Question about Sony FD Trinitron WEGA KV-27FS120 27" TV
Channels 3 and 4 no longer support VCR playback.
A faint picture can be seen behid the snow on the screen. I have switched to composite video on this tv. It's a better format, yes, but I have problems seeing what I want to record. The TV is only 3 years old. Last night I reset the factory settings to no avail. I am running SAT TV on channel 75 and I have no problems viewing the tv when the VCR itself is not online (tv/vcr switch). I have tried the TV on 3 and 4 with the VCR on 75. I have also tried the tv on 3,4 and 75 for test purposes. It is obviously out of warranty and it did work when we switched over to the satellite. The tv had to be on 3 or 4, and the vcr on 75. The vcr does work on a different tv which needs to be on channel 3. (tv./vcr both on 3. I hope you have some insight to shed. Thanks. Mark
  • Mark James Apr 01, 2007
    Techman, for what it's worth, this afternoon I hooked up an old 12" Zenith tv. I was able to view the vcr picture on channel 3 of the tv. With the Sony on Channel 3, I have NO picture. I get the SAT picture on Aux 3 with the VCR.
    Out of curiosity, I had 2 guys tell me my VCR was defective, and thatthe TV was working properly addding it was a connection problem. I had only 1 guy tell me it was the tuner. I think I know who I am going to call for service. I am not sure if I want to tackle the repair problem myself. This is a great site to help troubleshoot a problem independent of the guy who would potentially soak you for a repair.
    Thanks.
    Photo Dog.
  • Mark James Apr 03, 2007
    Techman, okay, I am really confused here. I troubleshot this problem to nearly the Nth degree. I switched tv's, I switched VCR's, and I switched cables. One guy I spoke with said the TV needed to be on the "AIR" setting for vcr's w/SAT TV. So, I did that. And it worked...?!? TV on 3, VCR on 75. So I switched the setting back to CABLE, VCR on 75 TV on 3. And it worked...?!? The very same criteria and set up I had tried this last weekend. Only then it didn't work. I am hoping, if you have a moment, you can shed some light on this. Or maybe point me to a site that explains this a little more. Sunday the vcr would not play on the Sony. Last night it would. Good news, but I am so confused.
    Thanks
    Mark
    President:
  • 3,130 Answers
Your tuner is most likely the trouble with your TV set. These are soldered into place and can be replaced a san assembly. These tuners can be rebuilt at ptscorp.com. Good Luck
Posted on Mar 28, 2007
  • Larry  Dillon
    Larry Dillon Apr 02, 2007
    I am wondering how someone could tell you the VCR was bad if it worked on another TV set?? LOL Go for the tuner Guy! Good Luck
How can I set the channel BACK to CH 3 from CH 4
1) Set your TV to channel 3.
2) Insert a pre-recorded tape into this unit.
3) Press the OUTPUT button on the DVD/VCR so that the VCR OUTPUT light is lit.
• If noise appears on the TV screen, press the VCR/TV button on the remote control.
4) Press the PLAY button once.
5) After a few seconds, press the PLAY button on the DVD/VCR for 3 seconds.
• The RF output channel will change to channel 3 from channel 4 and you will see a playback picture.
• When a picture does not appear on the TV screen, repeat step [4].
6) Press the STOP button to stop playback.
Nov 17, 2007 | Emerson EWD2004
I have a Toshiba cx35e70 tv. The problem began as a turn on, live screen, no channels, no sound. I found that when I would tap on the tuner on the main board the problem would disappear. Every thing worked...
Is the VCR going through ch 3 or video inputs - if video inputs your TV tuner is likely bad if through ch 3 seeif te picture goes funny on ch 3 without using the VCR the tuner may be bad on higher band channels - smetimes you can remove the tuner and resolder the tuner itself. But if it always works with the VCR just use it that way and don't bother with the fix.
Sep 26, 2009 | Televison & Video
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
Blank Blue Screen
If you go to menu do you get that on the screen?
Nov 21, 2017 | Samsung CXN2085TP 20 in. TV/VCR/DVD Combo
Go video VR3845
Try unpluging the unit and the plug it back in
Apr 19, 2008 | GoVideo VR3845 DVD Recorder/VCR
No Picture
check out the tip in my profile or use a wet cleaning tape
Mar 31, 2008 | GE 13TVR62 Combo
3-4 switch
1. Set tv to channel 4
2. insert a pre-recorded tape into vcr.
3.press play once to start playback.
4. after a few seconds press play on the vcr for 3 sec you will see a playback picture.
when a picture doesn't appear on the tv screen repeat step 4.
5. press stop to stop playback.
Mar 16, 2008 | Sanyo VWM-950 VHS VCR
Can not tape from cable, blue screen
If you have a cable box connected now, leave the VCR on channel 3 all the time and use the channels from the cable box.
The way this should be connected is cable in to cable box and cable out to VCR, VCR output to TV IN.
Hope this works for you.
Feb 11, 2008 | RCA VR348 VCR
Sharp vc-a422
This is easy in a nutshell. from the cablebox into the VCR RF connection (ant in) then from the VCR RF into the TV RF in. The from the DVD composite video out and audio out into the VCR composite video in and audio in. This make the VCR the hub of your setup the VCR should be set to channel 3 and you can switch between the VCR and the DVD by using the VCR remote. Now for the cords: 1) Cable to VCR RF = Coaxial 2) Composite Video and audio out = RCA patch cable 3)Composite Video and audio in = RCA patch cable That is it. If your TV can support multiple inputs then use it as the hub. Cable Box to VCR RF (Coax cable) VCR to TV RF(coaxial cable) or VCR to TV Composite video, or TV Component Video (RCA Cable) DVD Player to Composite video, or TV Component Vido (RCA Cable), or Svideo (Svideo cable)
Sep 12, 2007 | Sharp VC-A420U VHS VCR
Sony FD Trinitron WEGA KV-27FS120 27" TV Logo
54 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
