Question about Dell 924 All-in-One InkJet Printer
Scanner problem We have attached this printer to our computer and the printer is recognized but the scanner isnt how do I fix it?
I have a Dell Photo A10 924 Printer. If you click on the Printer Icon and select Microsoft Sanner and Camera Wizard it should scan in OK>
Posted on Dec 22, 2008
How do I get the scanner to work on my computer
your printer probably has a software to install.
this software has the mode to scanner and to scan. the pc has a printer connection right? and.... how to scan should be on the software for the printer. it recognizes the printer and it's looking for a scanner, this is why is telling you scanner connection under the scanner connections but if the use is with the printer as a scanner, it must've a software. maybe the printer a scanner button so the pc recognizes it as scanner.
Jan 22, 2015 | Office Equipment & Supplies
30.01.13 device error
30.01.xx scanner has failed to initialize
there is a connector between the scanner section and printer section of the machine -which comes loose of the pwb its soldered to which is often the fault- where the connector isnt the fault then it falls on the scanner control pwb (attached to the printer formatter) replace this and the fault should be cured
Jan 14, 2014 | HP LaserJet 9040mfp Printer
Lexmark X4550 Scanner not working
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 05, 2012 | Lexmark X4550 Multifunction Wireless Color...
How do I get my new Windows 7 64bit computer to recognize the scanner? tessalee2
connect your pc to internet.then attach scanner with your pc.win 7 automaticaly search internet for compatible drivers.some time auto search for update is off check its on or off .you can find auto update setting in control panel.follow these steps if its not turn on.
1. goto control panel.
2. goto system.
3. select advance system setting on the left side.
4.hardware tab>installation setting>do this automaticaly.
5.done now restart pc and again connect it with internet and attach scanner.
after that goto start then select devices and printers there you can see your scanner
Jun 28, 2011 | Office Equipment & Supplies
My computer will not recognize the pandidgital photolink scanner
Try attaching the scanner directly to the computer. If this works, the problem is obviously in the hub. Many scanners will not work if attached to a bus-powered hub. If you have a self-powered (with a power transformer) hub, double check that the power transformer is working (it should be warm).
I hope this helps.
Dec 25, 2009 | PANDIGITAL Office Equipment & Supplies
HP C5280 all in one prints but does not scan
2 ways to scan from HP printers
First* try from "my computer" ... near the bottom of the page you should see "scanners" in there, try clicking that and follow prompts
Second* go to start/ programs/ HP/ HP Solution Center
all scanning choices should be on the left
Please don' forget to rate me : )
Oct 01, 2009 | HP Photosmart C5280 InkJet Printer
Scanner does not work
Try uninstalling the scanner driver. Then unplug the scanner. Reinstall the scanner driver on the computer and then plug the scanner back in (USB connection).
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Jul 30, 2009 | Canon PIXMA MP470 All-in-One Printer
My computer does not recognize my scanner
YOUR TECHNICIAN WOLKED ME THROUGH A SOLUTION THAT FIXED THE PROBLEM TEMPORARILY.  (REINSTALLING THE ORIGINAL SOFTWARE)  I WAS ABLE TO SCAN 1 IMMAGE, BUT COULD NOT SCAN ANOTHER.
Feb 18, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Need help to hook up IBM color flatbed scanner
Attach one end of a parallel port cable to the parallel (printer) port on your computer and the other end of the cable to the computer port on the rear of the scanner. If you have a printer connected to your computer, you must disconnect the printer cable from the computer before connecting the scanner cable.
If you have trouble attaching a cable connector to a port, be sure that you are connecting the correct end of the cable to the correct port.
IF. . . you want to use a printer WITH your scanner, attach one end of the printer cable to the printer port on the rear of the scanner and attach the other end of the cable to the printer.
Plug in power cord and then power up PC.
Power on scanner. Install drivers. Restart PC to activate EZ Station buttons.
Oct 11, 2008 | IBM Color Scanner Flatbed Scanner
SCANNER GIVEN TO ME DON'T HAVE DISK. DOWNLOADED FROM WEB SITE.
I HAVE THE SCANNER ATTACHED TO HP 4050 LASERJET PRINTER
What does that mean?
scanner should not be connected to anything but the computer.
Did you have the software disk for the scanner?
Oct 26, 2007 | HP ScanJet 3200C Flatbed Scanner
Dell 924 All-in-One InkJet Printer Logo
80 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
