Question about Shure ULX1 Body-Pack Transmitter Microphone
Shure Wireless Mike no Output
Shure ULX1 wireless body pack has good battery but Batt light(red) is on and no channel display or output but backlight is lit. Any suggestions.
  • AsburySteve May 18, 2009
    I have a unit with the same problem. What was the solution?
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
Check the battery with a volt meter. If the battery measures lower than 8 volts on a volt meter, replace the battery. I have seen entire cases of brand new batteries that are defective. Make certain to check it with a volt meter. If the battery tests fine, then send the bodypack to Shure for repairs. www.shure.com/service
Posted on Jul 15, 2010
Er r1 error message on shure wireless body pack
Does the display show something like "E1" or "F1"? See Shure's website at:
http://shure.custhelp.com/app/answers/detail/a_id/2818
Apr 03, 2014 | Shure ULX1 Body-Pack Transmitter...
Shure ULX1 transmitter issue. Tapping the pack, tap goes through the system.
It's probably best to call Shure at 800-516-2525. They can help you best troubleshoot and get it repaired if it is faulty.
Jan 31, 2013 | Shure ULX1 Body-Pack Transmitter...
Shure ulx1 signal dropout
There are many things that can cause a drop out on a wireless microphone. See the following troubleshooting guide:
http://shure.custhelp.com/app/answers/detail/a_id/3834
Apr 03, 2012 | Shure ULX1 Body-Pack Transmitter...
I have a Shure ULP4 with al ULX1 body pack & ULX2 Hand Held transmiter. The ULX1 body pack shows only numbers for the Group frequnecy, the hand held ULX2 has group "E1" and "F1"...
This is described in the Trouble Shooting section of the User Guide. If you don't have a User Guide, you can download one from the Shure website.
Jan 30, 2011 | Shure ULXP4 Receiver
Shure ulx1 pack red power light will not turn green. Pack display does not show any status messages.
Please make certain the battery is good. Put a voltmeter on the battery to make certain it is above 7.5 volts.
If the battery does measure above 7.5 volts, then then transmitter will need to be sent to Shure for repairs.
Dec 20, 2010 | Shure ULX Professional Series Wireless...
I have the same problem. The ULX1 bodypack transmitter displays a RED battery light even when I use different batteries. I have used a voltmeter to test the batteries and they are good. I took the unit a...
I suggest sending the unit to Shure for repairs. The battery indicator is controlled by the micro. Thus, it needs to looked at by a service center that has access to the micro code.
Dec 07, 2010 | Shure ULX1 Body-Pack Transmitter...
Remove the battery and leave it out for a couple minutes to see if that helps. Also, check the battery with a volt meter to make certain it is above 8.5 volts. I have seen entire cases of batteries that are defective. If the battery checks to be above 8.5 volts and you have removed the battery for over two minutes, then send the bodypack in to Shure Service (www.shure.com/service)
Jul 06, 2010 | Shure ULX1 Body-Pack Transmitter...
How to make Shure wireless mic work with Azden 305
Sorry, that is not possible. Different manufacturers use different companding, noise reduction, and squelch schemes. Thus, even if they are on the same frequency, you might not get any audio or the audio might sound quite funny.
May 06, 2010 | Shure ULX1 Body-Pack Transmitter...
I have a shure ULX-1m1 transmitter with full battery but will not work. screen comes up green nothing on the display and the battery light is red, what could this be? and how do I fix it
First, sometimes LCD screens have an intesity/angle control and at extreme range of these characters are sometimes not visible. Check you manual to see if your unit might have such a setting.
Also this unit has some control lockouts so make sure it is unlocked so the automatic frequency selection can be made.
Verify the status of the LED in your manual. MANY Shure mics display the LED red when battery is low.
DO NOT trust a battery as being full because it is new.
ALSO DO NOT USE rechargeable batteries in these as the rechargeable battery does NOT produce 9 volts... usually only 7.2 volts (in spite of the labeling) which is insufficient and will give a low battery indication.
Sep 29, 2009 | Shure ULX1 Body-Pack Transmitter...
256 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
