Schematics or diagram for a 480W PSU
Need the wiring harness details of a Golden Deluxe 480W PSU as that what came with the unit to set up the step motors for a CNC machine.
  • Anonymous Feb 01, 2009
    vlbnm,
I need a schemetic diagrm D15-1013/diablo ATX 250w Power supply
Thanks Louie.
Posted on Dec 30, 2008
  • joecoolvette
    joecoolvette Dec 04, 2010
    How is this a solution, much less a Best Solution? Clean-up on Aisle 3
Need the pin to pin wiring schematics for this model of motorcycle?
    More images for 1990 Kawasaki 650R wiring schematic
    Kawasaki Motorcycle Wiring Diagrams - ClassicCycles.org
    www.classiccycles.org/1852/597943.html
    Kawasaki Motorcycle Electrical Wiring Diagram Schematics. ... Kawasaki GPZ600 GPZ 600 Electrical Wiring Harness Diagram Schematic 1988 to 1990 HERE ...Kawasaki KZ650 Z650 KZ Z 650 B Electrical Wiring Harness Diagram Schematic ...
    Owner Center - Kawasaki
Jan 21, 2016 | Motorcycles
Wiring for radio
generic wiring schematics seldom match the OEM wiring as to get the diagram the book publishers have to virtually strip down a vehicle as the diagrams are copy write protected. IN many cases the manufacturers of the vehicles change wiring harness suppliers and the OEM schematics will vary to your vehicle. When in doubt take it to an installer and have them fit it as diy people generally install incorrectly and produce faults in the CPU program
Mar 09, 2014 | 1998 Saturn SL
Replace fuel gauge
Hi Anonymous, you could have a faulty sending unit or guage, there could be a problem with your wiring. On models with the fuel gauge posing as a left hand fuel cap the gauge is a press fit do not try to unscrew it, simply ample force lift up in a rocking motion to remove gauge. Disconnect wires to the gauge and with a set of positive and negative jumpers from the battery connect the positive jumper and flash the negative, gauge should peg full, if not replace gauge. With a test light check for power to the sending unit, then remove the sending unit and manually operate the float arm slowly with the correct wiring hooked up to the fuel gauge and sending unit and the ignition on, the gauge should respond accordingly if not replace the float arm assembly. For a free wiring diagram please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 29, 2013 | 2005 Harley Davidson FLSTN- FLSTNI Softail...
I need the wiring schematics for 2006 equinox
try this site autozone. they ahve a lot of wiring diagrams. jsut go down the list until you find your diagram.
Repair Guides Wiring Systems 2006 Power Distribution Schematics AutoZone...
Feb 03, 2018 | 2006 Chevrolet Equinox
Need wiring harness color coded diagram for pioneer dehp3900mp
Hi, the wiring diagram is at the back of the manual. This unit has the standard wire colors for all aftermarket head units. Please get back to me with the car model and year if you need to know the car wire colors to match up.
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/130/130DEHP390.PDF
Nov 20, 2011 | Car Audio & Video
Need to know what the fuses under the hood twenty amp keeps blowing
The following wiring diagram, electrical system schematics, harness and cable routing apply for Jeep Grand Cherokee ZJ models. Here you will find detail description, illustration and explanation about the electrical system of the vehicle: ZJ-Secc-8W-Wiring-Diagrams
Hope helps (remember to rate and comment this answer).
Mar 28, 2011 | 1996 Jeep Grand Cherokee
I replaced the bed of my 94 Dodge Ram 1500 Pickup. When I put the new bed on I didn't realzie it was setting on the brake light wires, and now due to friction, the brake wiring has sereved in two! Anyone...
It's the rear wiring harness, and more specifically, the taillight harness.
Are there any wires left? Could you splice in new wires using solder on the connections, and heat shrink tubing? (Plus wiring wrap)
Wire the new one up, and where to get it?
Instead of buying a manual that may not be detailed enough, (Chiltons, and so on. You need a Shop Manual), I suggest you go down to your nearest Dodge dealer> Parts Department, and see if the Ol' Boys will copy off this part of the wiring diagram you need.
Shouldn't be but a few bucks.
They should have the wiring harness you need also.
OR,
you could buy the length of wires you need, match the color code of the insulation on the various wires, and the gauge of the wires, (Thickness of the wire), reuse the rubber connecting plugs, and other connectors, and wrap this wiring harness you made in electrical tape.
Naturally you won't reuse a melted rubber plug, (or Socket), and you'll have to buy any metal terminal ends you need.
That flexible plastic cover you see over the old wiring harness, is sold also. (Use electrical tape, and this flexible cover)
Wiring diagram? Here are the Wiring Schematics,
http://www.autozone.com/autozone/repairinfo/repairInfoLanding.jsp
You have to become a member. It's free. Go up to the top right, and click on -> Become A Member.
Now on the main page you started from, go to the left side, and click on -> Vehicle Repair Guides.
On the next page go up to the top left, and click on the blue -> Manage My Vehicles
Now go to the right, and click on -> Add A Vehicle, in the orange box.
This takes to several pages. First page you choose the Year. Second page you choose the
Make. Third page you choose the Model. (I chose RAM 1500 1/2 Ton 2WD) Fourth page you choose the Engine. (We're after the wiring schematics for the rear of the truck, so I just picked one)
NOW, (Finally, lol!), under the Select A Category heading, click on Vehicle Repair Guides.
Go to the right, and click on -> Chassis Electrical
Now under the Select A Chapter heading, go down to the bottom, and click on -> Wiring Diagrams.
Fig. 27 is the wiring diagram you want. I would also look at the first two diagrams to familiarize yourself with reading wiring schematics, unless you are already adept at this.
Would appreciate it if you would rate my solution.
Jul 17, 2009 | 1994 Dodge Ram
Computers & Internet Logo
1,095 people viewed this question
Alun Cox
David Payne
David Payne
