Question about Kenmore Washing Machines
Plastic nipple is stripped and need to know if it can be replaced
Its an old model and i need to know if it can be replaced and if so how to get back panel off
    President:
  • 2,992 Answers
The plastic nipple is part of the washer's fill valve. The whole valve needs to be replaced (but it's not a very expensive part). You don't remove the back of the machine to get at it. The whole procedure is shown in good detail here:
http://www.popularmechanics.com/home_journal/home_improvement/1276036.html
The replacement part is available at appliance parts stores.
Posted on Dec 18, 2008
My clutch cable to my 1979 suzuki gs 550e snapped and didnt know if it was a fairly simple fix or if it was something that would require a mechanic. Oh, and the person before me has stripped 3 of the...
Easy fix to fit a new clutch cable,make sure you leave the old cable in place until the new one is in place, this way you know the route you have taken is the same as the old one was fitted,
Dont know in respect of the securing screws when you say they have been stripped, do you mean the screw heads no longer suitable for a screwdriver or wrench? If so this can be easily removed using a drill to remove the heads of the screws, first using a sharp 3mm drill bit after centrepunching the screw head. Drill into the screw about 2mm deeper than the head of the screw, then using a 6.5-7 mm drill bit again drill the pre drilled hole untill the head of the screw comes off, some care is required to make sure you accuratly mark and drill as straight as possible. If you mean that the screw threads in the engine crankcase have been stripped then you will have to have the threads repaired using a helicoil repaire kit, once the cover is removed remove the cable nipple from the clutch acuating worm, you may have to carefully bend over the securing tag before the nipple is removed,and caerfully bend it back, after fitting the new cable, Obtain yourself some new fixing screws of the correct length and (WARNING) no longer. Replace the cover, grease the nipple at the bar end, then fit the cable
take out any free play with the addjusting screw leaving about 4 mm free play
May 29, 2011 | 1979 Suzuki Gs 550 L
The hose leading out of the water heater on the inside of the trailer has rusted off. My dad has in the past use epoxy putty to repair it but it has come loose again and I would like to know if and how it...
Coming out of the back should be a 1/2" NPT short nipple, or a check valve with 1/2" NPT threads. ( NPT = National pipe thread. Just ask for a 1/2" galvanized pipe nipple the right length.(short, or 2" usually) If it's a check valve, it will usually be brass or plastic/nylon. I prefer galvanized just because the tend to hold up better. Most water lines connect to that, unless yours has a different fitting such as a female flare going to a male flare fitting in tank. Either way, you'll have to get old one out and match it, to allow for water line fitting to re-attach, or change end of water line to proper fitting to attach to nipple. Without seeing exactly what you have, I can't explain exactly what you need to do.
Nov 01, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
My 2 year-old pulled a thin transparent plastic strip out of our dell photo 944 printer, and now it no longer works. The plastic strip appears to be the only thing he did. Where does it go, and how do I...
The plastic strip you are referring to is the mechanisim to move the cartridge carrier back and forth, you may need to take it to a certified technician to see if it can be replaced or if not damaged put back into the printer.
May 28, 2010 | Dell 944 All-In-One InkJet Printer
Plastic hot water hose nipple on the machine is stripped
See the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.92480200
You should be able to see how the connector fits.
Nov 24, 2009 | Kenmore Washing Machines
How do you take out a broken wall attachement for a pool polaris vacuum? the inside is stripped and we can't get the old plastic out to put in new plastic to attach hose to??
??? is the piece your trying to remove screwed into a coupling. If so use a hacksaw blade ,insert it thru the nipple and cut very gently thru the nipple in several places. !!!!!!! I repeat that is is very importand not to damage the coupling threads. When you are cutting do it a little at a time. As not to damage the threads. If you cut to deep you will ruin the coupling. If you are not sure of what you are doing get a serviceman to do it.
Jul 27, 2009 | Zodiac POLARIS 380 HEAD/HOSE INGROUND POOL...
Water in rear footwell
Look in the front door frame, there are drains from the sunroof that are possibly plugged.
Squeeze the plastics nipples to see if water or dirt/debris comes out.
I took a 10" piece of metal shirt hanger and ran it up the nipple and alot of **** came out. Solved my problem.
Good luck
Dec 15, 2008 | 1999 Volkswagen Golf
Clutch cable snapped on my s reg ford escort 1.6
nipple on top of pedal to release mechanism their is alan key head behind pedal just unwind it the with pedal down drop new cable nipple into the slot thingy.this model doesnt take long compared with old plastic auto adjust type .look at it and you will soon sus it out a 10 min job
Nov 15, 2008 | 1999 Ford Escort
Bleeding breaks on '01 silverado
if you can get the bleeder out replace it otherwise you will need to replace the caliper remember to start at the the line furthest away from the mastercylinder when you bleed them and work your way to the closet
Oct 06, 2008 | 2001 Chevrolet Silverado
Mazda B4000 Fuel Filter replacement
remove the bracket from around the filter, and remove the clip from the fuel line, and it should pop right off.
Jun 21, 2008 | 2007 Mazda B4000
Washing Machines Logo
46 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
