Question about Magic Chef 9512 Electric Single Oven
How to operate Magic Chef Oven
Hi, Yesterday i was trying to bake my food.But i do not know how to operate it.How to set the temperature and time.There are options like bake,broil,timer,clock,stop time,self clean. Please any one let me know how to operate it. I pressed bake and broil but no use. Thanks in advance boss
  • Anonymous Apr 06, 2008
    a likeley story.
    Whoever designed the oven control is berserk . Not even a logical looking way to do anything to clock and no simple way to turn on oven!
  • 306 Answers
SOURCE: Old Magic Chef Gas Oven won't light
sounding like thermostat isn't working. If you could ohm out the t-stat should be closed when you call for heat. If that passes the test then only thing it could be is the gas valve.
Posted on Nov 26, 2008
SOURCE: MAGIC CHEF TIME SAVOR GLASS TOP
Got to this address http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=MCF
And enter the model number
Posted on Dec 15, 2008
jyackle5
  • 8197 Answers
SOURCE: magic chef manual
You can download it here but you need the right model #.
As for the temp adjust it is best if you get an repair man out to do that.
Good Luck
Posted on Dec 18, 2008
Maytag317
  • 1136 Answers
SOURCE: Gas range won't work
Hi, Even tho the ignitor is glowing, it can be bad. It has to pull enough amps to open the gas valve. This is very common problem. I can get you the part and or prices if you could get me the model#
If I can help further, please let me know.
Thanks
Vic
Posted on May 15, 2009
MNfisherman
  • 11896 Answers
SOURCE: Gas smell oven does not light
you may need new coupler on pilot system
Posted on Jun 23, 2009
I have a magic chef electric wall oven and it flashes an error code of F3 when I try to bake something. How do I fix it and what does it mean?
The F3 code means that the temperature sensor in the oven is not giving the signal to the oven control. This could be the result of a problem with the wiring or the wire harness between the control board and the sensor or indicate that the sensor itself has failed.
To identify the correct parts, you need to provide your oven model number. Try here: http://www.partselect.com/Magic-Chef-Parts.htm . There are other sources for parts.
I hope this helps. If you add a comment with the model number, I'll be glad to give you more specific information for your wall oven.
Sep 25, 2011 | Magic Chef Ovens
I have a magic chef S68-3cxw electric stove/oven. It is flashing f2 can anyone advise what F 2 stands for
Hi, the F2 code on the Magic Chef Oven implies that the Oven temperature is too hot.
The solution is to replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness...
Oct 09, 2010 | Magic Chef Ovens
Oven works but wont get up to temp
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.-----
thanks for using fixya,please do rate the solution positively.
Feb 17, 2010 | Magic Chef Ovens
No power to Magic Chef Electric oven
I'm not familiar with this oven, but it ought to have protection against this kind of exciting burn-out.
This could be a fuse: find it and replace it, or it could be a circuit breaker: look for a reset button.
As I said, I don't know this oven; this attempt to help is based on the general idea that it ought to have some built in protection.
Dec 11, 2009 | Magic Chef 9815 Electric Single Oven
I have a magic chef range/oven. For the last few months, it has taken longer and longer for the oven to heat up to temp. Now it won't get more than 90 degrees or so. What is the problem??
Turn off the power to the range. Remove the bake element from inside the oven. Be careful not to let the wires go back into the oven cavity. Take a volt/ohm meter set for ohms or continuity and test the bake element leads. If you get no reading replace the element. If you do get a reading,replace the temperature sensor in the oven.
Oct 08, 2009 | Magic Chef Ovens
Thanks
Vic
May 15, 2009 | Magic Chef 9122 Gas Single Oven
Magic chef 59F - 5TXW
hi. Thanks for the question. The problem is with the igniter . Replace it it is located under the floor of the oven .thanks the appliance doc
Jul 06, 2008 | Magic Chef 9512 Electric Single Oven
Magic Chef 9512 Electric Single Oven Logo
268 people viewed this question
Top Magic Chef Ovens Experts
Sal De
Oloyede Monsuru
reliableservice
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
