Question about RCA PHD50400 50 in. Plasma Television
RCA PHD50400 PLASMA
Shuts down, found short on vcc of driver board right top as looking at back nec on board lifted all vcc points no cap or ic shows short,triple layer board? looking for part numbers of boards and source to order thanks jim s
  • JIM SAMANSKI Mar 29, 2007
    actually this is one of the brds that drive the panel, has a large white connector that connects to video brd i quess and 3 or 4 connectors which connect to ribbon cables going to the panel itself
    thanks
  • 97 Answers
Most RCA units are board replacement only. The plasma diplay itself is not made by them. Reference replacement board.
Posted on Mar 30, 2007
    President:
  • 1,284 Answers
If that board has three connectors going to it (10 pin, 9 pin and 41 pin) then it is the PDP Module but no luck on finding a source for it. RCA is bad about parts supply on thier TV's the past several years.
Posted on Mar 29, 2007
TV was fine then suddenly no picture, still have sound but no picture.
if is a lcd tv the issue could be the inverter board or one of the lcd bulbs has stop or vcc which is 24 to 30volts that goes to the inverter is not found if its there check the fuse on the inverter if its a plasma the y-sustain board may be out there is a chip called the pmc (power modulator chip ) if is shorted the first sign would be a blown chip on the vcc side 180volt if thats the case the board is shorted needs to be replaced
Jan 26, 2011 | Samsung Televison & Video
NEC Multisync LCD1770V Model# L174F- Monitor powers on for a few seconds then goes black. You can still see a faint image in the background and the power light is still green. I checked for leaky caps on...
Check the iCs on the lcd control board which shut down the ccfl lamps? If hot put a paper sticker slightly smaller on the IC. This prevents condensation from osmosis into the IC.
Dec 19, 2010 | Televison & Video
Hi. When I switch on my NEC 42" Plasma (PX-42VM3A), the on light changes from red to green but then nothing happens. I have box-loads of spare parts but would appreciate any assistance in pointing me in...
CHECK FUSE AT Y-SUSTAINER PCB. IF BLOWN, DO NOT REPLACE IT! LOOK AT SCAN CONVERTORS BOARDS. THEY ARE CONNECTED BETWEEN Y-SUS AND PLUGS FROM DISPLAY(LEFT SIDE WITH FACE DOWN, BACK OPEN). SCENARIO: SCANS GOT BURNED(LOOK FOR A SIGNS AT THOSE LONG BOARDS: UPPER&LOWER).FIND ANY IMPERFECTIONS: REPLACE ALL 3 BOARDS: Y-SUS, UP/LOW SCANS.LAST THING: IF FUSE IS OK, CHECK POWER SUPPLY FOR BLOATED CAPACITORS(BIGGEST BOARD IN A MIDDLE OF THE SET) SAME SERVICE POSITION.
GOOD LUCK,
LET ME KNOW HOW TI GOES.
ALEX'S TV?PHILADELPHIA, PA.
Apr 06, 2010 | NEC PX-42VM3A 42 in. EDTV-Ready Plasma...
CAN NOT GET CIRCUITS,JP275852,JP273734 AND JP275857.
THE UNIT NEEDS 2 DRIVER BOARDS TYPE PKG50C2J1 AND " J2.LABEL # JP275852,JP273734,JP275887. MADE BY NEC. I CAN NOT FIND THE BOARDS. THOMSON/RCA TECH SUPPORT SAID I WOULD HAVE TO REPLACE THE PLASMA PANEL BECAUSE THEY DO NOT STOCK BOARDS.THE PRICE IS OUT RAGEOUS. ( $8,200.00 ) END.
Oct 01, 2008 | RCA PHD50400 50 in. Plasma Television
Red Blinking Light
These types of problems are allways hard to diagnose.. If you were to power on the set and preform tests, you would think that everything was fine until the moment it shuts off.
Look on the main power board and see if you cant find the thyristor (thermal switch), those are the things that when heated will cause the set to power off for safety reasons.. They are normally placed where ever a large heatsink is. That may give you a location as to the problem and you can put a meter around its 2 pins with the set off and unplugged a couple of min after failure, if its short (0 ohms) thats not the problem, if its open, it triggered the event.
Second, you can run the set for a while and check the voltages and Ve, Va, VCC, Vsetup etc and compair to the markings on the plasma PDP sticker. If you see one is falling down over time (volts will be lost as heat) then you can isolate that portion of the supply.
Third and allways the best way to go about these problems is buy a thermal gun and moniter various spots for heat.
Its just vary hard to say, resistance could be off somewhere, diodes could be overheating as well as fets and caps. Thats why a good thermal gun can point you to exactly where the problem is.
Hope this info helps, but I would suspect the problem is on the main power supply itself and not the y sus and z sus boards side boards.
Aug 26, 2008 | Toshiba 50HP95 50 in. Plasma Television
Just a half picture on the screen
1. Remove the rear cover 2. remove the perforated large shield on the main board housing (almost in center). 3. Unplug the right top fan and temp sensor plugs ( two small plugs at the top of the main board). 4. Remove screwsthat secure the main board housing, there is also four screws by the video inputs. Do not unplug the board, just gently pull it away 6 to 8 inches. 5. Remove the cover with the Top fan attached (more screws). 6. Now the scan board for the top half of the screen is exposed. The board has four large heat sinks with two large Electrolytic aluminum caps next to each heat sink. 7. The problem caps are at the very top right side of the scan board C192 Nichicon 220 uf next to the IC, the other cap is C120 100UF on the lower side of the IC next to a heat sink. I replaced them without taking the board out. C192 is the one that failed, the other one tested OK but I replaced both.
I got the caps from Mouser.com they are 69 cents each, the Mouser part number for the 220Uf is: 647-UUD1C221MCL1GS (Nichicon 220uFm 16V 6.3x7.7 mm surface mount); the 100uF is:647-UUD1E101MCL (Nichicon 100uF 25V 6.3x7.7mm), both are 105 degree C. I bought two extra spares in case I need them for the future.
Reassemble the unit in the reverse order and you are done. Note if you test it without closing everything, make sure you have the main board shield back on, otherwise the screen will bleed due to the noise from the board. good luck! mine has been working fine.. just like new..
May 16, 2008 | NEC PlasmaSync 61MP1 61 in. Television
LCT2662 - No power
I have not seen a supply problem that after replacing the caps found something loading down the 5v line. Guess it's time to get out the scope and trace. :)
Good Luck
Bill
Apr 03, 2008 | Akai LCT2662 Television
NEC 42mpi plasma tv not working
Check the +170 volt  test point on the power board (not the power filter board, the one that the plug comes into) but the one to the right of that board. It has a 5v test point (TP +5v) , a +170 and a +70. I've found that the +170 transformer goes bad, and won't allow you to adjust the voltage using the pot screw.
Dec 29, 2007 | NEC PlasmaSync 42MP1 42 in. Television
Horizontal and vertical lines
I am having the same problem with my TV. I believe that the Y-Buffer Driver IC's are bad. There are two small boards on the left hand side(looking at the TV from the back) with 6 small heat sinks on each of them. If you look closely at the boards, it ill say Y-BUFFER on them. There are ribbon cables that run from them to the Plasma screen.
In my TV, several sections of the screen do not have lines in them. These driver IC's are not hot, however the sections of the screen that have lines in, the drivers are hot to the touch. In order to verify that the chips are indeed bad, I am going to swap one that I think is bad with a good section and see if the problem moves. If this is the case, the boards can be swapped out, or chips replaced depending on what kind of parts I am able to find. The chip that they use is SN755867. I haven't been able to locate a source for the chips yet.
Dec 16, 2007 | Philips 42PF7320A 42 in. Plasma HDTV
Half Screen
take it apart and check the cables to see if they are seated properly, if you hit it and it comes back, then something is not connected good
May 25, 2007 | RCA PHD50400 50 in. Plasma Television
RCA PHD50400 50 in. Plasma Television Logo
235 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
