Question about RCA HD52W59 HDTV Projection Television
I need to replace FL231 fuse.
Do I need to take the entire back off. And where is the flyback located.Can I lie the set screen down to repair it. RCA Model 52W59 rear projection t.v
  • RCA Master
  • 5,138 Answers
Yes you must take back off and NO do not lay set over! POwer/deflection board is first board on bottom to left on right side bottom SSB board. FL231 is located on right side of FBT it has 2 wires coming out from it red/black(3) fuses look like small brown caps right in a roll it will be the middle fuse
Posted on Dec 18, 2008
My mom has a RCA HD61W66 and the picture was showing red, blue and green "lines and shadows" as if the picture was warped. It has now stopped showing a picture at all but the power is working....
The flyback transformer has solder cracks around the pins and most likely blown the FL231 Micro fuse to the right of the flyback.I would inspect the flybacks solder. The FL231 and the CL230 and DL231 should also be replaced ( near the flyback) You can get the ITC222 Convergence option missing repair kit from www.tvrepairworld.com under the RCA repair kits. The kit contains the parts and the CD with repair instructions
Sep 15, 2011 | RCA HD61W66 61" Projection HDTV
Convergency has gone out of sync, went to try to realign but the convergeny setting was not listed in the tools menu.
Thats usually caused by a blown FL231 Fuse and a blown DL231 diode that blow when the flyback transformer develops solder cracks around the pins. The repair is to first resolder the flyback then replace the FL231 fuse and DL231 diode. You can get the RCA / GE convergence option missing repair kit which has the parts and repair instructions from www.tvrepairworld.com
Jul 09, 2011 | RCA HD61W66 61" Projection HDTV
Wont turn on after replacing FL231 fuse on a RCA HD52W59
If you replaced the fuse alone without installing the other components that are rquired to repair that issue the new fuse can allow voltages to flow trough the diode in both directions which can prevent the set from firing up. You need to replace the FL231, DL231 and CL230 as a set then reflow the solder on the flyback and vertical IC.
Dec 04, 2009 | RCA HD52W59 HDTV Projection Television
Picture is 3D like with green, red, and bules lines at the top of the screen. It is also cuvred on the top, and bootom of the screen?
Your has probably blown fuse fl231, causing your convergence to go out. This is often a sign of a bad power supply. The fuse is located right next to the power supply. Replace the fuse and check flyback for bad solder joints. I fuse blows again, replace fuse and flyback transformer.
Oct 12, 2009 | RCA Televison & Video
I replaced the fl231 fuse in my rca HD52W58 and it went back out
Had the same problem , you have to resolder the flyback before replacing the fuse.
Jun 25, 2009 | RCA HD52W58 52" TV
I have a RCA HD 52in and I'm have a problem with the Convergence Ic's
Hi, rca`s don`t have convergence IC`s, they use an entirely different system to perform convergence, you have a blown chemical fuse and 3-6 bad solder joints on your flyback transformer. replace fl231 chemical fuse rated at 400ma. right beside flyback (theres 3 of them your bad one is the middle one)and while your soldering re-solder all of the flyback transformer pins and your tv will be back to normal :) video-tek
Jun 04, 2009 | RCA R52WM24 52" HDTV Projection Television
NO POWER rca hdtv R52WH74YX61
if the fuse you took out at first was fried black as cool, how do you know it was .6a
now the fl231 as I told you before is close to the flyback transformer
Go to google search -type in flyback transformer --enter
scroll down to get video results for flyback
click on the picture
now you will see what a flyback looks like
you should not try to fix tv if you have no idea of tv repair.it is very cmplicated and fatal .there is serious high voltage in tv sets
Nov 23, 2008 | Televison & Video
Rca tv
i assume you speaking of the fusable link that causes the convergence problem... IF the convergence option is not visable in the setup menu. then possibley FL231 is the problem this is a small rectangular fuse brown or tan in color. this is located on the deflection board on left of the set from the back. there is a large black component with a large wire coming out of the top. this is the flyback.. to the right of it on the board is three small rectangular componts brown or tan in color. the fl231 is the middle one of these. the curcit board has index markings like a map these components are located in Q5 Quadrant. When replacing this rember to resolder connections on flyback(that large black thing with wire out the top) This is why the fuse blew to begin with
Jun 08, 2008 | RCA P52937 52" Rear Projection Television
Broken d52w19
Hi ,here is some of the tips found on www.repairworld.com no convergence- replace fuse FL231 near flyback or in front of flyback also solder flyback pins alot of these sets have poor connections,they are having alot of trouble from ribbons that connect from bottom tuner broad going to convergence broad also connectors that ribbons plug into so far there is more infor on the HD52w59 .The next set i get in my shop the first thing is to solder power supply broad,then see what happens so far the 2 sets i have now i havent been able to fix,but im not quiting untill i fix them or throw them back to customers.
Feb 03, 2008 | RCA D52W19 52" Rear Projection Television
RCA 52w59 projection fuse fl231
Instead of taking the board out, I just soldered two wires to the old fl231 fuse on the underside. Installed a fuse holder with a half amp fuse. And I re-soldered all of the flyback points. My tv is working like new. thanks for everyone's help.
Dec 28, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
186 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
