Question about Roper REX4634KQ Electric Dryer
ONE OFTHE CONTACTS KEEPS BURNING AT ELEMENT
ON ONE THE CONTACT FROM THE ELEMENT THE LEAD COMING
FROM MOTOR TO THE ELEMENT KEEPS BURNING THE WIRE
RIGHT AT THAT CONTACT I KEEP TRIMING THE WIRE AND
RE CONNECTING IT TO THE ELEMENT CONTACT.
  • 198 Answers
You will have to replace the heat element, because the male terminal is burnt, which causes too much heat at the connection, and causes the wire to burn. If you can clean the terminal to where its shiny it may work otherwise replace the element
Posted on Jan 19, 2009
I have an Amana dryer model number ned7200tw and a wire keeps burning out but what is causing that to happen
wires that burn out are caused by bad connections at one end or the other. The resistance becomes too great at the connection and the wire becomes an element.
Make sure the wire is clean and shiny and that the connector makes good contact with the wire, and the connector itself makes good contact with it other contact.
You could also replace the wire with a slightly heavier gauge
Jan 26, 2016 | Amana Dryers
I HAVE 7.5 HP VERT 80 GAL TANK COMPRSSOR IT KEEPS BURNING CONTACTS ON PRESSURE SWITCH. CONTACTS STICK TOGETHER AND COMPRESSOR WON'T SHUT OFF AFTER REACHING PRESSURE. WHAT'S CAUSING THIS?
There is a capacitor across the contacts
To absorb the inductive collapse if the motor.
But this problem usually only happens to DC motors not AC.
If the starting Cap has 2 leads I'm stumped if it has 3 leads replace it.
Apr 22, 2015 | Air Tools & Compressors
The thermostat keeps burning
Check for loose wiring connections between the t-stat and the elements. Sometimes it will melt the wires, sometimes it will burn the contacts inside the thermostat.
Mar 08, 2013 | Vulcan Hart Vulcan EV24-S-4FP208...
The stove is 26 years old. Has been working very well. Now the two heating elements on the left side of the stove and oven are not working. The pilot lights come on. Fuses in good shape and 220 volts...
check the contact points on the rear of the element they burn off after years of use, if the contacts are still good, Look at the element itself for any white marks on the element, if you see any , the element itself has probably burned out and need replacing , to get to the contacts,, depending on the oven, remove the back they should be right in sight , if you do need to replace the fittings on the wire ends, be sure and get heat range connectors
May 29, 2011 | Ovens
Machine Fills up perfectly. Then trips electrics when it starts the cycle. Have checked plug, and changed extension lead-all OK. Have taken front cover off and pump is OK, no water leaks at all, also have...
Sorry but it could be internal wiring/plugs sockets, control panel switches, control PCB but the main motor is probably the primary suspect, I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Mar 29, 2011 | Speed Queen Washing Machines
My miele microwave is blowing the house fuse once pluged in to power point. Any idea why?
Their is a live wire which contact to the metal body so it contact to the earth cable. This can be by a loose wire, a burn heating element or a burn motor. All the above can lead to direct contact of alive cable mean power cable to earth so the house fuse which is the earth protector is driping off.
Your oven definiatly need to be open and check by and electrician.
Good luck
Jul 26, 2010 | Miele H147MB Convection/Microwave Oven
Dryer turns on but no heat, I don't have the manual so not sure about how it works, there is a swicth that says "air fluff, heated dry & timed cycles" I have tried turning this but nothing happens.
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check element, timer , thermostats and safety switch on motor (check wiring diagram for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element
Aug 07, 2009 | Bosch Axxis WTA 3500 Dryer
My dryer throws cold air not hot?
One of three things can stop a dryers element, from heating up. the big red wire going to the motors relay switch could be burned off,that is on the back of the motor itself. two, the element or the wirers conected to it have bad contacts. three the safety thermal cutout devices, have open circuts do to some sort of blockage in the vent pipe.
Jul 28, 2009 | Dryers
I need a wireing diagram for a king tablesaw model kc10-sc 1 hp
I did some Research and Came up with the King Canada Website, where they Show your Table Saw. You may wish to go to that site, and Click on "Contact Us" and send them a Request for the Proper wiring of Their 220V Motor...Here's the Link for Their Site:
http://www.kingcanada.com/Products.htm?CD=101&ID=644
As far as a 220V Motor Wiring goes, 3 Leads works since you have 2 Hot Leads(Black & Red), 1 Neutral Lead(White). as Far as a Capacitor (probably 2 Black wires) goes That should be Pre-Wired into the Motor coming off the Lugs for Your Wiring to...Should NOT be a 2-Stage Motor Connect to, but you may be referring to a Mag-Starter(sounds to me Like someone was trying to do Step-down Voltage)
In all Honesty "IF" I were you, I would do the "Contact Us" @ the Link I Provided, and Let King Tell you How They Have Their Motor Wired for Your Application. Good Luck. Let me Know How you make out.
Mar 15, 2009 | Saws
Maytag electric dryer model DE410' Dryer motor runs normally and freely; N0 HEAT is produced by the dryer element. electric heat element presumably is not working. Cold air is emitted from the exhaust....
check all of those "relays", htey are thermostats, monitoring you temps, they should all have continuity through them if not its bad. (temp jump it out) just to see the element glow. TEMPORARIly.. you CANNOT leave any jumped out you will damaged something. HOUSE FIRE. just wanted to instill the importance of not leaving jumped out
Mar 23, 2008 | Dryers
Roper REX4634KQ Electric Dryer Logo
204 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
