Question about Creative Labs WebCam Live!
No image webcam is paired to pc but does not show my image on screen. every time i press for image , all i get is a plain white square comes on screen
Blan White screen
try holding the power and the square at the same time till it shuts downand the apple logo shows up then release
May 12, 2010 | Apple iPhone Smartphone
Screen is always white. Will record picture, but plain white also
The image sensor (CCD) is dead. This is a known manufacturing problem and may be repaired at no charge, even though the warranty has expired. Here's a link to a detailed explanation; http://www.imaging-resource.com/badccds.html
Aug 08, 2009 | Canon PowerShot Pro1 Digital Camera
LCD viewing monitor has "optimize image" screen on it
Press up/down on the multiselector to cycle through different views of the image.
Feb 11, 2009 | Nikon D80 Digital Camera with 18-135mm...
4 black and white images on screen
you need to check device manager and uninstall old camera driver
Then restart system
if you still have a problem then back to device manager uninstall new cam and then restart and reinstall
yes more then likely conflict
please let me know if this has solved
Feb 11, 2009 | Logitech Webcam
WHITE IMAGE ON PIC
Normal 0 Probably has corrupt driver.
Try disconnecting the Camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Jan 04, 2009 | Sony PCGA-UVC10 Webcam
Laptop screen not working
Hi, I'm a laptop technician and if the screen is blank as in there is nothing showing on the screen at all (even when the laptop first starts up), but the laptop sounds like it is starting normally then the backlight or invertor for the laptop screen has probably failed. This is very common.
The easy way to check this is to plug the laptop into a normal PC monitor (if you can) via the monitor out port on the laptop - you may have to press Ctrl + F5 to get a display on the PC screen. If you can get the laptop to show an image on the PC screen then the main laptop itself is fine, and the problem is almost certainly a failed invertor or backlight.
Assuming you *could* see an image on the PC screen, you should then press Ctrl + F5 so that you *can't* see an image on the PC screen any more (this is very important). Next unplug the laptop from the PC monitor (if you did the above) and look VERY closely at the laptop screen. You will hopefully *just* make out a very, very feint and very dark image on the laptop screen. Bear in mind that you may need to re-boot the laptop to get a moving image that you can detect (like the Windows boot up screen for example). If you *can* see a very, very dark and feint image on the screen then the backlight has failed. If the screen is plain bright white or there is no image then the invertor has gone.
The invertor (or inverter as it is sometimes spelt) is a smaller circuit board that sits in the screen housing, the backlight is a very thin "flourescent" kind of tube light that is built into the screen itself. The invertor can be removed and replaced pretty easily by most competent people without much trouble (takes maybe 30-45 minutes to do). The backlight on the other hand is very hard to remove without damaging the screen itself and should only be attempted by a specialist laptop repair company.
Both the invertor and backlight parts are specific to the screen so you must get exactly the same to replace the faulty one with. Online auctions are a good place to get s/hand or new spares, just tap in the *exact* part number or laptop model number and you will usually find someone who has the bit you need.
I hope this helps.
Jan 03, 2009 | Acer Aspire 5002WLCi Notebook
Multiple screen coming up in black and white also flickering on and off
I have a logitech quickcam E3500
I have 4 black & white images
I tried downloading older and newer versions of the software, no joy.
From the logitech site, I found this fix:
Go to Start>Run, type "dxdiag", wait for the application to show, then go to the "Display" tab and disable Direct3D acceleration or Directdraw acceleration. Exit. That's all.
I tried it and it works a treat.
May 16, 2008 | Logitech QuickCam Pro 5000 Webcam
Hp webcam in built
Hello
webcam has small CCD in it and if it goes bad it will show you blue or white image sometime and then other times it will work fine is it is showing you blue or white images sometimes you can take LCD bezel of and then replace webcam easily it is just a small board with CCD inbuilt.
Thankyou
May 05, 2008 | HP Pavilion dv9000z Notebook
Speaker wiring
hi mat
you should have four terminals two plain and two with dots
to get the best power cut two inches off good speker wire
tear apart now place one wire from
plan black to red with white dot then
plain red to black with white dot
this is how set then up with my directed 1100d mono amp .. very loud at half gain
well hope this helps.............. ..benjaminsarmy..
Mar 29, 2008 | Car Audio & Video
Creative Labs WebCam Live! Logo
14 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
