Security system is okay, put key in ignition and key won't turn to start the car. ? what could be wrong.
SOURCE: security light on and car not starting
Put the key in ignition and leave in the on position for 20 minutes and it should start after that. I had the same problem with a 99 chev silverado an it worked for that. Hope it get you going. Thanks.Bear001
SOURCE: Can not turn key in ignition to the start position.
sounds like the brake pedal lock out switch or the gear selector switch is out of adjustment.
SOURCE: new ignition switch now car security system locked
ok here you go
make sure the battery is fully charged befor starting
turn ignition to run
attempt to start once then release the key in the run position
let vehicle sit with the key on for ten minutes
the security light should turn off
turn igniton switch off
wait 5 seconds
turn key to run position
let vehicle sit for 10 minutes
turn key off
wait 5 seconds
let vehicle sit for ten minutes
turn key off
wait more than 6 seconds
and start engine
SOURCE: when battery was unhooked, the security system
If you have the second ignition key's with you try it. If not try this, it takes about 30 min to do. 30-Minute Learn Procedure 1. Turn ON the ignition, with the engine OFF. 2. Attempt to start the engine, then release the key to ON; the vehicle will not start. 3. Observe the SECURITY tell tale light. After approximately 10 minutes, the light will turn OFF. 4. Turn OFF the ignition switch, and wait 5 seconds. 5. Repeat steps 1 through 4 - two more times - for a total of 3 cycles of 10 minutes. 3x10 = 30 minutes. The vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch turn from OFF to CRANK Important: Turn the Ignition Switch OFF. The vehicle learns the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle. 6. Start the engine. The vehicle has now learned the Passlock Sensor Data Code and/or password. 7. With a scan tool, clear any DTCs if needed. History DTCs will self clear after 100 ignition cycles. Without a scan tool you may have momentary starter interruptions while history clears itself. Good luck and hope this helps, keep me posted, be glad to help.
