Question about Kenmore 30 in. 42701 / 42702 / 42709 Electric Cooktop
Cooktop light stays on when cool
I have a Kenmore electric cooktop, model 42645/42649/42656. One of the hot surface indicator light is stuck on, even though the burner is off and cool to the touch. We've tried turning the burner off and on, but the indicator light stays on. Any ideas?
  • 2 more comments
  • Anonymous Feb 25, 2008
    we are having the same problem, just wondering if you got yours fixed and what you had to do. thanks
  • Anonymous May 14, 2008
    turned stove off and on again
  • Anonymous May 18, 2009
    I have the same problem for my jenn air cve3401
  • Anonymous Mar 15, 2014
    kENMORE COOKTOP INDICATOR LIGHT STAYS ON
Please be more specific.
A.  What is the "plate cut-out"?
B.  How does one access it?
Posted on Oct 15, 2007
    President:
  • 1,462 Answers
The "hot top" indicator lamp is switched by a contact on the plate cut-out. sometimes this cut-out is available as a separate part but often must fit complete plate. by plate i mean the bit that gets hot!
Posted on Mar 28, 2007
Are there problems with the kenmore 36-in. radiant cooktops 42749 hot surface indicator lights?
Most likely the problem is in the heat control switch.Cannot be repaired you will have to replace it. To make sure, swap it with one of the other burners that do not have the problem. If the problem goes away, you know its the switch.
Aug 08, 2014 | Kenmore 36 in.42741 / 42742 / 42744 /...
Red light on kenmore cooktop stay on when is cold
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on
heatman101
Jan 05, 2011 | Kenmore Cooktops
Red lights stays on
heatman101
Jan 05, 2011 | Kenmore 36 in. 42711 / 42712 / 42719...
Whirpool cook top surface light countiune on even surface are cold
How long does it take for the light to finally go off?or does the light ever go off when a cooktop decrease in tempreture has to reach the tempreture set by the factory for that light to go off. Sounds like a thermal switch which controls the hot surface light is stuck closed If this is a new unit, I'd return it. If not, I would check the switche(s) for the hot surface light -- when the unit is cold, unplug one wire going to the thermal switch and check it for electrical continuity. If you get current from a multi-meter through the switch, replace it -- it's not opening when it cools down.If you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
Dec 12, 2010 | Whirlpool RCC3024 Electric Cooktop
LIGHT STAYS ON FOR HOURS BUT THE TOP HAS COOLED
if its going out, its probably ok
its not a light indicating the burner is on, rather that the glass is abcove 100 degrees and still not safe to put something on
2 hours is a bit long but it depends on how fst the surface can cool of
you can test this by trying to cool it off faster with a fan ans see what happens
Oct 21, 2009 | Whirlpool RCC3024 Electric Cooktop
Just installed an electric cooktop and the Hot Surface indicator light has been on since installation. How do we fix this?
Sounds like a thermal switch which controls the hot surface light is stuck closed.
Charlie
Aug 20, 2009 | Whirlpool Cooktops
Kenmore "Hot Surface" light
hot surface light is turned on by a auxiliary switch across the plate. it is possible that the switch has stuck in the closed position. it is also possible that the plate is not turning off. feel the plate and check if it is at all warm. if not, then the auxialuary switch is stuck closed. not dangerous. to fix means replacing the limiter which is the rod you can see across the plate. sometimes you can only get the complete plate with limiter which is a bit pricey
Jun 26, 2008 | Kenmore 30 in. 42701 / 42702 / 42709...
Unit on light
you have a bad switch. You can check each switch for voltage going to the light one at a time, if your comfortable with that. Remember there is enough current there to seriously injure you so if your not comfortable around electricity, call in a service technician.
Jun 10, 2007 | Kenmore 30 in. 44022 / 44029 Electric...
Kenmore 30 in. 42701 / 42702 / 42709 Electric Cooktop Logo
2,291 people viewed this question
Top Kenmore Cooktops Experts
Dan Webster
Dan Webster
jdthefixer
mcgsp
Level 1 Expert
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
