Question about Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television
Pioneer SD-532HD5 Good Morning, Last year I had to repair the power supply for the SD-532HD5 projection TV (the turn off problem), and I managed to have the power supply assembly re-soldered and it worked fine until now. Yesterday the convergence went severely out of whack, picture is doubled and the colour is out. The yellow and green centre cross pattern now has 2 vertical cross hairs about an inch apart and the blue is a couple of inches over and maybe 2 inches between the doubled centre vertical cross hairs (multi-point looks like spaghetti). There is no possible way to bring these all together through TV setup. I took the TV apart yesterday and everything is still clean and firmly fixed in place so my question, is there a main board that controls the convergence?, how much would it be? And in your opinion is it even worth fixing it again? I'm loosing my faith in Pioneer and would think a TV would last more than 6 years. Thank you, Ray
  • Ray Klatt Mar 28, 2007
    Thanks Techman,
    I have called a tech and he mentioned the IC's as well, promisses me he can fix it for under $500.00, $100.00 for each IC and $90.00 for travel plus labour. I hope that ends my problems, I do still enjoy the HD picture quality (when working, as good as my freinds plazma)but I am loosing faith. If I decide to sell it (when working) any idea whats it's worth, it is old technology I guess. Thanks again
How do I open the sd-582HD5 to get to the PS board, from front or back?
Posted on Oct 31, 2007
    President:
  • 3,130 Answers
This fault happens with just about any tube type projection set. The convergence IC's simply need to be replaced. They are two black, 2"X3", stand up ICs that will start with the letters STK on the surface of them and are mounted up against a large metal heatsink. If you have the soldering skills this should not be so hard for you to do, but please if you do not have the skills or experience to replace these IC's call in a pro to assist you with this repair. Good Luck
Posted on Mar 28, 2007
I HAVE A SD-532HD5 RED LIGHT STAY ON....IT USE TO TURN OFF BY ITSELF ONE DAY IT WENT OFF AND NEVER CAME BACK ON ......THERE IS A RED LIGHT ON THE POWER BOARD
This model and others close to it have all sorts of soldering problems on the power board----fixed a lot of them by removal of power board and aside from fuses solder the ENTIRE board--every connection---bad connections develop with age and heat.
Oct 14, 2012 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer sd-582hd5 shuts off while watching
internal components probably need to be cleaned.... sounds like a problem with t.v. overheating
Jul 11, 2009 | Pioneer SD-532HD5 53" Rear Projection...
When tv is turned on green light comes on then goes to standby
had the same problem on mine.
Found loose solder terminals on the main power transformer, resoldered fixed it up about 5 min.
Nov 01, 2008 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer SD-532HD5 Projection Screen TV won't turn back on.
the problem with pioneer projection tvs is that when they made the boards they never used enough solder for the circuits and you get cracks in the runs. thats why heat and cold will effect it. I had the same problem and I took out the board and resoldered every track I could and it works good now but my remote wont work if anyone has any info or prints to this tv please post on here
Jul 26, 2007 | Pioneer SD-532HD5 53" Rear Projection...
Off Screen Picture
There is a width problem. There could be a control inside to control this but the TV should not change so drastically. There is most likely a problem in the width circuit.. This is a high voltage circuit, and is very dangerous to tinker or experiment around inside of. Your best bet would be to call an Authorized Pioneer repair shop and have them have a look at the set. Good Luck
Jul 14, 2007 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer SD-532HD5
it is time to buy a new one,,,sorry
Aug 23, 2006 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television Logo
240 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
