Question about Maytag Neptune FAV6800AW Top Load Washer
I have a maytag neptune fav6800aw tl washing machine that is out of balance I guess you could say. On spin cycle sounds like the washer is going to come apart?? just started and getting worse... Also can you send a link to get the repair/owner manual for this? Thank you tommy Lumsford
  • 335 Answers
Tom,
Here is a link posted by another member of this site for the Svr Repair manual;
http://www.fixya.com/support/t495521-fav6800_manual
This will help you trouble shoot issues with this machine.  I removed my clutch and lubed needle berings in the clutch pully and that took care of my issue of DC/UC errors in spin cycle.  Here is a quick note on my repair action.
I just did a repair on my FAV6800AAW by lubricating the needle bearings in the clutch pulley hub, the tub displacement sensor checked OK per the service manual check. I was getting dc/uc errors in the spin cycle, washer was purchased in 7/05. I have basic mechanical skills and used a socket wrench to remove clutch pulley, just follow the service manual removal steps to remove clutch pulley. Pull the plastic cover off the clutch pulley and inspect the spring, clean/lube needle bearings and the clutch hub coupler that drives spinner shaft. I used WD40 I may need to re-lube down the road with a good light grease. It took a few tries for me to get the clutch pulley to stay on after re-install and power up, getting the clutch pulley seated properly is the trick. I did not remove the washer tub for this fix, I believe I saw a posting where someone did. I just leaned the washer back to get a better reach angle, it is a tight work area. I did not want to junk 4 yr old $1k machine with out trying a fix. If you want to work on this model get the service manual, I found it online and I believe you can order it in PDF format from Maytag. Good luck!
I just went thru my 10th load of a mix of light, medium and heavy loads and all work fine no unbalance errors (DC/UC). Doesn’t fix the tangle problem :) Prior to this fix I could only run the washer with no clothes in it to complete a spin cycle with no dc/uc error codes.
Posted on Dec 19, 2008
We just moved and the house came with a Maytag Neptune TL which won't spin if there are clothes in the cylinder. It will spin empty. Please help! Thanks.
Washer bangs around in spin cycle and throws a DC or UC unballance code with cloths in the wash basket is that correct?
If so it's a Clutch issue.
If you want read more about what I feel is your issue read this post Maytag Neptune load unbalance
Sep 08, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Washer want pump out all the water and it will not go in the spin cycle, and it cut off display UC Code
Google this Neptune TL Washer FAV6800AWW
5th post down in the sticky you will find my service notes to get you back in service.
Mar 10, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag Neptune TL will not switch cycles, when I started the wash cycle it said 57 minuntes came back 1/2 hour later and it still said 57 minutes tried unpluging it to see if it might clear any erriors...
What happens if you do a Spin Only cycle with that wash load?
Does it fail to go thru the 12 min Spin Only Cycle?
Any error code to the console?
Do you want to troubleshoot?
Feb 19, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL stops spinning mid cycle? The washer stops with 11 to 13 minutes from the end of the wash cycle and leaves water in the wash tub. We've tried shifting the load for balance but it does not...
RF_Tim
I feel you have a Clutch malfunction a very common problem with the machine. If you want to DIY the fix see my Clutch Fix post.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
If you need some additional help just shout back……..Rich
Jun 30, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Neptune Washer Spin Cycle
If your FAV6800A or FAV9800A wash tub is banging around in Spin Cycle of the Wash Cycle and your Control Board signals a dC or uC error code to the console I feel you have a Clutch malfunction. I feel the TDS is working as designed with the unblance error code shut down.
See my Clutch Fix post for more info related to dC and uC unbalance errors with the FAV6800A and FAV9800A TL’s and the repair action…….Rich
May 10, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag will not run a complete cycle. Is there
mgissy
What is your machine model number? Is it a FAV6800A or FAV9800A TL?
If it’s a FAV6800A or FAV9800A TL do you error out in the Spin cycle of the wash cycle with an unbalance error code such as dC or uC? Is the wsh tub banging around during Spin Cycle of the Wash Cycle?
If so see this post Clutch Fix. I have a step by step maintenance/repair process for Clutch Pulley assembly issues related to the above error codes.
Post back if you have questions or concerns………Rich
May 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl makes grinding sound and stops at 33 minutes in normal mode and at 24 minutes in quick wash mode
Hello djlampl,
With the lowest spin cycle setting I enter spin cycle in Quick Wash around the 21 minute mark. But first question is do you hear the grinding noise with the tumblers rotating during the wash/agitate cycle?
If you start a spin only cycle do you hear the grinding noise?
Does the washer error code out with an error code to the display? Codes such as dC, uC, Lr?, I assume the machine type is a FAV6800AW is that correct?
Any additional info will help in troubleshooting…..Rich
Assuming the machine type is a FAV6800A/FAV9800A here are some handy links;
The Service Manual for reference. Sears Parts Direct for reference.
Nov 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Won't complete spin cycle, code dc
If your machine is a FAV6800AW or FAV9800AW see this post for a DIY repair/replacement of the clutch in your machine. If this is not your machine model type disregard my post.
Aug 27, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
133 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
