Question about Philips Lands Phones
Phillips SE140 duo - had power cut now phone not registering with base! I dont have the manual anymore!
You may have to input you country code again as you did at set up .then you will probably find that your handset will register as long as you use the master charger
Posted on Feb 11, 2009
My vtech phone says not registered and not sure why and how come? can this be fixed or do i have to buy new one? model # CS6114 S# LR605935851
Here is a direct link to the User's Manual for your phone:
http://vt.vtp-media.com/ecp/documents/product_Product/1624/UserManual/5352/cs6114_manual_i6.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 26 of the manual for detailed instructions on HOW TO REGISTER THE HANDSET TO THE BASE.
Basically, the manual reads as follows:
Not registered appears on the handset and it does not work at all.
The handset may be deregistered from the telephone base.
Follow the steps below to register the handset to the telephone base.
1. Remove the handset from the telephone base.
2. Press and hold FIND HANDSET button on the telephone base for about four seconds until the red IN USE light turns on.
3. Then press # (pound key) on the handset.
It displays Registering... and it takes about 60 seconds to complete the registration.
The handset displays Registered for a few seconds and you hear a confirmation tone when the registration process completes.
I hope that was helpful to you, good luck and take care.
Joe.
Aug 13, 2011 | Vtech 2653 Cordless Phone (VTECHEV2653)
I have a SKPE Phillips phone VO1P8411B/37. In an effort to fix the phone I de-registered it. When I select REGISTER, it comes back with 'Registration failed'. I tried to put in the default code of 0000...
Firstly, unplug the base unit, then remove from this base unit the ethernet cable and most importantly, unplug the telephone line! Then remove the batteries from the 2nd handset. Keep everything unplugged for a few minutes, then plug the power into the base unit, wait 1 minute, then plug in the Ethernet cable and wait 5 more minutes. Do NOT plug in the telephone line just yet. After the 5 minute wait, put the batteries back into the 2nd handset and then follow the registration instructions from the manual (copied below)...
Make sure you have configured the language, country code, and area code of your
phone before registering additional handsets.
1. Press "Reg.". Register shall be highlighted.
2. Enter the system PIN (Default: 0000). Use "Clear" to correct typing errors.
3. Press "Enter" to confirm.
• Your handset starts searching for the base.
4. Press the top button on the base unit until the two indications turn off.
• If registration is unsuccessful, the signal icon displays steadily.
TIP: IF REGISTRATION FAILED, REPEAT THE ABOVE PROCEDURE.
Like other methods, you must hold down the button on the base unit until the lights STOP blinking. When you have successfully registered your 2nd handset, then plug in the telephone line into the base station. I did the above and it worked! The trick is to be patient and wait the few minutes while everything resets itself.
Aug 05, 2010 | Philips Lands Phones
Need manual in english for philips se140 phone
phone.manualsonline.com/ex/mfg/headline/m/philips/d/cordless_telephone/type/manual_request -
Jun 08, 2009 | Philips Lands Phones
One of the handsets of my Dect telephone can not be registrated anymore.
On my phillips phones you first have to "enable registration" on the base before you can register the phone - the RC code should be a label on the bottom of the phone. Else unfortunately the handset could be faulty.
Apr 30, 2009 | Lands Phones
Philips cd245 duo wont register and wont reset
Hi, I sort of solved this issue. What you cannot confuse here is that when you are doing "Registering" on your existing handset, the base has to be in the registration mode too. To get the base in the registration mode, you have to press <page> (or speaker with sound symbol on the base) more than 5 seconds, then the base is in the "Register Mode". You can then go through the procedure you describe and the handset will beep with Registration number on the screen. This is however a fix only if the Base is still functioning. In my case, sadly, the base was more likely dead (if I press any button on the base, i.e. answer phone etc., there is no response). Hence I went and bought a new cheap GAP compatible BINATONE 1800 Single at Comet (14.99). I then set up the base, put it in the registration mode. Then on the Phillips CD245 handset and gone through the above registration procedure... and Voila! It worked. Now I have a new base that came with 1 handset, then 3 of my CD245 handset are all registered with it. So far, the sound quality is good and I also managed to have kept all the telephone numbers registered with the handset. The BINATONE base came with 12 months manufacturer's guarantee so I am sorted with the base problem for at least a year, which is nice. I hope this is helpful. Best, Ken
Apr 04, 2009 | Lands Phones
Phillips dect2152
If you bought the base and handset together they should already be registered. If not then the instruction manual is downloadable here: MANUAL
The relevant section is on page 16 - here is a copy:
4 handsets can be registered to the base station. A handset
can only be associated with 1 base station.
�� To register another handset
First enter registration mode by unplugging and
plugging back in the power adapter to the
electricity supply.
Handsets registering / unregistering ( )
�� To unregister the handset you use
enter the RC code*
�� To unregister all the handsets (except the handset you are using)
enter the RC code*
Once the menu is selected, enter the RC* code written under the base and press
to confirm.
Warning : If you wish to associate a non-Philips handset to the DECT 211 or DECT 215 base
stations, make sure that these handsets are GAP compliant otherwise they will not operate properly.
*RC code
(Registration
Code) is
written under
the base.
Warning : Once unregistered, the handset is no longer operational.
Please rate my assistance this should be a fixya!
Mar 29, 2008 | Philips DECT 2151 Cordless Phone
Registering a base station of Siemens Gigaset 2415 Cordless Phone
To register your handset to that base station, you must put the base station in registration mode at the same time you put the handset in registration mode. This is how you do it. At the handset you push OK when it asks you to register. If it asks you for the pin enter 0000 (factory pin) and push OK. The handset should say "registering base 1". Then at the base press the page/reg key down until it flashes (its to the immediate right of the cradle where you rest the handset for charging). That puts the base in registration mode and now its looking for the handset and vise versa. Now watch your handsets display. If it asks to to select an intercom number, then push ok and your done. If it says "invalid pin" then you need to reset your pin on your base (thats a different problem see below). If the handset times out and never registers, you need to repeat the process a couple times, you may have a bad base or it needs to be defaulted. If you need more help you can download a manual for free or get free technical help at the link below.
http://www.barclayent.com/manuals/Gigaset%202415%20User%20Guide.pdf
If you need to default your pin, you can do so but it will default the base station to factory settings. To do so remove the power from your base, hold your page/registration key down, and apply power back to the base. Count to 15, then let off the key. Turn off the power, count to five, then apply power again and follow the steps again to register the handset and you will need to reregister every handset that was previously running on it.
Feb 02, 2008 | Siemens Gigaset 2415 Cordless Phone
Lands Phones Logo
301 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
