Question about Whirlpool Dryers
Dryer trips house circuit breakers when I turn it on.
  • 706 Answers
Hello rarakaki,
I assume that you are referring to an electric dryer and that when you run it, it trips the main house breaker. If that is correct, then you may be running too many appliances simultaneously and that will draw curent , beyond the maximum rated value of your house main breaker. It is also possible that your main breaker may be going bad and tripping below it rated current value. I suggest you do the following: Shut off other appliances or electrical equipment in other rooms and then try running your dryer. If it operates and does not trip the main breaker , then the comments stated above are the problem. You may need to have an electrician replace your main breaker and/or change your service to a higher value. Please get back to me if I am incorrect in understanding your problem. Regards,
Rick
Posted on Dec 18, 2008
Frigidaire Affinity panel turns on (lights up), even counting down, but the dryer won't tumble or heat. Help?!
Hi margaretc920 - Often when a dryer turns but will not heat, it is because either a fuse from the fuse box is blown or the switches on the breaker tripped, depending on your house. If your house uses fuses, there are two house fuses that supply voltage to the dryer circuit in your fuse box. If one of the two fuses is blown, the unit may turn but will not heat. Check and replace fuse in fuse box if necessary. However, if the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer and if one is tripped the unit as well will experience this issue. The heater of a dryer requires 220 to 240 volts to operate. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If the issue persists, it could also potentially mean a number of other things: defective cord, wiring, control board or door switch. I would personally contact a professional to accurately diagnose the dryer to determine the root cause to reduce the risk of unnecessary parts.
Jun 16, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
2year old ge dryer trips breaker when it's turned on, but sometimes will run a complete cycle before it shuts off.
HELLO THERE
Electric dryers require the use of a 220 volt line. The dryer heating elements run off of 220 volts. An excessive draw of electricity, or a short in the wiring can blow a fuse or trip a breaker. This happens to protect sensitive components from damage, and to help prevent fires. Every other dryer component operates off of 110 volts, the timer, motor, etc. Usually when a fuse blows or a circuit trips, it's because there's to much draw on the power line.
It is very possible for one part of your dryer to work fine, and yet another to have a problem, such as a short circuit. A short circuit may be caused by the heating element, internal wiring, or the main power cord.
To troubleshoot this problem, unplug the dryer and check to see if the circuit breaker or fuse remains on when the dryer is unplugged. If they stay on, it's more than likely the problem is somewhere in the dryer.
If your fuse blows, or the circuit breaker trips when the dryer is unplugged, it's likely the problem is with the circuit breaker, fuse box, or house wiring; contact a professional electrician.
OK I hope this is very helpful for you
Best regards Michael
Dec 01, 2009 | GE DBSR453EBWW Electric Dryer
My house circuit breaker kept tripping and
sounds like your heating element has opened up it was probably partially shorted to the case and this was causing your breaker arcing condition previously
Sep 24, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
When i try to turn my dryer on, it won't start
Assuming that you have an electric dryer, check the house electrical panel dryer-circuit breaker-pair. Push both off, then on. If they immediately trip off again, then you have a dead short circuit within the dryer. If they hold on, then try the dryer--if works,ok! If it doesn't work, recheck the breakers again--if tripped, a short circuit in the dryer heater circuit is probable. The dryer drum must be removed to gain access to the heater assembly.
Aug 23, 2009 | Dryers
Clothes Dryer tripping house circuit breaker
If it is breaking the main circuit of the house there is something wrong. It should throw the breaker to the dryer only. It sounds like you are having a problem with a short between the main breaker and sub panel in the house. Is there any way you can move the breaker in the panel to a different place on the same panel to see if it is that circuit only. If not check the outlet and the plug on the dryer and make sure the wiring is connected correctly.
Aug 03, 2009 | Dryers
I have a Whirlpool dryer Model # LGR7648K20 that just stopped heating. THE DRUM TURNS BUT IT WILL NOT HEAT.
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to Good luck
Regards:
VOTIT
Dont forget to rate:
Jul 01, 2009 | Whirlpool Dryers
Hoover HDC7FM condensor dryer starts then cuts out
Open the dryer door (right after the breaker trips) and check for a burned smell. If it smells in the dryer, you probably have a direct short in the dryer wiring. Check for a burn smell at the wall socket. There may be a short in the socket itself, but not likely unless a mouse is lying across the contacts in the wall.
If everything checks ok replace the circuit breaker if this is an older home. Circuit breakers weaken after years of use. A 30 amp circuit breaker will trip at a much lower amperage after a period of years especially if it has tripped often.
Mar 12, 2009 | Hoover HDC7FM Dryer
Dryer no heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Dec 24, 2008 | GE DSXH47EGWW Electric Dryer
Estate gas dryer
Heating element
Thermal fuse
Wiring
Jul 04, 2008 | Estate TGDS840JQ Gas Dryer
HE4 Kenmore Dryer tripping Circuit Breaker
If you put a light load in the dryer will not trip the circuit at all. That means heavy load made the motor work harder and over heat, it going to trip the circuit , pretty soon, the motor will be warn out.
Jul 01, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
228 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
