My sure in ear monitor system PSM 200 has extremely low volume (audio output) from the receiver. I can increase the volume at the transmitter point, but it peaks and causes major distortion. I've used the monitors as headphones plugged into other audio sources and the volume is not a problem.
gadget
  • 14 Answers
SOURCE: playing itunes through receiver
On the back of your tower you should have auxillary outputs that will go into your receiver. Get a connection going between the two ports and you should have perfect sound. The sound that comes out of your headphone output will not really have the amount of power that your receiver needs. Hope this helps.
Posted on Sep 15, 2006
HDTV GURU
  • 261 Answers
SOURCE: The Output Volume Is Extremely Low!
Sometimes the rear channels can be used as a 2nd zone. Does the unit have A&B speaker selection on front panel? Usually if it has a 2nd zone it will say in owerns manual or on back of unit or on front panel as well. That is when you have the option to adjust the volume in the menu on the 2nd zone. GURU JAY
Posted on Feb 07, 2008
SOURCE: No component video output
Hope this helps
The Yamaha HTR-6030 offers two types of video monitor output: Component and Composite. You may need to connect both types to your television as the HTR-6030 does not have composite to component video conversion. In other words, to view your VCR on your TV, you need to use the composite video monitor connection. However, for a DVD player or other source that has component video connections, use the component video monitor output to your TV. If your TV has both types, you simply switch between the two with your TV remote to access the proper video monitor output signal from the HTR-6030.
Posted on Feb 28, 2008
mlapres
  • 757 Answers
SOURCE: I'm trying to hook up my Acer Aspire x1700 to a
You can set the receiver to any source that uses a optical connection. Then make sure that whatever you select whether it be CD/DVD you also have the source connection set to optical too on the receiver setup menu.
That being said, after that is done you will need to set up the computer to output audio. That usually just involves changing the output mode on the computer and adjusting the levels...open the Acer audio managment application, choose the audio output mode to stereo or dolby digital and turn everything up on the computers level controls. Then, when you open whatever software you're going to use to play your discs you may also have to adjust the volume level there as well.
Posted on May 08, 2009
  • 140 Answers
SOURCE: Hi I have a shure psm 200 iem.Suddenly started
Youre best bet is to contact shure and send it to them. there number is for service 1800-516-2525
Posted on Jan 05, 2010
I have only used my Shure psm 200 one time and I had trouble with highs. When I would belt out a high note the sound would distort or go away completely. I hope you can help, I'm really hoping to love the...
Brief research didn't turn up "protection" circuitry that could possibly cause your audio "go away completely" but I will assume that the distortion issue is just because the system is set up incorrectly. In-ear systems can be tricky to adjust as too much volume can distort the tiny "ear-bud" type earphones, and damage your hearing. Check online for your model as I found a manual that specifically addresses safe volume levels at the beginning of the owners manual, followed by operational settings, etc.
Mar 27, 2015 | Shure Audio Players & Recorders
How to increase the volume using the on screen menu?
Be sure the audio output from the sound card in the computer is connected to the monitor, else you cannot control the audio volument with the monitor control.
Jun 24, 2014 | iiyama AS4316UTC 17" LCD Monitor
How do you increas monitor sound?
Check the settings for audio volume control on the monitor side. Also, check the individual settings for the audio for applications and system sounds on the OS side. Or call ViewSonic technical support for assistance.
Jun 15, 2014 | ViewSonic Computers & Internet
Signal drops completely in PSM 200
bring in your guitar and have the intonation checked on pickups
Feb 21, 2013 | Shure PSM 200 Wireless Inear Personal...
I have a Shure PSM 900 and for some reason I suffer from extreme dropouts. I have checked everything I could, batteries, limit switch settings (tried all of them), adjustments on the receiver/bodypack. ...
This system operates in the 600 MHz band. Things to consider: Never use rechargeable batteries in things designed for alkaline. Transmitter should be within 100 feet for reliable link. Interference from other sources will OVERIDE the low power signals for this unit. Such sources can for instance be the fourth harmonic of polce and taxicab radios... fifth harmonic of aircraft radios... other RF sources including computers. All of these devices are SECONDARY users that MUST tolerate interference from licensed primary users of the band. The devices are FM radio links and with FM a transmitter anywhere near the same frequency will "CAPTURE" the discriminator of the unit and you MAY not even hear the audio of the interfering transmitter/source because it may use a different modulation means, if it is even modulated. Just changing to a different channel is NOT likely to fix the problem long term either. Shure makes high quality devices and I doubt the device is defective... only interfered with or being used at too long a range. Use an unused wire in the snake if you use one to get the transmitter within 20 feet of you and it might fix the problem. This unit is NOT a diversity device as in ear monitors are really not diversity (with two antennas and receivers) like ones used to send the other direction often are.
Apr 30, 2011 | Shure PSM 900 Bodypack Receiver
I feel that the 'normal' background hiss is a problem that I would like to minimize with the sennheiser IEM 300. I'm currently using the IE 4 ear phones. Would a different/better earset with maybe a...
No, that will not help. The his is a function of the receiver NOT receiving a signal from the transmitter as they apparently do NOT have a "squelch" circuit to mute the receiver noise when no signal is being received. The noise level when no signal is received is pretty high and apparently the volume control is not enough to reduce the hiss.
To solve this, LEAVE the transmitter ON and make yourself a switch at the receiver. DO this using one of those little in line lamp switches that fit on zip cord. Make one on a short length of zip cor with mating connectors to fit the received jack and the headphone plug. Don't worry about unshielded wire as the impedance is very low. Then you use this switch to mute the headphones when you want to. There are other switch types you can use, I am just suggesting what might be readily available to you.
Sennheiser SHOULD have include a mute switch on their unit as turning the power off on the receiver would be a pain. They could have used a volume control with switch to kill the audio line out... simple solution... oversight on their part.
Mar 25, 2011 | Sennheiser ew 300 IEM G3 In-Ear Wireless...
Some Headphones have an inherent hiss noise when they are connected to my wireless sennheiser EK 300 IEM G3 receiver. It seems to be a problem particularly with high-end IEMs which are highly sensitive...
Hiss is a problem of statistical noise in electronic devices due to the laws of physics plus circuit design.
One thing to do is to improve the signal to noise ratio (SNR) by properly setting gains. It is POSSIBLE that the IEM's you are using are too low impedance for the receivers resulting in you having to use excessive gain at the receiver. Your receiver gain control should not have to be above 60% of the way up. If you are above that, the ear buds are probably lower impedance than the receiver is designed for... and remember the manufacturer will LIE on the capability of the thing they are trying to sell.
The receiver is speced at 32 ohm drive... IF your ear buds are less than that impedance, they are NOT suitable. Conversely if they are too high, thaat will ALSO cause you to turn up the receiver gain too much and result in poor SNR.
You want to make sure the transmitter is being driven at line level so receivers get adequate input audio so gain doesn't have to be run too high.
Jan 04, 2011 | Sennheiser ew 300 IEM G3 In-Ear Wireless...
How can i make a simple wireless speaker ?
There isn't anything too simple about wireless communications. First you need a transmitter. Your headphone output would be a likely source for your transmitter. Once you have that in place you will need a receiver of the same operating frequency as your transmitter. The receiver will demodulate the signal and you will be left with a low voltage audio signal which would then need to be amplified. Amplifier power gain would be dependent upon a few things. Size of speaker, output power desired etc etc. All in all it would be cheaper to buy one. Good Luck!
Feb 08, 2010 | Arcam AVR-200 Receiver
46 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
