2 door halves by removing the screws securing it together
    Replace with new hinge, fit back in reverse order.
    Thanks.
    Nov 12, 2009 | Creda W120VW Front Load Washer
    Rubber door seal replacement on my Front Load Washer
    OPEN THE DOOR
    THERE IS A WIRE AND SPRING CLAMP AROUND THE SEAL, PULL BACK THE SEAL WITH YOUR FINGERS AND YOU WILL SEE IT
    TAKE OFF THE CLAMP
    FOLD THE SEAL BACK INTO THE DRUM
    YOU WILL SEE ( OR FEEL ) A CLAMP AROUND THE SEAL ON THE DRUM
    SLACKEN OFF THE SCREW HOLDING IT UNTIL YOU CAN PULL OFF THE SEAL.
    FIT A NEW ONE IN REVERSE ORDER.
    HINT- WIPING WITH LIQUID DETERGENT WILL MAKE IT EASIER TO FIT THE NEW SEAL.
    HINT2 - YOU MAY NEED 4 PAIR OF HANDS TO FIT THE SPRING CLAMP
    Jul 06, 2009 | Whirlpool Washing Machines
    FITTING NEW DOOR SEAL ON WHIRLPOOL AWM5125
    this is a complex repair and the machine complet frount has to be removed
    May 10, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
    Usually it will be just be reversing the procedure of removing the old seal. At any rate, the door will need to be disassembled.
    Mar 29, 2008 | Whirlpool AWM5125/1 Front Load Washer
    Candy CN126 Front Load Washer Logo
    217 people viewed this question
    Top Candy Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Kolbrun...
    Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
