Question about Casio CFX 9850GA Plus Calculator
Confused where can I get a free manual of operations for a cfx 9850gb plus
  • Casio Master
  • 7,993 Answers
Here is the link to the user s manual.
http://support.casio.com/manualfile.php?rgn=4&cid=004002005
Hope it helps.
Posted on Sep 22, 2009
I have casio cfx 9859gb plus i dont know how to change from deg to rad pls help
Press SHIFT [SETUP] to bring up the setup screen. Move down to the line beginning "Angle" and select "Rad."
Nov 29, 2010 | Casio CFX 9850GB Plus Calculator
Operation manual for Casio cfx=9850gb plus
Casio CFX-9850GB Plus/Product User Maunal
Link for manual: http://support.casio.com/pdf/004/fx_plus_ch_intro.pdf
Sep 12, 2010 | Office Equipment & Supplies
Casio CFX-9850GB Plus calculator will not switch on when AC/on pressed, all 4 AAA and 3v backup battery are new.
If it is just a matter of the screen being too dim, you can actually increase the contrast.
  1. Turn calculator ON
  2. Press [MENU] even if you do not see anything
  3. Press [ALPHA][COS] sequence to access the letter E.
  4. Press repeatedly the Right Arrow till the contrast is adequate.
Jun 14, 2010 | Casio CFX-9850G Plus Calculator
Casio cfx-9850gb plus calculators's graph messed up
Press the RESET button on the back of the calculator. Use a starightened paper clip.
May 05, 2010 | Casio CFX 9850GB Plus Calculator
Do i have only one type of exponencial regression o my 9850gb plus?
Th CFX-9850GB Plus is programmed to perform 10 types of regressions, namely
LinearReg: Linear y=ax+b
Med-Med also linear y=ax+b
QuadReg :Quadratic y= ax^2+bx+c
Cubic: y=ax^3+bx^2+cx+d
Quartic: y=ax^4+bx^3+cx^2+dx+e
LogReg, logarithmic: y=a+b*ln(x)
ExpReg, exponential y=a*e^(bx)
PowerReg, power: y= ax^b
SinReg, sinusoidal: y=a*sin(bx+c) +d
LogisticReg, logistic; y= c/(1+a*e^(-bx))
There may be more regression models appropriate for more advanced (specialized) statistics but the ones in the list are all the CFX-9850GB plus offers. However, since the calculator knows a programming language, you may want to implement a particular model.
Hope that helps.
Oct 24, 2009 | Casio CFX 9850GB Plus Calculator
Generating random numbers
Turn calculator ON, press MENU if you see no icons. Use arrow key to highlight the RUN application. Press OPTN, press F6 to pan right. Press F3: Prob, then F4:Ran# then EXE to execute.
Each time you press EXE a new random number is generated. You might want to fix the number of decimal digits to less than the 10 digits displayed by default.
By default number generated are between 0 and 1. If you want numbers between 0 and 100 you enter Ran#(100).
Hope it helps.
Oct 20, 2009 | Casio CFX 9850GB Plus Calculator
Calculation with angle
You perform all calculations in complex mode. When you need to convert to angle amplitude, in the [RUN] screen press [OPTN][F3:CMPLX]
To obtain the angle press [Arg] ( complex number) [EXE]
To obtain the magnitude, amplitude press [Abs] (complex number) [EXE].
Since the [ANS] memory keeps only the last value calculated, you may have to store your result (the complex number) in a variable.
1+ 1 i [white right arrow under tan key to store] [ALPHA] H
Display shows 1+1i. Then
[Abs] [ALPHA] H [EXE] gives 1.414213562
[Arg] [ALPHA] H [EXE] gives 45
Hope it helps.
May 22, 2009 | Casio CFX 9850GB Plus Calculator
Ma error appears in stat menu with casio cfx-9850gb plus
Here are the possible causes for such an error
1. calculation results exceeds calculation range.
2. Calculation is outside the input range of a function
3. Illogical operation (division by zero, etc.
4. Poor precision in sigma calculation results,
For all these reasons
Check the input numeric values and correct them . If you are using memory, check that the numeric values stored in memory are correct.
Hope it helps
Apr 07, 2009 | Casio CFX-9850G Plus Calculator
In it's back, there is a small hole-reset key. prick it with your pencil.
Nov 11, 2007 | Casio CFX 9850GA Plus Calculator
Casio CFX 9850GA Plus Calculator Logo
133 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
