Question about HP Compaq nc6000 Notebook
Laptop won't boot up
I installed a new linksys onto the network computer and now the laptop won;t boot up. Everytime I turn on the computer and type in the password the computer flashes an error message, the computer shuts down and will keep doing the same thing until I hold the power button for it to power off.
  • 679 Answers
That shouldn't affect the laptop booting, hold down the power button for 10 seconds, it shoul boot up., if not then remove the battery and replace it. then try it again, good luck, Gym
Posted on Dec 18, 2008
How to replace linksys-g home router with linksys e3000
Use the laptop with a network cable to check connection. Just connect the NEW? e3000 to the ISP modem. It should work right from the start. If the e3000 is not new, there is a reset in the back.Hold it till it cycles.
The wireless on the laptop should pick up the new router as a new network.
You can even go further back by cycling the ISP modem as well.
Oct 16, 2012 | Linksys Wireless-G WRT54G Router
I have this product and Im trying to install it in the computer Wireless-G Notebook Adapter WPC54G
Go to this website on a computer where you can download the drivers. http://www.linksysbycisco.com/US/en/support/WPC54G/download Copy the downloaded file onto a USB drive (thumb drive) and then install the driver from the USB drive onto your laptop before you insert the wireless adapter card into the laptop. After the driver installation is complete, then install the card into your laptop and it should be recognized and after a couple of minutes,should be ready to go.
Jan 26, 2010 | Linksys WPC54G Wireless-G Notebook Adapter...
Lost installation cd cant connect to wireless router wrt54g v8 linksys router need to know how to get it connected to my laptop
If you configure the Linksys wireless router with encryption and you configure your wireless card in your computer with the router's encryption settings it will secure the Linksys wireless router and allow your computer to connect to the Linksys. Please click on this link and follow my instructions to secure your wireless router :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jan 06, 2010 | Linksys Wireless-G WRT54G Router
My Dell laptop won't connect with my Linksys G wireless router
First check in your laptop wi fi switch is turn on if you have laptop.
Then check in computer that wi fi network adapter driver are installed correctly and enabled .
You can check it in my network places right click on it thne go to proeprty then you see there wi fi network driver then enable it.if disable.
Then you can see search for available networks.
If not works then post here so i give you assistanse for router configuration.
Let me know if you need more assistanse.
Aug 31, 2009 | Linksys Wireless-G WRT54G Router
Laptop not working
try to boot the computer in safemode with networking .
first shut down the computer and then while u turn on the computer start pressing F8 on the computer for 12 times and it will give you an option for advanced boot option from the list select safe mode with networking and then try to boot the computer ,,,,,once u log on to safe mode then go to run and in run type in msconfig ,,,in system configuration box select services and disable unwanted services and then restart the computer on normal boot and then the system will work fine ,,,,,,
Jul 21, 2009 | HP 413670-001 - HP Compaq nc6320, nx6310,...
NEW WINDOWS VISTA NOW LINKSYS WILL NOT INSTALL
first coonect your wifi router witjh your laptop with ether net then go to this link
http://192.168.0.1
then type user :admin and password also admin or blank
then go to dhcp then enbale it with auto .
then disconnect your cable from laptop.
then go to my network places then find wireless network then simply conect your network.
thtas it.
then check tcp/ip poperteis in your lmy network places properties enable in auto get ip adreeses.
Nov 04, 2008 | Linksys Wireless-G Broadband Router
Laptop could not detect linksys on second day
Jatman,
Couple of things you can try here:
1) Connect your laptop (or another computer if possible) to the router using a network cable. You should then be able to see your configuration info. Make sure that the computer you are using to connect (wired) to the router is set up to use DHCP. Once in there, depending on what you find, you might be able to fix it yourself.
2) Factory reset the router and go through the setup options as if it were brand new.
Hope this helps.
May 18, 2008 | Linksys Wireless-G WRT54G Router
Unable to log on to network with Apple Laptop
The type of computer doesn't matter, as the protocols are the same. Check your router's dhcp settings, as you may have it set to allow too few IPs to be distributed.
Apr 09, 2008 | Linksys RangePlus WRT100 Wireless Router
You are connected to access point but the internet cannot be found.
Do you have a connection wizard that you can run on your computer? Linksys offers them for downloading at their website. Try that -
have you named your home network so your wireless connection can "find" it? You don't mention how your main computer is networked in. A wireless adapter for a notebook will need to have a Linksys connection wizard run on the laptop.
If you have a Linksys router connected to your main computer, it should already have the piece of software you need. Most likely, you'll need to put it on a flash drive and install it from that onto your laptop. the wizard helps also to diagnose the right settings.
If you want to post what you are using for your main network (linksys router?) and which operating systems you are using, that will help.
For example, in Vista, you'll need to enable the option for "network discovery" under your laptop's control panel/network and sharing center.
You also need to have certain settings on your main computer for the wireless to work - there are two main types of wireless connections - B and G. Most of today's routers and cards will do both, but if you have an older router, it might not be set up to handle the newer or combined types. They run on different frequencies, so your laptop might not be "reading" your router's frequency.Also, if you have other wireless/radio frequency equipment near your laptop, it can interfere with the signal being received right.
You also need to be sure that your firewall allows the linksys system to access your computer (allowed programs).
Dec 10, 2007 | Linksys WPC54G Wireless-G Notebook Adapter...
Can not connect adapter to laptop no installation CD-Rom
you have to install the driver for it to work and i assume that is not the case as you have no cd. Go here to download the driver. http://www.linksys.com/servlet/Satellite?c=L_Download_C2&childpagename=US%2FLayout&cid=1115417109934&packedargs=sku%3D1134691790190&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=0993490190B03 When installed go to the properties of your adapter in network connections, then click on tcp/ip line and then properties and ensure obtain ip address automatically is ticked and press ok. You may also have to use the home network connection wizard if you havent previously to share documents over your network.
Apr 13, 2007 | Linksys Wireless-G WUSB54G 802.11g/b
HP Compaq nc6000 Notebook Logo
124 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
