Question about Sony Handycam DCR-TRV320 Digital Camcorder
Camera always returns to telephoto position
For some reason, the camera always returns to the telephoto position. I can push the w/t control, but as soon as I let it go the camera zooms back to the telephoto position.
  • 10,594 Answers
W-T switch is defective and requires replacement,
above part can be demanded under following part number for DCR-TRV320 camcorder...
1-418-799-11 SWITCH BLOCK, CONTROL (FK-10000)
If you have different model camcorder, let me know to provide you appropriate part number.
Posted on Dec 18, 2008
Why does the focusing ring on the efs 55-250mm not retract all the way when you turn the camera off
I doesn't return to it's closed position when the camera is turned off. You have to do it manually . Turn the zoom ring to the 55 position then turn the front focus ring fully to the left.
Apr 27, 2014 | Canon Ef-s 55-250mm F/4.0-5.6 Is Telephoto...
My Nikon D40x will not always take a picture when I push the shutter and will not focus whats wrong with it?
I have the same problem and I make this: take out the zoom lens from the body and put it again. The auto-focus comes back. Another my solution: Push autofocus buton to M (manual) and back to A (auto). Then sometimes starts again to work autofocus. But still I know it is not final solution...
Zvonko
Feb 12, 2013 | Nikon D40x Digital Camera
Pincushion distortion
This can be a characteristic of some wide-angle lenses - have you tried with different lenses, or if the lens is fixed, at a telephoto setting ?
Mar 12, 2017 | Sony Cyber-shot DSC-HX1 Digital Camera
Need information and Instruction Manual for a Vintage Bushnell 300mm camera lens
This is not a zoom lens, it is a fixed focal length of 300mm telephoto, so the focus ring will not slide back and forth, merely rotate. It is also manual focus. If you google it, you may find a manual, but doubtful - best bet is to get a book on basic photography and read up on telephoto lenses there.
Update - allegedly made by Tokina, so should be a reasonable lens.
Apr 01, 2017 | Bushnell Cameras
Hi when I use the creative settings I push the shutter realese button the camera clicks but does not tak the picture until I realesa the button and press it again. Is ths a setting I need to change or is...
No fault of the camera it's has been programed in custom function #9 for mirror lock up. In mirror kock up mode first click of the shutter button locks up the mirror the second takes the shot and lowers the mirror. Mirror lock up is most often used while tripod mounted for extreme close ups or macro photography and also where a large telephoto lens is used. Mirror lock up is for reducing camera vibration during exposure. You can go into your custom function menu scroll to #9 and turn this off and all will return to normal.
Dec 22, 2010 | Canon EOS Rebel XSi Digital Camera
I want to use fairly telephoto lens in D3 slr nikon camera
You don't say what sort of telephoto you want to buy or how much money you want to spend but basically anything longer than a 50 mm is regarded as telephoto.
A staring point for you maybe the lens listed below: Nikon Telephoto Zoom 70-300mm f/4.5-5.6G IF-ED AF-S VR
It importantly has VR or "Vibration Reduction" on it to reduce camera blur when hand holding telephoto shots. This is just a staring point... You need to work out what you want to photograph Cheers Ian
Mar 17, 2009 | Nikon D40X Digital SLR Camera Digital...
I dont know what I am doing!!!
The camera has a zoom lens, so 'W' means 'Wide Angle', 'T' means telephoto.
It also has a dedicated landscape mode which is the mountain icon. Use this when taking pictures of landscapes. The lightning bolt, means 'Flash'.
The backwards 'G' sounds like a film wind icon, but that's a guess!
Jan 20, 2009 | Olympus Photography
I have a canon ixus 70. When I use the zoom facility the pictures become blurred. WHY
Believe it to be a camera fault. Reason: zoom feature makes the lens extend for telephoto work, therefore, the autofocus feature should be working at any distance you set the lens for and your shots should be clear. Could be an autofocus problem or the lens and CCD are misaligned at the telephoto position. Have the camera checked by a qualified repairperson. Get an estimate first. You may want to ask this question at the Canon website also.
Aug 22, 2008 | Canon Cameras
Telephoto lens for digital camera
It will not work because it is the wrong thread size. Here is info on the Olympus TCON-17 lens for the 5050: TCON-17 (1.7X) Telephoto Conversion Lens Extend the capabilities of your digital camera with the TCON-17 Telephoto Converter lens. This telephoto lens will increase the magnification of your subject by 1.7x when your camera lens is set to the telephoto position. This will help you bring in the subject when you can't get closer, for example, shooting sports or concerts. Please see below for additional items required to attach this lens to your camera. The following models require the CLA-1 and 43-55mm Step-Up Ring: C-2000/2020/2040/3000/3020/3030/3040/4000/4040/5050 Zoom ....... The video lens is too small (diameter). If you found one with a 43mm thread and put it on the 5050, you would experience severe vignetting (clipping of the corners of the photo).
Sep 05, 2005 | Olympus Camedia C-5050 Zoom Digital Camera
Sony Handycam DCR-TRV320 Digital Camcorder Logo
169 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
