Question about Refrigerators
Puddles of water in Fridge
I have a 7 year old Kenmore Refridgerator that is leaking large amounts of water inside the Fridge. I have vacumned the coils and have arranged the food inside so as not to impeed air flow. I also cleaned and inspected the ''Drip'' tray under the fridge. There appears to be ice crystals on the duct type thing on the inside, on the rear of the fridge. Some small fozen drops are also on the metal areas on the top of the inside.I have turned off the ice maker and still am getting water puddles in the bottom of the fridge. They are 1/2'' deep and fill the bottom of the fridge
You may want to check your door seal, air leaking thru the door seal causes condesation,also make sure that the drain tube is clear under the defrost element in your freezer.
Posted on Dec 18, 2008
Mw Daewoo fridge freezer FRS-20321BE is leaking water copiously from the refrigerator I cannot see any source for this but puddles form and flow internally under the veg box. Help!
All depends on how much water is collecting. A lot of water indicated a leak from the ice maker. A small amount and it's probably a clogged condensate drain. Here's a YouTube video on a different brand showing a clogged drain, your may be similar (or not), but it might give you an idea as to where to look. Refrigerator dripping water inside FIX
Mar 07, 2016 | Daewoo Refrigerators
Water on the inside floor of the refridgerator,
remove back panel from freezer and unglog hole where it collects water. its glogged
Feb 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
Whirlpool, water puddles on top shelf of fridge
If it is not from a plugged or misaligned defrost drain tube, then it is always from air leaking into your refer section. Check you door gasket to see if it is sealing correctly all around your door. Make sure your door is shutting tightly every time. Good Luck, Appliance Specialists.
Jan 17, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water in Leaking in the Freezer
Hi, this sounds like a problem with a blocked drain. For full instructions on clearing the blockage from my tips click HERE if you have any other questions please feel free to comment. Mike
Dec 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Refridgerator leaking water into refridgerator compartment from freezer compartment
You most likely have a clogged drain. When you freezers goes into defrost every 8 to 10 hours. The frost that is melted during the defrost drains from the freezer either down through the fridge or out the back and down. Either way it drains into a pan under the fridge. This tube is either clogged or the drain it's self inside the freezer is. Most of the time I find peas stopping the water from draining from the freezer. When the water can't drain it leaks through the bottom of the freezer into the fresh food section of the fridge. You will need to fix this because it will cause other problems. The water that cant drain from the freezer refreezes and will end up destroying the foam in the bottom of the freezer. Water will also leak onto the controls located in the part between the freezer and fresh food section ruining you controls.
Please rate this solution
Sep 01, 2009 | Kenmore Refrigerators
Water inside refrigerator
Even though it doesn't seem like it's coming from your freezer, morre than likely that's where it's coming from. At the back of the fridge there will be a drip tray that actually catches the water from the thawing freeze. One way to avoid access water is to simply turn down your freezer and fridge. Usually if they are number 0-10, both frigde and freezer should be set on the 5 level.
Aug 31, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
My refridgerator leaks water every two weeks
check to make sure the drain pan is in the right place. If it puddles up inside the bottom of the fridge first, your drain hole is plugged up. for this, you wil have to remove the access panel in the back of the freezer side to get to the drain hole. you may also have a crack in your drain pan.
Aug 11, 2009 | KitchenAid Superba Architect KSCS25INSS...
Soleus A/C unit is leaking water out of drain plug
it is working well, possibly has a bad sensor to tell you it's full but put a permanent drain on, run it in the sink or dump it more often. just means it's pulling out excessive amounts of moisture
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Nov 03, 2017 | Soleus KY-34 Portable Air Conditioner
Fridge does not stay cold
If the compressor is running continually, could be short of gas , or a compressor problem, ie not pumping properly,make sure it has plenty of ventilation
Dec 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Leaking inside of fridge
i guess u will benifit from this link
plz rate this post
click here
Sep 02, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
387 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
