Question about Zanussi TC7114W Electric Dryer
ZANUSSI TC7103W My Zannusi dryer will not dry clothes, i have removed the heater elemnt and it is ok, but dryer stillblows cold air, Could you please advise, If it is door thermostat can you please tell me were i could locate it ,thanks
  • 2 more comments
  • David Seddon
    David Seddon Apr 04, 2007
    previous guest told me it was a door stat, which i have replaced, dryer is now working ok,
    wanted to know were the stat was located.
    i stripped the machine down & removed the drum,the thermostat was exposed with the drum removed in the plastic holder behind the door.
  • chrisquest Sep 15, 2008
    I have zanussi TC7114W condensor unit dryer. All works, but machine does not blow hot air (cold air blower works)
    How do I test thermostat or heating element
    Tha
    Christo
  • dave plumber Nov 16, 2008
    i have zanussi 7103 s and it only blows cold air could wen drying could i have the same problem if so would termostat be in same plase
  • benny51 May 11, 2010
    Yes on the TC7103W the t-stat is built in to the heater unit, changed my whole unit still did not work
There is a thermostat inside the machine just inside and top, put your head in and look up. Took my whole machine apart before finding the wire which led to it!! It should be Normally Closed (NC) and cuts the power to the heating element when too hot or broken! Hope this helps.
Bolts
Posted on Mar 15, 2008
Check to see if their is a t-stat on the heater. if not the heat check on the blow housing. its definately a t-stat. im not to familiar with zannusi dryer but it definately is a t-stat.
Posted on Mar 29, 2007
2003 nissan sentra is blowing cold air i changed thermostat stillblowing cold air i did notice that heater core hoses are both cold car is not overheating
remove both hoses from engine that passes through firewall to heater. put a stiff piece of wire in the hole and make sure it is clear. If there is no restriction, then the heater is choked up
Jan 17, 2013 | 2003 Nissan Sentra
No heat from my tumble dryer
There should be 2 limits mounted above the heating element on back along with a limit mounted on the heating element. I have some repair video: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 16, 2010 | Zanussi TC7102W Electric Dryer
Zanussin tc7103w not drying clothes
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 17, 2009 | Zanussi TC7114W Electric Dryer
Zanussi TCE 7276W taking ages to dry.
make sure your dryer vent is not gloged all the way to the outside first befor you do anything else,take a air hose and make sure you have ventilation. hope this helps
Jun 12, 2009 | Dryers
My Kenmore 70 series is blowing only cold air. Any ideas how I can fix it myself? $ is really tight. Thank you. MB
open door and feel the inside at the top and remove the 2 screws, there is a little heating elemnt attached unplug it then replace it, its not a deer part to buy
Jan 31, 2009 | Zanussi TC7102W Electric Dryer
Zanussi Tumble Dryer Model TC7103W ** Heat
have u changed the thermostats if not change these these r what let the heater element get warm if this then works then the element u changed will more then likely be OK m8
Mar 10, 2008 | Dryers
Zanussi tumble dryer model TC7103W ** heat, machine runns ok, changed compleate heater unit including thermostat.
it could be the timer what sometimes happens is a wire can burn out or have a break in it have had some dryers do this to me and have had to change part of the wiring to fix the customers dryer
My zannusi dryer is will not dry clothes on hot setting
thermostat in door part no 1258406014 should do the job colin
Mar 06, 2007 | Zanussi TC7114W Electric Dryer
Zanussi TC7114W Electric Dryer Logo
738 people viewed this question
Top Zanussi Dryers Experts
Marvin
Marvin
jb_ab1
jb_ab1
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
