Question about SanDisk Sansa Clip MP3 Player
Sansa wont cut on
Iwas charging my sansa on a cell charger and it was charging but now it wont cut on at all
  • 8,596 Answers
Using a non-conforming charger can damage your player.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
My cell phone wont stay on
TRY CHARGING THE BATTERY IT SELF WITH A CHARGER..FOR A BIT ANY OLD CELL PHONE CHARGER U DONT USED CUT IT AND CONNECT THE POSETIVE AND NEGATIVE TO THE BATTERY FOR A LITTLE WHILE THEN INSERTED BACK TO THE PHONE AND PLUG IT IN ...WITH THE REGULAR CHARGER..
May 23, 2013 | Cell Phones
This isn't a problem (I hope) but my Sansa clip didn't hold a charge for very long. Can I use my cell phone charger to charge it? It fits the connection fine.
Yes, assuming you're referring to the connection at the end of the Sansa cord and not on the Sansa itself. The Sansa can be charged by any USB device or port that puts out sufficient current.
Dec 06, 2010 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa e260 (4 GB) MP3 Player MP3 and Digital Media i have a e260 sansa mp3. when i plug it into my Answer i have a e260 sansa mp3. when i plug it into my computer it wont charge what should i do
There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Jan 30, 2010 | SanDisk Sansa e260 MP3 Player
Hi,my nokia n95 wont hold charge i have a new battery and new software,do you know what the problem could be,also when it charges it doenst cut out when it is charging it just keeps charging,thank you
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dear user,
Such issue may appear when Nokia charger adapter CA-146C is used with incompatible charger to charge Nokia N97. Currently compatible chargers for N97 with CA-146C are Nokia Travel Charger AC-4 and Nokia Compact Travel Charger AC-5.
Spangley, just plug it into your PC. If your battery needs charging, it will charge slowly simply while being connected to your computer. Nothing else to do!
Goodluck :)
Dec 11, 2009 | Nokia N95 Cellular Phone
MP3 Wont charge or upload
u need a new cord for charging.u lost ur receipt so no problem u can buy it any electronic or computer market i hope.
Aug 03, 2009 | SanDisk Sansa Clip MP3 Player
Phone not charging unless i hold it in my hand and squeeze the charger. Same thing happens with a new charger
Try to reduce the length of wire of your cell's charger.Cut the wire of your charger and reduce its length.Reconnect both wires the same way they were connected before and please make sure wires wont touch each other.Set your phone at charge and see if its charging,if not then connect the wires again but differently.
If you have the same problem with other chargers too then the problem is with your charging port.You'll have to take your cell to cell phone repairer.
Thank you!
Feb 17, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Sansa E250 won't turn on after trying to plug it into an an ipod docking station my sansa mp3 player wont turn on or off the only way i can get it on is to plug it in to charge. and i cant take it to work...
my sansa e250 wont turn on only when i plug it into the charger...and when i try to turn it on without plugging it into the charger it says battery is low and turns off..when actually the battery is full...?
Jun 27, 2008 | SanDisk Sansa c240 MP3 Player
Sandisk Sansa clip
You need the latest firmware update from Sansa' website - may require a restart of computer after performing.
Apr 18, 2008 | SanDisk Sansa Clip MP3 Player
Battery wont charge with an AC adaptor
Dear Verona,
Sandisk is a brand that is best used with its own. There are two degrees of separation here. 1) It is a cell phone charger
2) The charger is not in its family.
With both things working against the machine, it is not a surprise it will not fully charge.
Happy Surfing!
Feb 07, 2008 | SanDisk Sansa Clip MP3 Player
Wont turn on
I don't know if this applies to the Sansa for sure or not but many MP3 devices and smartphones if completely dischard will not charge back up via usb to computer, you have to use a wall jack charger. This is true for the Motorola Q and other smart phones I know for a fact, also the Apple Ipod Gen 5 has had some issues with charging after complete discharge of the battery. Try a wall charger if possible. I don't know much about the sansas.
Jan 07, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
104 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
