Question about Kicker Solo-Baric S12L5 Car Subwoofer
Rattling subwoofer I have a kicker S12L5 subwoofer with an SPL1500 amp. I had the amp level in the middle and the sub was working fine last night. This morning I was driving to school and it was fine. Then it shut off and wouldnt work. I turned everything off and turned it back on and all the sub did was rattle. I thought the coils might have burnt up because I smelled an odor like that but they were fine. It just doesnt seem to be working right at all. What should I do.
  • 62 Answers
If you can smell burning I would say your voice coils are shot... My friend has a older Kicker subwoofer and it was doing the same thing you described... We took it in and the audio repair shop said it was toast.
Posted on Mar 29, 2007
SOURCE:
Kicker dx 250.1 class d monoblock amp has a fixed lpf at 80 hz 24db octave non adjustable. My car stereo is a pioneer deh-x55hd with the sub control set at 100 hz -6 slope unable to turn sub control off to...
Do you have the subwoofer amp connected to the pioneer thru pre amp connections; pre amp output of pioneer to pre amp input of Kicker amp. Page 10 of the manual explains how to adjust the subwoofer output. You can select the cutoff freq. that will pass to the subwoofer; The slopes don't match perfectly, but if you use the -12 slope , it should work fine.
Cut-off frequency:
50HZ
63HZ
80HZ same as kicker cut in freq
100HZ
125HZ
160HZ
200HZ
Output level:
24
to
+6
Slope level:
6
12
http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DEH-X5500HD_OwnersManual112712.pdf
May 19, 2014 | Car Audio & Video
Im trying to figure out how i should wire my Kicker S12L5 sub to my Kicker Zr360 amp. should i wire it for 1ohm and bridge it or what if you could help it would be much appreciated thanks. ...
What is the wattage of the sub? What is the power output of the amp, bridged & not bridged? If the bridged power output will NOT exceed the rated power of the sub then you should bridge it. If it will exceed the rated power of the sub then don't. 8)
Nov 11, 2010 | Kicker Car Audio & Video
Can i hook up my sub if it's wired to a 2 ohm and my amp is 4 ohm
Hi martineztag
You should never connect a load of an impedance less than the min the amp is able to drive. This can have disastrous consequences that may easily result in failure of the amps output stages. You need to use a different configuration that does not overload the amp in this manner for safe operation.
regards robotek
Jan 19, 2010 | Kicker Solo-Baric S12L5 Car Subwoofer
Best amp for Kicker Sub
Hello dalex7,
The Kicker 08ZX400.1 would be a great amp for your subwoofer. It will work into a 4ohm load with no problems.
But you can buy an amp with more power, looks better, has a smaller footprint, and cost less than the 400.1. I'd look at the Alpine MRP-M500. Take a look at it here at Crutchfield. The M500 is also easy to install, runs cool, and is very efficient.
Hope this helps.
May 21, 2009 | Jl Audio CVR12 Kicker 12" CompVR Series...
I have two kicker l5 10's with a 1600 DB SERIES bass dont sound very clear how can i make it clear and loud ?
Make sure to tune the amp according to the subs. Turn all the levels down on the amp, then start with turning up the gain till you can tell the sub is struggling, from there turn up the crossover to around 120hz. Then adjust the gain again as now it will prolly be to high. Also it depends on how you have the subs wired up.
Apr 06, 2009 | Kicker Solo-Baric L5 Car Subwoofer
My subs sound distorted and dont pound right 2 12in cvr kickers and a kingwood 2 channel amp think its not wired right
Are you sure the polarity is correct on the sub's connectors? This is very important as reversing them will cause the sub to pound inward instead of out. Make sure the wires are thick enough and that the amp's + connector goes to the red(or +) connector on the sub and that the amp is grounded properly to a clean piece of metal on the car's body. This ground wire should also be as short as possible. Also make sure the fine-tuning for the bass level on the amp is adjusted correctly and that the sub's enclosure is the correct specification ie. Ported or sealed, right size, etc.
Mar 09, 2009 | Kicker CVR12 Car Subwoofer
Subwoofer/speakers are hooked up to my amp but making bad noise
it sounds like you have some wires crossed or a bad ground
Hope this helps
Jan 25, 2009 | Kicker CVR12 Car Subwoofer
Subwoofers
sell me the subs it would be better
Oct 29, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Intermittent Subwoofer
the wire from the coil to post is probably severed.you might have to take the dust cap off..
http://www.mwaspeakerparts.com/
this is a speaker part site
Jan 13, 2008 | Kicker CVR12 Car Subwoofer
Kicker Solo-Baric S12L5 Car Subwoofer Logo
214 people viewed this question
Top Kicker Car Audio & Video Experts
Morne Olivier
Marvin
Marvin
Dalynn Turner
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
