Question about Whirlpool AWM8143 Front Load Washer
HAVE PROBLEM WITH WHIRLPOOL AWM 8000 WASHING MACHINE
HALF WAY THROUGH THE CYCLE - USUALLY AT THE END THE LETTERS F & DL COME UP ON SCREEN ,A CLICKING SOUND IS HEARD AT THE BACK OF THE MACHINE AND ALL LIGHTS FLASH .THE DOOR CANNOT BE UNLOCKED.WE HAVE BROUGHT EXPERT SAYS THERE IS A FAULT IN THE DOOR LOCK.WE HAVE CHANGED IT BUT THE PROBLEM CONTINUES.WHATS THE PROBLEM?
SOURCE: whirlpool awm 8000 washer leaking
the rubber door seal needs replacing.you can get them from appliance repair shops easily.
Posted on Jun 21, 2008
futureloginn
  • 734 Answers
SOURCE: Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Posted on Dec 10, 2008
    • 56 Answers
    SOURCE: Front loader AWM 6100 - door open light flashes and won't wash
    I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
    Posted on Feb 11, 2010
    • 1382 Answers
    SOURCE: Will start the wash cycle and DL come on and light
    "dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
    Check for the following when dl occurs:
    • Door Lock Mechanism broken.
    • Check Door Lock/Switch Assembly for foreign objects
    • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
    • Door Lock/Switch Assembly Failure
    Thank you !!
    Posted on Jul 28, 2010
    blueextc3221
    • 15935 Answers
    SOURCE: i have a awm 8000 whirlpooll washing machine f and
    FH error indicates that either you have no water coming into the washer, or very little water. Since you can see it filling, the error indicates low flow. A flow meter
    in the unit detects if 10.5 gallons fills the tub within 8 minutes; yours must not be. This will turn off the inlet valves and the error code will be displayed. Check the following:
    - Make sure you don't have a siphoning problem. This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
    •The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
    •The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
    •DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
    •DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
    •The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
    - Verify Drain Pump operation. Unplug the washer and take the lower panel under the door off by removing the three screws under the bottom edge. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Open the pump access and remove, once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
    - Verify Flow meter operation and that the Pressure Switch hoses are intact and connected properly. Remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached. There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required in determining if the components are good or bad.
    "F/H" indicates that either you have no water coming into the washer, or very little water.
    If you have NO water coming into the wash tub after 30 seconds the error code is displayed. Check the following:
    - Inlet water valve may be clogged. Clean inlet screens if necessary.
    - Make sure water taps are on.
    - Check inlet hoses for kinks or clogs.
    If you HAVE water filling the wash tub, and after 8 minutes, 10.5 gallons of water has been detected by the flowmeter, but there has not been a detected a Pressure Switch trip, the inlet valves are turned off and the error code is displayed. Check the following:
    - Make sure you don't have a siphoning problem. Click the following link for instructions: http://www.fixya.com/support/r587481-prevent_washer_siphoning
    - Verify Flowmeter operation.
    - Verify the Pressure Switch hoses are intact and connected properly.
    To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. If not, click on the following link to check the pump for obstructions:
    http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
    To access the Flowmeter and Pressure Switch - remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached.
    There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Posted on Oct 01, 2010
    I have a whirlpool awm 8121 6th sense front loader. when i select the cycle, usually rapid, and press the start button the machine commences to fill with water. when it comes time for the actual washing...
    If your machine is reasonably old, perhaps take a look at the bushes of the motor . Before that, take the manual and run the test cycles by following the instructions; it might provide you with answers
    Oct 14, 2017 | Whirlpool AWM8123 Front Load Washer
    Whirlpool AWM 5080 stops during cycles
    Sound like could be faulty pump however you need to make sure no
    Could be pump at fault 1st you need to make sure no coin stuck in there ...
    Mar 31, 2010 | Whirlpool AWM6100 Front Load Washer
    Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
    WHirlpool 1600 Washing Machine AWM 8163 model. The letter ''P'' appears on the display screen and the washing cycle will not complete. Tried the other cycle and unfortanetly the motor sounds but the...
    Removed the top cover of the machine and cleared out the hoses and the plastci chamber, which was full of limescale which had built up and also unscrewed the front outlet cover, again that had become clogged up with alsorts debris. Now it works a treat.
    Dec 12, 2009 | Whirlpool Washing Machines
    Whirlpool AWM 045-1000 washing machine has suddenly stopped working and warning light "WATER STOP" has come on. Any ideas for a fix?
    Sep 19, 2009 | Whirlpool Washing Machines
    Washing cycle starts and takes hours even for short cycle.
    Try checking for good water supply.
    Pull out detergent tray and check for good water supply during filling.
    if poor filling-
    Try checking the hoses.
    Turn taps off, disconnect from machine, place hose end in sink, turn tap on and check for good water flow.
    if the hose has a red indicator in the side of the hose (end which is fitted to the tap) - Red indicator is a failed hose.(for models with Water Stop hose type "B")
    Oct 05, 2008 | Whirlpool AWM6120 Front Load Washer
    Whirlpool Duet HT
    its a door lock error a door lock error occurs if the door cannot be locked it will try to lock 6 times before displaying the error
    Mar 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Washing machine problem
    bought a new appliance , seems to have resolved issue
    Mar 11, 2008 | Washing Machines
    Whirlpool AWM8143 Front Load Washer Logo
    142 people viewed this question
    Sal De
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
