Question about HP PSC 1610 All-In-One InkJet Printer
Hello- carriage jam - HP PSC 1610 All-In-One InkJet Printer
  • Anonymous Jan 14, 2009
    unit alternates between the paper jam error code and the carriage jam
    error code. No visable jam anywhere to be found. Cleaned all rollers,
    carrier moves freely, cleaned memory strip (just in case).
  • mmstemp Jan 14, 2009
    It frequently gives the message, "Carriage jam.  Open door.  Clear carriage jam, and then press OK."
    Of course, nowhere in the manual are there any instructions on how to clear the carriage jam - nothing seems to be a problem when I check.  This happens repeatedly.
    Then maybe, eventually, I can get it to print.  How, I don't know.
    The manual is useless.
I was just getting ready to pull the plug on this printer of mine, and order a new one, when I happened on a solution that worked...
Unplug the unit.
Open the top.
Move the carriage to the left.
CLEAN the black plastic tray that the ink cartridge "parks" over - it seems to collect gunky ink that impedes the movement of the cartridge... also clean the "rail" hehind it. I used a Windex knock-off -- and Q-Tips, somebody else said they used alcohol.
Seems to have done the trick for me. I wasted so much time downloading drivers thinking that it was a hardware problem :-(
Posted on Feb 09, 2009
  • 679 Answers
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Posted on Feb 03, 2009
2 Suggested Answers
proton77
  • 1183 Answers
SOURCE: DELL 924 PHOTO All-In-ONE....jam in carriage
Follow the following steps :
http://tinyurl.com/55k6df
Thanks
Mandeep
Posted on Apr 07, 2008
Hello - the carriage has jammed. It was at a tab stop. Any advice please?
It sounds as either the tab didn't knock off or the tab stop has been knocked out of place thus jamming the carriage. You can try gently pushing on the right hand side of the carriage towards the left next to the tab stop to see if it will know off. If it does, then it probably means you have a gummy carriage or the mainspring tension needs adjusted. Other than that you will probably need to have it serviced.
Sep 01, 2013 | Olympia Office Equipment & Supplies
Hello, I got an error message 5C10. What does that
I just had this error message appear on my computer screen and the 6A00 on my MP830 printer at the same time. I heard this error mean a few things (paper jam, ink carriage stuck), though not sure what it does actually mean. I moved the carriage back-and-forth, blasted compressed air and checked for paper jams. When nothing worked, I looked inside and saw a lot of spilled ink, I'm guessing from not using genuine Canon ink. I blotted the inside with paper towels (use gloves!!),especially the far right, and took out the ink cartridges and blotted the carriage. I replaced everything, powered the printer off and on, and it worked fine. I would suggest first to slide the carriage back-and-forth and look for paper jams before cleaning the ink. Hope this works for you.
May 25, 2011 | Canon PIXMA MP830 All-In-One InkJet...
My printer is giving me 2 error messages. One is
For the cartridge jam, that means that either the ink is not properly installed or there is one tiny piece of something blocking the sensors. Same is true with the carriage jam.Please try to look for small bits of paper and remove it.
Is the ink newly installed?
Aug 08, 2009 | HP Photosmart C5180 All-In-One InkJet...
Carriage jam how do i fix this
Hello sir; It got to have something stuck at the end of the shaft, look carefully.
Dec 13, 2008 | HP Photosmart C6100 All-In-One Printer
Epson 1280 ink carriage making noise and not printing
hello there. try re-seating the cartridge. Take it out, then put it back in.
Nov 28, 2008 | Epson Stylus Photo 1280 InkJet Printer
Carriage Jam Error from replacing refilled cartridge
Cleaned the roller & carriage assembly, If possible service the printer your printer will work fine.
Mar 10, 2008 | HP PSC 750 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
504 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
