Question about RCA F36648 36" TV
I simply need to know the weight of the RCA F36648 36" tv
I want to sit my RCA F36648 36" tv onto a wooden stand and I need to know the weight of the television so it won't break the stand.
  • 556 Answers
SOURCE: Weight of TV
near about 75 kg.
Posted on Sep 19, 2007
ctf1800
  • 4402 Answers
SOURCE: service mode help
are you talking service menu?
or opening the back? can you be more specific?
whats the problem your having?
Posted on Dec 11, 2007
ladywinn
  • 5138 Answers
SOURCE: keep changing channel without any input
Most of the time it is the front contact switches Dirty clean them with contact cleaner or replace contact buttons on front panel board 29 cents each Call Mats 1-800-628-1118
Posted on Nov 19, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: need to get the weight of a RCA Model f36665 36
Sorry I can't give you the exact weight. My service literature has everything but dimensions and weights. But Amazon.com says the shipping weight is 170 pounds.
Posted on Feb 01, 2010
  • 963 Answers
SOURCE: hi got a RCA 36
You probably have the internal speakers turned off. Here's a link to the PDF file of your TV Manual:
http://download.rca.com/FilesForRCAcom/Manuals/15491880.pdf
Page 46 of the manual describes how to switch the audio (TV's speakers) on and off.
Posted on Mar 05, 2011
Error 2 . How can we solve this problem. Thank you, Margaret
I found this procedure which was given by Taran_2005. I just come to try him(it) on mine, that works.
"The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero's or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away."
Sep 10, 2011 | Terraillon FBC Alteo Family Body Control...
Need to get the weight of a RCA Model f36665 36" tube tv
Feb 01, 2010 | RCA F36450 36" TV
Trying to find a tv stand for this tv. what is the weight of the tv
  • Dimensions: 29" H, 30 1/8" W, 22 1/2" D
  • Approx. Shipping Weight: 120 Lbs. I would get a stand that gives you some extra capacity for safety. Measure the base of the TV so you know the dimensions of the sets "footprint" to know the dimensions you need for the stands shelf to accomodate the set. Good luck
  • Nov 25, 2009 | RCA F32648 32" TV
    I just purchased a JVC 47'' LCD just need to know how to remove the stand. I have it hanging on a Unti do not need the stand.
    1. remove the 4 screws on the back of the TV (these are located in the deep holes above the stand)
    2. after the screws are removed, the TV will lift from the stand.
    The stands sits inside the TV. after the screws are removed the TV will still sit on the stand. you (and someone else) will need to lift it from the stand.
    Nov 10, 2009 | JVC LT-47X788 47 in. LCD HDTV
    Need to know the WEIGHT of Sony TV: KV-27EXR25
    most tv stands have a large range of rating. most range in increments of 100 lbs. The tv you have is around 40 lbs. so if your stand will support up to 100lbs. your good to go. also you didnt specify if this is a hanging stand or floor stand. I am asumming the previous as being a hanging stand. with that make sure you get the bolts into a stud as drywall will only support about 20 lbs. before ripping out.
    Dec 28, 2008 | Sony Televison & Video
    TV weight
    The trick to lifting Large TVs' is that they are very 'front' heavy, that is, most of the weight is in the picture tube...recall the "problem" of unstable TVs' from years ago (Children pulling down TVs')
    If the TV is on the floor you can put a large pillow at the front (Picture tube face) on the floor & carefully tip the set forward onto the pillow. You can then measure the bottom of the set to see if it will fit on your stand. If you are concerned about the weight simply attempt to sit your body (180 lbs?) on your suspect stand..if it holds your weight your good...wiggle around to see how stable it is.
    _________________________________________________Rick......
    May 24, 2008 | Televison & Video
    Service mode help
    Dec 11, 2007 | RCA P46812BL 46" Rear Projection...
    Weight
    I have one of these TVs and still love it.  The manual says that the weight is listed at 250lbs (approx.).  Most of the TV stands in retail stores only hold up to 240lbs., so that is something to consider.
    Sep 23, 2007 | Mitsubishi CS-40503 TV
    RCA F36648 36" TV Logo
    35 people viewed this question
    Top RCA Televison & Video Experts
    jason
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
