Question about Dacor DMT2420 1200 Watts Microwave Oven
I got a ewave microwave from a friend, and installed it, set it for 4 min. and then tried the light for the range the power to the microwave shut off. I thought it might be the outlet that I installed for it but that was not the prob. waited awhile and pluged back in it work and again I did the same thing and again It shut off, It also smells like it is burnning like a furnace would and get real hot. In not sure what to do now, my friend said they never had a problem. please help
  • Dacor Master
  • 9,098 Answers
I see (and repair) this a lot. The problem is on the controller assembly, which I regularly repair. Details are here.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Posted on May 28, 2017
MicrowaveSvc
  • 9098 Answers
SOURCE: tappan microwave over the range tmv151f
You can download your owner's manual free here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 08, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Ewave OTR Microwave Oven, Model KOT-153UW. Light
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 13, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: ewave panel is on lock
As per the owner's manual:
The oven operation can be locked to prevent the microwave from accidentally being turned on. All oven functions can be locked.
To Set: Touch and hold the CANCEL/OFF Pad for three seconds. The Display shows “LOCKED” and the oven beeps.
To Cancel: Touch and hold the CANCEL/OFF Pad for three seconds. “LOCKED” disappears from the Display and the oven beeps.
If this does not work, then try a hard reset: Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it still fails, you probably have a problem with the controller.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee. It may cost a little more if you need parts, such as a new keypad.
prototech@usa.net
Posted on Aug 30, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: I have an Ewave microwave/range hood. How do I
Depends on the model number but here are some owner's manuals to check:
HTML clipboard http://www.microwavedisplay.com/KOT131UB.pdf
http://www.microwavedisplay.com/KOT131UW.pdf
http://www.microwavedisplay.com/KOT152UB.pdf
http://www.microwavedisplay.com/KOT152UW.pdf
http://www.microwavedisplay.com/KOT153UB.pdf
http://www.microwavedisplay.com/KOT153UW.pdf
http://www.microwavedisplay.com/KOT170SB.pdf
http://www.microwavedisplay.com/KOT170SW.pdf
http://www.microwavedisplay.com/KOT171S.pdf
If you find that you still have trouble after replacing the bulbs, you probably have a problem on the circuit board.
prototech@usa.net
Posted on Oct 30, 2009
SOURCE: E-Wave over the range microwave has blown main fuse
My Ewave has stopped heating eventho it appears to be running. Is is possible the power has been reduced or does the microwave need to be replaces
Posted on Feb 17, 2010
Ewave microwave
Over the range microwaves are generally the same as far as the rear dimensions but you will still need to install new mounting brackets and drill new holes in the cabinet. Each brand is slightly differnt in its mounting.
Nov 25, 2013 | Microwave Ovens
My ewave microwave oven fan keeps running will not shut off unless power is unplugged
Sorry to read about your problem, I hope this helps you out.
you have a defective fan relay switch
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Microwave Ovens
How to replace the door handle on an Ewave KOT 170SW Microwave
Ewave KOT 170SW Microwave, it starts runs for a few mins. then stops. Shorter then time set for.
Dec 10, 2009 | Microwave Ovens
Nov 16, 2009 | Microwave Ovens
prototech@usa.net
Oct 29, 2009 | Daewoo Microwave Ovens
Sylvania microwave convection oven overheats after
you need to remove the cover and after it operates and shuts down(CAREFULLY) feel the magnetron tube sides (BE EXTREMELY CAREFUL<HI_VOLTAGE ON TUBE FROM CAPACITOR) still, then if its not too warm there is a small temp sensor held by 2 screws on the side of the tube and they can go bad and shut off current to the tube,the tube will run warm, but should never run HOT,if its hot its defective
Oct 28, 2009 | Sharp R-353 Microwave Oven
prototech@usa.net
Jul 13, 2009 | Daewoo Microwave Ovens
Dacor DMT2420 1200 Watts Microwave Oven Logo
664 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
