Question about Sony Handycam CCD-TRV68 Camcorder
Camcorder has audio, but video will not display on viewfinder or LCD screen.
  • 320 Answers
Try a cleaning tape. It sounds like the heads are clogged.
Posted on Dec 18, 2008
Samsung scl901 camcorder screen "rolls" on lcd
Possible that there is loss of sync from the signal and so it is unstable on both the viewfinder and the LCD display. This can be a fault on the main board- processing section. It can also be related to weak passive components or development of moisture. Leave the camera ON for few hours , place it on a warm surface - near to a table lamp and see if the fault changes. If so you need to keep using the camera often to keep the circuits active.
Oct 15, 2011 | Samsung SCL901 Hi8mm Camcorder
Sony DCR-TRV250E.
was the problem the lense cap, or you do still need assistance?
Mar 28, 2008 | Sony Handycam DCR-TRV19 Mini DV Digital...
No display in viewfinder and LCD
i think you are able too see the video in play back mode. so there is no problem in your LCD.
i think the CCD has got damaged in your CAM. that is why you are not able to view anything in shooting mode.
because CCD is the layer which converts the light falling on it to a electrical signal and shows us as a complete image.
Dec 25, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
My handycam screen is blank and doesn't show anything
Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record.
NOTES:
* Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
* It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
1. Ensure the lens cap on the front of the camcorder has been removed.
2. Ensure a fully-charged battery is inserted in the camcorder.
3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
4. Turn on the camcorder and set it to the CAMERA mode.
5. Look to see if an image can be seen in the viewfinder or LCD.
IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
6. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshooting steps, service may be required .
Dec 23, 2010 | Sony Handycam DCR-HC40E Mini DV Digital...
Not seeing anything through the viewfinder when switched on
Most cameras and video recorders now display picture either through the viewfinder or the LCD screen.
Your camera model allows the same. Although if you turn the lcd screen towards the subject (screen faces the same direction as the lens) then the viewfinder switches on.
Sep 26, 2009 | Canon ZR200 Mini DV Digital Camcorder
Blue screen when using VCR function
Hi and welcome to FixYa,
A blue screen is 'video muting', the player is not getting a decent video signal and rather than display distorted / noisy video, it is muted.  Initially, has a video head cleaner been tried on the camcorder?
Good luck and thank you for asking FixYa.
Aug 02, 2009 | Sony Handycam DCR-TRV80 Mini DV Digital...
Records audio but no video
Replace the ccd base assumbly and check.
Jan 01, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Recording problem
Knowledge Article C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record. Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record. NOTES:
  • Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
  • It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
  6. IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
  7. If the issue is not resolved, reset the camcorder to factory specifications.
Nov 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
LCD screen isn't working.
Hello, the special flat cable connecting LCD panel with main board is broken. If you want I can supply you with further info (part number, etc.) at LIVE Expert Assistance. Best regards, Arpi
Jul 01, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Malfunction?
If the LCD display is open, the viewfinder becomes inactive. Shut the LCD display, and the image should appear through the viewfinder. If there is still no image, the camcorder may require service.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Sony Handycam CCD-TRV68 Camcorder Logo
52 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
