Question about Panasonic NV-EX3EN Mini DV Digital Camcorder
Panasonic Nv-EX3 - Error F02
I havent used my camera for some time and get a display message on screen "F02". I am unable to switch from Camera to VCR and Camera LED light is simply flashing Red. Can any one help ?
    New Friend:
Hi
I do not know how to get digital photographs in my pc how to do it.
you may reply to my email adress through face book sunil.vadher@gmail.com
Posted on Dec 08, 2012
  • sunil Dec 08, 2012
    Hi
Hi
I have just had the same problem and I have just charged my battery, taken out the tape, switched the camera off and when switched back on and re-entered the tape everything is working. Hope this helps.
Posted on Jan 07, 2009
PANASONIC EX3 MINI DV FAULT CODE PLEASE HELP
Hi
I have the same camera and just had a warner F02 code on my screen and the red light flashed twice. I have just taken out my tape and switched off then switched back on and all the functions are working. Hope this helps.
Oct 06, 2008 | Panasonic NV-EX3EN Mini DV Digital...
Panasonic NV-DS55
Try to restthe setting by default setting and try to take out tape if is there inside.
Apr 09, 2008 | Panasonic NV-DS55B Mini DV Digital...
Panasonic S-VHS-C movie camera
1. Take out the tape - AND TURN THE CAMERA ON.
2. press the menu button (near the viewfinder)
3. Use he wheel on top next to the viewfinderto scroll through the choices
4. Choose "display setup" by pushing the wheel in
5. Choose "C. Rest" by pushing the wheel in
6. Turn camera off
7. Next time you turn camera on you should be able to view tapes and record.
IT DID NOT WORK THE FISRT TIME SO I PUT MY FINGER IN TO TRY TO GENTLY PUSH BUTTON WHEN I TOOK THE TAPE OFF AND THEN TRIED SOLUTION ABOVE AGAIN, AND THIS TIME, IT WORKED. BUT PLEASE DONT INSERT YOUR FINGERS IN AS I DID TRY THE SOLUTION 2 OR THREE TIME IT SHOULD BE OK, HOPE THIS WORKS FOR YOU,
THANKS
CREDIT TO LABBER
Feb 16, 2008 | Panasonic Palmcorder PV-DV53 Mini DV...
F02 error in Panasonic vedio camera
Hello.
F02 error code means tape slack. If you have a separate deck try winding the tape all the way to the end and then rewind it back to get the tension up. Or if you are able to do it in the camcorder then do it this way.
Nov 30, 2007 | Panasonic NV-VX77 Camcorder
Hints
it is general fault in this camcorder get a clean path tape and you may get better work regards
Apr 25, 2007 | Panasonic NV-MD9000EN Mini DV Digital...
Panasonic NV-GS30
please check Video head tip, if it is OK. Clean Video head with Head cleaning cassette. If Head tip is damaged head to be replace. thanking you & best of luck.
Nov 18, 2006 | Panasonic NV-GS30 Mini DV Digital...
My video camera is lock 'cause i select VCR OFF from menu
YOU WILL CONTACT TO NEARER  MECHANIC IT IS TECHNICAL PROBLEM
Oct 19, 2006 | Panasonic NV-DS50EN Mini DV Digital...
Stopped working
Seen loads of these problems. Some get fixed by simply using panasonic tapes, some require cleaning with some alcohol, including the head(cleaning tapes clean only head, not the rest of the mechanism), some by tapping, some by smacking, some take out the battery and put it back, and some are stuck with it ;[ Try finding out what the error code is and post back. To get the error code, you need to hold down the fade/stop button and the record button for 3 secs, the error code should be displayed in the viewfinder, in the top right hand corner. Good luck
Jun 02, 2006 | Panasonic NV-GS30 Mini DV Digital...
Panasonic NV-EX3EN Mini DV Digital Camcorder Logo
698 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
