Ricoh Aficio 450 Copier
Problem for Ricoh Aficio 450 Copier
SC405 - 00 Code Can it be reset
By mmcgrath on Dec 18, 2008
Happy Holidays - I have a Gestetner 3245 with a SC405-00 code. Can it be reset. If yes, how?
Thank you very much.
Mark
Best Solution
posted on Dec 18, 2008
Helpful)
moe0303
Rank: Guru
Rating: 87%, 37 votes
Yesy this code can be reset by turning the machine off at the red power switch located on the left side of the machine. If this does not fix you problem, then the machine may need to be serviced.
Was this helpful?
Yes
No
Solution #2
posted on Dec 24, 2008
Not Rated)
copyclubweb
Rank: Master
Rating: 95%, 2 votes
Transfer belt error or fuse FU5
1. Spring missing on machine that touches the transferbelt unit. when door is closed. There are two. one of both are missing.
2. Fuse FU5 blown on the power board on the left side of machine.
Was this helpful?
Yes
No
Popular Solutions for Ricoh Aficio 450 Copier
Questions and Unsolved Problems for Ricoh Aficio 450 Copier
Do you recommend Ricoh Aficio 450 Copier?
Answer
Answer
how to scan data memori canon iR6020 to komputer
Answer
I took cartridge 31 off the printer (Lexmartk X5450) several times to clean it with ink cleaner (it... (More)
Answer
I need the plastic part that holds the lamp mine is broken were can I get this part?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copiers Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
