Question about Aprilaire 600 Humidifier
Aprilaire 500 - Everything works, but humidity will not increase!
I've got a brand new home (2 months old).  Had the 500 model installed about a month ago.  I am not using the controller supplied by Aprilaire.  I am using a white-rodgers thermostat that has the ability to control humidifiers.
Originally, my contractor wired it in a way that the water solenoid would only be powered with a heating call from the t-stat.  I thought everything was working fine as the RH was more or less hovering around my humidity setting of 38%.  It would fluctuate 30-39% daily.  Now thatthe outside temps have dropped to about 20 degrees fahrenheit (-7 celsius) my RH is around 21-26%.  I suspected that the furnace was just too efficient and didn't give the humidifier enough time during cycles to make a significant impact.  So I had my contractor re-wire the system so that the humidifier could run indepedant from the heat call.  The white-rodgers t-stat has a feature in which it can trigger the water solenoid AND the blower together on a separate call.  With the setting still at 38%, and the ambient being 25%, I had it run for a good week with no significant increase.
I then contacted Aprilaire.  They suggested that I switch the water source from the cold line it was currently connected to, to the hot water line.  The rep I spoke to said that the system needs heat (despite what the owners manual states).  Whether from the furnace or the water, it needs heat.  Had the water lines switched the other day and still no change.
So as it stands right now, the t-stat has the fan and the water going 24/7 since the humidity level is not being reached.  I have verified that the t-stat does works, the blower fan and humidifier are being triggered, the solenoid is powered and running the water, the water is entering the water panel, and the water is also draining. Just can't get the humidity level up!  My house is brand spanking new.  2170 sq.ft and from what I understand the 500 should have no problems with a house this size.
Can anyone help me out with this?  I am all out of ideas.
Thanks in advance!
  • Stephen Evans May 11, 2010
    Is the humidifier mounted on the slpy or return duct. also i hate to say it but you should use the aprilaire humidistat, mounted to the duct. It sense humidty much more accuratly that way
  • 30 Answers
You should take out that aprilaire and throw it in the garbage or return it to who you got it from. Ask them why they didn't offer you the best humidifiers available. The only way to truly control humidity in your home without running your heat is a steam humidifier. Autoflo makes a good one also honeywell makes a new one. I have installed a honeywell tru steam in my own home and a few customers it hasn't lived up to its advertising. The auto flo has never given me any problems with customers.
Posted on Jan 05, 2009
I have an aprilaire model 6303 control panel, and the B and G terminal lights are on, on the equipment output and the fan runs continously. Is the board bad or what please help
[PDF]Aprilaire® Zoned Comfort Control® Product Guide
ftp://ftp.aprilaire.com/...Control/5050_ZCC_productguide.pdf
AprilaireAprilaire Model 6303 Control Panel ... with the Model 6504 Intelligent Zoned Comfort system, we have the right control for your ... A control panel coordinates the operation of the equipment with the ..... Proper control of the fan (G-terminal) for either electric.... Auxiliary output relays available to control humidifiers, electronic.
[PDF]Safety & Installation Instructions - Aprilaire
ftp://ftp.aprilaire.com/Fulfillment/Inbox.../6404_install_guide.p...
AprilaireModel 6404. Zoned Comfort ... Do not mount the control panel on any part of the heating/cooling equipment or ... allowing for control of a humidifier. b. HUM LEDlights when the relay is closed. .... on the fan (G output terminal) with a heat call (W1output ..... Run wire between the HVAC equipment and the control panel. 3.Missing: 6303
Jan 20, 2016 | Aprilaire Humidifiers
Model 800 Aprilaire steam humidifire I have
Follow manufacturer instalation instructions. Why risk your equipment and you family's health to save a few bucks and a lil trouble on the proper parts. Your family is worth it, now go do the right thing. :)
Jan 24, 2011 | Aprilaire 550 Humidifier
I have an old Aprilaire 550. Can't get the humidity to desired level of 40-45% humidity, only 36-39%. Is there anything I can do. Water is very hard in my home could this be the reason why water isn't...
Sorry to read about your problem, I hope this helps you out.
You are at the limit of what the unit can do.
One little thing you can do is see if the unit is hooked up to hot water instead of cold water.
OUTSIDE TEMPERATURE RECOMMENDED SETTING
-20F -29C 15%
-10F -23C 20%
0F -18C 25%
+10F -29C 30%
+20F - 7C 35%
+30F - 1C 40%
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Aprilaire 550 Humidifier
I purchased a home with a aprilaire model 224. How do I know if its working?
Here is a link to the owners manual. http://www.aprilaire.com/themes/aa/en/manuals/Humidifiers_Owners_Manual.pdf
You can also pickup some cheap humidity gauges at a hardware store to check the settings on your unit verses the actual humidity in the house.
Dec 19, 2010 | Aprilaire Humidifiers
Aprilaire 700. It works on fan on mode but not otherwise. It's never on and the humidity reading is always way below the setting. It should turn on automatically to bring the humidity up, right?
It appears your Aprilaire model 700 is wired to only operate when your HVAC fan is operated by your thermostat. Your HVAC installer can wire the humidifier control to operate the humidifier during a heat call, fan call or to turn on the fan when there is a need for humidification. Please contact your HVAC installer to have them change the wiring.
Thank you for giving us the opportunity to be of service
Sincerely,
Brad Uselmann
Technical Support
Research Products Corporation
www.aprilaire.com
Nov 01, 2010 | Aprilaire 700 Humidifier
What controls how much water flows into an Aprilaire 550? It was fine until a couple of days ago. I replaced filter, but it still appears to be too strong. It not only runs out the drain tube but is...
In the water line where it connects to the solenoid is an orifice. You can install a smaller plastic orifice or you can install a manual feed valve to where you can control the flow.
Feb 12, 2010 | Aprilaire 550 Humidifier
Our Aprilaire is over 14 years old. Two
If your humidifier is working properly, then the problem lies outside of the humidifier. For example how long does your furnance run when the thermostat calls for heat? If your furnace is oversized for your home, it will heat your home relatively quickly, and turn off, while your humidifier does not have a chance to work long enough for it to increase the humidity. If this is the case, you could try to set the thermostat to run the fan in manual mode instead of automatic. This will give the humidifier a chance to increase the humidity.
Hope this helps.
Jan 08, 2010 | Aprilaire Humidifiers
Aprilaire 600 Humidifier Logo
528 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
1STHVACMAN
Doug
Level 1 Expert
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
