Question about Canon LaserCLASS Fax 710 Printer
E100 error We are getting a system error E100. I can't find this in the manual. Anyone know what this error means?
  • Anonymous Jan 26, 2009
    Also, how do you clear it?
  • 66 Answers
Hi Paikin,
The error code 100 - Excessive Repeat Protocol during Transmission. Causes
1. Poor line condition.
2. Low transmission level.
3. Echo on the line.
Try reducing transmission spped.
Rgs
S88
Posted on Dec 19, 2008
Canon isensys MF8180C show System Error E100 while printing operation.
This error means: there is a problem with the laser unit. Dirty or faulty
Jun 20, 2015 | Canon imageCLASS MF8180C All-In-One Laser...
How do i clear system error E100 on an IR 10181 canon machine and what may be causing this error?
E100 0000 BD detection PCB failureThe BD detection PCB is faulty. - Check the connector of the BD detection PCB.- Replace the laser scanner unit.- Replace the DC controller PCB.
Dec 14, 2011 | Canon Office Equipment & Supplies
Systemerror E100
That means that you have laser unit related error.Probablly bad laser controller pcb.
Jun 01, 2010 | Canon PC-D340 All-In-One Laser Printer
Can somebody help me what this mean? Error Code: E100 0001- E100 0002 it is a canon LBP5000
Symptom
  • E061-0001 (Potential ON)
  • E061-0002 (Potential OFF)
  • E100-0001
  • E227-0004
Cause
  • The pin is broken on the Primary Fan 2 Duct. The Laser Shutter is activated by the pin on the Primary Fan Duct Assembly. The linkage is pinched not allowing the laser shutter to be fully actuated (may also indicate E227-0004). Faulty Laser Scanner Assembly.
  • Defective DC Controller PCB Assembly.
Action
  1. Check the shutter operation and the pin on the Primary Fan Duct Assembly. If the pin is broken replace the Primary Fan 2 Duct (iR6570 : FC6-3540-000 / iR5075 : FL2-5834-000) or the Primary Fan Duct Assembly (iR6570 : FM2-3074-000 / iR5075 : FM2-9694-000). If the Laser Scanner Assembly (iR6570 : FM2-3670-000 / iR5075 : FM2-9832-000) has been replaced and error codes E100-0001/ E227-0004 are intermittently indicated, proceed to the next step.
  2. Remove the Primary Fan Duct Assembly (this assembly has a pin on it that activates the laser shutter).
  3. Remove and reinstall the Laser Scanner Assembly.
  4. Install the Primary Fan Duct Assembly. This should free the linkage allowing the laser shutter to be fully actuated.
  5. Finally a DC Con clear resolved both of the intermittent issues (E100-0001/ E227-0004).
May 28, 2009 | Office Equipment & Supplies
Canon ir5070 i have an error code e100-00001 what does this mean
E100 code
Laser Shutter not opening
Possible mechanical failure or cracked/damaged Primary Fan Duct preventing the Laser Shutter from opening fully.
May 16, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
Canon copier show error code:E100
E100 means the copier is not warming up.Make sure all the wires to the fuser are properly connected, then open and close the front door.you may have to go into the service mode to reset the error code.Good Luck
Mar 26, 2009 | Canon Office Equipment & Supplies
Systems Error E100
ERROR E100 is results when DRUM UNIT is not sitted properly , please check it is engaged with toner ( developing assy).
Oct 02, 2008 | Canon Image Runner 1630 Copier Copier
Ir 2010
The most common cause for E100 is the drum unit. At the rear of the drum unit should be a small peg pointing into the machine. This gets broken off. It's purpose is to opperate a laser cut off shield when the drum is removed so to prevent laser exposure. If peg is missing laser will not be detected by the system and give E100. Can be repaired or will require a new drum if it has done more than 40 to 60K copies.
Sep 28, 2008 | Canon iR 2016i Black and White Copier
I have an error code on my printer Error Code: E100 0000 E100 0001 it is a canon LBP5000
Well im having the same issue E100 error on my xbox one as it was never update till the other day i was thinking is it possible if the nand dumpable and get the keys or signature from it and replace it with a working nand i know it still works cos i able to do the recovery mode with the offline update dianogtic from microsoft but still error E100 after reset
For more help visit cbr tech solutions
Sep 04, 2008 | Canon Office Equipment & Supplies
Canon IR 2000
Canon IR 2000
System Error E100
Feb 27, 2007 | Canon imageRUNNER 2000 Copier
Canon LaserCLASS Fax 710 Printer Logo
1,621 people viewed this question
old marine
old marine
mukhtar21 shaikh
mukhtar21 shaikh
