Question about Kitchen Appliances - Others
I need a new kneading blade unit.
The seal on the inside around the kneading blade is falling apart and the blade itself is very wabbly and is cutting a trail in the bottom of the bread pan. I have a model 1163 toastamser bread box . I ma have to have the whole bread pan unit with a new blade if it is still available.
  • Anonymous Feb 11, 2009
    need new seal under the kneading blade
  • 368 Answers
Hi pkandyco,
For Toastmaster parts, service or manuals, go to
http://prc.prodregister.com/prodprotect/applica/
And click on "toastmaster" (lower-left portion of the page), it redirects you to a secure webpage where you can register.
https://secure.prodregister.com/prodprotect/applica/tm.shtml
Part of the page reads:
"Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Jan 04, 2009
I have an old toastmaster bread machine model 1154, and I realized that the kneading blade does not rotate when the ingredients are in the bread pan. Either the kneading blade mounting shaft and the...
If the spindle is turning and the paddle is not then your paddle is worn out and probable slipping on the spindle. If the spindle isn't turning then your problem is underneath the pan or inside the drive and your paddle may be fine.
Dec 01, 2010 | Toastmaster Kitchen Appliances - Others
We need new kneading blade and drive mechanism at the base of the inner pot. Is this available we are in timarunew Zealand
Hello, There is a sealed bearing that is on the bottom of the pan and unfortunately it can not be replaced. You will need a new bread pan. Hank
May 20, 2010 | Sanyo SBM-20 Bread Maker
Panasonic SD-YD205 Bread Maker: Paddle gets stuck then continues.
Take the bread pan out of the machine and run a kneading cycle. If it is noisy with the pan out then you can take the belt off and try a kneading cycle again. If it's quiet, the yep it's the belt. If still noisy its a gear or the motor itself. If everything is quiet with the pan out then it's the pan itself. There is a sealed bearing in the pan that allows the paddle to spin. The seal on the bearing leaks oil and the bearing either freezes or does not let the paddle spin freely. There is no replacement for the sealed bearing ..and a new pan is needed. Good Luck Hank
Dec 10, 2009 | Panasonic SD-YD205 Bread Maker
The driver that operates the kneading blade ( paddle) is falling out of the baking pan from the bottom. It appears a washer has disintegrated. Pieces seemed to fall apart when cleaning. any suggestions? I...
There is a sealed bearing at the bottom of the pan. This allows the paddle to rotate. The bearing has failed and is falling apart. This usually happens with age or use. Time for a new bread pan. If you are lucky you can find one on ebay. Sorry for the bad news....Hank
Dec 09, 2009 | Oster 5838 ExpressBake Bread Maker
Kneading blade stuck
plz contact 022-23051554 /23095757
Feb 02, 2009 | KitchenAid KFP750 Food Processor
Loaf falls in the middle and outside is hard
Falling in middle is usually due to innacurate measuring of liquids. Try again using the instruction manual's recipe and very carefully measuring. Be sure to adjust the liquid if you use honey or other liquid not called for in the recipe.
orleydog
Feb 01, 2009 | Oster 5836 ExpressBake Bread Maker
Table saw blade wabbles alot when cutting?
This could be caused by several problems. First unplug the saw. Put a known straight edge against the blade (making sure not to contact the teeth) turn the blade slowly and watch for runout. Second make sure the spacers and blade flanges are on correctly. I would just about think it would be the blade. If you provide the model and brand I can do some more research. Good Luck
Jan 03, 2009 | Black & Decker DEWALT 12 In. 80 Tooth Thin...
Blade inserted in bread when done
Either spay a non stick spray on the blade/paddle before you began or simplly remove the the blade/paddle after the kneading cycle is completed
Nov 23, 2008 | Sunbeam 5891 Bread Maker
How do I reassemble On/Off switch?
The actual switch will not fall apart. There is a black part that is integral with the switch itself. This is about 1/4" to 3/8" wide, and can only be seen from inside the unit. Then there is a plastic piece that is part of the top shell. The hole in the plastic piece has to fit over the black part of the switch, so when the plastic piece is moved, the switch on the inside of the unit will move with it. SO, center both parts, and put them together. If you actually took the switch itself apart, you would have needed a soldering iron, and there would be no purpose for doing this.
Apr 03, 2008 | Fellowes P700-2 Shredder
Kitchen Appliances - Others Logo
56 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
