FixYa.com
Tags:
GE Monogram ZV1050SFSS 42
Halogen Lights Failing (by 5 users)
posted by GregH on Mar 28, 2007
I am an appliance salesman for a locally owned business in my city. I sold this hood to a customer of mine that has been having problems with the halogen lighting. Initially the lights just quit working. Three seperate service calls were made to repair the problem. Each time after the lights failed shortly after. The whole hood was replaced and two days later the lights failed again. There have been no problems with the vent motor at all, only the lights. Any feedback would be much appreciated. Thanks!!!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by Guest, posted on Jul 23, 2008
two of the 4 blubs do not work. They were replace but no luck.
Comment by GE Victim, posted on Mar 13, 2008
I have the same problem. I installed the GE Monogram ZV1050SFSS 42" hood, and the lights and fan worked great for a week. Then, after 8 days of use, the lights quit working. I had a GE repairman come out and examine the hood. The bulbs and fuses were checked and were all OK. The repairman replaced the circuitboard and the transformer box. The lights then worked great for about 10 days, before quiting again. The repairman has now been out four times. I am currently negotiating with the GE Chairman's office to have GE replace the entire hood. It is still under warranty.
Comment by Guest, posted on Feb 09, 2008
We are having the same problem with our 2 years new hood. All of the lights started to flicker about 1 week ago (they'd get bright and then dim) and today they don't come on at all. Must say that we've been pretty unimpressed with our complete kitchen purchase in general. It took almost 1 year to get our Monogram refridgerator to the point where we don't need to call the service dept. every month. Sounds like that is what we'll have to do again....
Comment by Guest, posted on Jan 09, 2008
We replaced the bulbs and it still doesn't work...None of the lights work. It is only 2 years new.
Clarification Request
by tormeycarol, posted on Jul 23, 2008
two of 4 lights stopped working - the two lights were replaced - no luck??? Help
Best Solution
posted on Mar 28, 2007
Helpful (85)
Noggin
Rank:Guru Guru
Rating: 87%, 1462 votes
If the hood is on the same circuit as the range / cooker then maybe there is a power surge when the cooker is turned on or off, or possibly a low voltage when the cooker is running - that will often damage halogens - try wiring the hood totally seperate.
Unless there is a similar generic fault with both hoods, power supply has to be the problem. (I am guessing that the bulbs were the right ones).
Hope this can help :)
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Kitchen Hoods problems?
Kitchen Hoods
Need to replace main control...
I know the circuit board is bad... Answer This...
Kitchen Hoods
Light bulb socket replacement...
Hi, I'm really having a tough... Answer This...
Kitchen Hoods
STIHL BLOWER MODEL BG-85
do you have a link to a parts... Answer This...
Kitchen Hoods
attic roof vent fan- brand...
put a new motor 3.4 amp 1050... Answer This...
GE Monogram ZV1050SFSS 42" Island Chimney...
vent aluminum cover inside duct
In a newly installed hood-- a... Answer This...
Repair Service
Find Kitchen Hood Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
