Question about Magic Ice Cream Makers
Magic Chef Ice Make does not make ice
Magic Chef – Model MCIM30SST
Ice Maker heats water up instead of making ice. Inside of Stand alone Ice Maker gets warm and water gets pretty warm after about 12-14 hours. Ice Light never lights up but add water light works and Ice Maker even fogs up the clear window inside on top of the machine due to the heat and humidity.
Pump does work and puts water in tray and ice machine goes through cycle but no ice. As I said inside of ice machine gets warm but appears to go through all cycles normally except make ice. I have taken Case off Ice Machine. I also can hear compressor kick in and run for 5 minutes or so and then cut off. Also I have heard compressor kick back in when you open lid for a few minutes.
Would sincerely appreciate any help.
Thanks, Rich
voodoomox
  • 1689 Answers
SOURCE: Magic chef ice maker model MCIM30TW
have you checked on the fuse and the thermostat of the appliance, because aside from the cooling system, you may want to check on the easy parts first.
i will go further on this, will keep you updated if in case i find more.
Posted on Aug 11, 2008
SOURCE: Polar Ice Maker Portable
there is a little sensor inside on the top right, it is a little wire if there is anything on it it will not work, i took at small pair of pliers and gently cleaned it
Posted on Mar 06, 2009
  • 30 Answers
SOURCE: no accumulation of ice
Check to see if your condensor coil is clean, use an air compressor or other source to blow thourgh the coil,dont just brush it off. newer refrigerant charged systems need as much air flow as possible to work ,also make sure the cover is on the condensor section while the ubit is in nrmal operation. try setting the cube size to lowest setting and let run for 24 hrs. Let me know if you need further assistance.
Posted on Mar 07, 2009
  • 4 Answers
SOURCE: Musso Ice cream maker freezes and then heats up during use
go to Http://www.catering-machines.com they have full list of spares or parts for Musso stella.
All parts for the musso ice cream machine including lid, motors, gear wheels, gearbox, musso paddle Musso serial numbers start L1 = Musso piccolo L2 = Musso stella L3 = Musso Club L4 = MUSSO CONSUL.
Posted on Jun 04, 2009
proartya8765
  • 581 Answers
SOURCE: Need instruction or manual for the Magic chef ice maker model
Hope this helps. This is the link where you may be able to download
http://www.partselect.ca/Search-Suggestions.aspx?term=MCIM30TW
Posted on Nov 23, 2009
I need to order aice shovel for my magic chef tabletop icemaker model #MCIM30TW
try this page - I have a similar model (MCIM30TS) - however, I can't figure out how to remove the pins to remove and replace the ice shovel...any ideas?
http://www.repairclinic.com/Shop-For-Parts?searchText=mcim30ts&Search=Find%20Parts
In case the link does not work properly, just go to the repairclinic.com website and enter your model number in the search box...
hope this helps
- Margaret
Sep 15, 2010 | Eastern Tabletop 7002 Stainless Steel 24...
Nov 22, 2009 | Magic Ice Cream Makers
I need an instruction manual for my Deni 5000 ice cream maker
Are you looking for operating instructions or reciepts?
Find receipts via Google.
Operating instructions:
place the mix into the can with the paddle inside. Place the can into the bucket. Attach the motor or crank as appropriate.
Crush some ice (aboout 5 pounds) and pack about 2 inches around the base of the can with the can in the bucket. cover this ice with rock salt. Put two more inches of crushed ice on top - spread more rock salt (the smaller the ice, the smoother the mix). Continue this process until you are at the top. Make sure the drain is clear, start cranking (or motoring. When the motor stops, unplug it. Cover all with a heavy towel for about 30 minutges (if you can stand it) If for some reason the motor doesn't stop - you didnt put in enough salt. Expect to use about 1/2 of a 5 pound bag.
Remove the towel - the motor - the top - the paddle. Give the paddle to the kids with a couple spoons. Dig in for the adults.
I sometimes add a quart of water but you dont have to.
The ice makes the water cold - the water provides the freezing power, the salt lowers the freezing point of the water - the extra water might speed the process a little bit ... maybe not
Enjoy your delicious home made ice cream.
(BTW - the paddle does not move ... the can spins around the can causing mixing.
a
Oct 14, 2009 | Deni 5000 Scoop Factory 1.5 Quart Ice...
Wanting to make less than the 5 quarts that it holds, do I just reduce the recipe to the 2 quart instructions, will it freeze with that much less?
Why would you want to do all that work for LESS ICE CREAM???
In my experience, your ice cream maker will make any amount of ice cream up to its capacity. Remember, it is the salt that is the magic ingredient here ... that allows the ice water you are creating to get colder than 32 degrees F. Ice isnt really cold enough to freeze the mixture.
Sep 07, 2009 | Rival 8550-X 5 Quart Ice Cream Maker
Magimix Ice cream maker - Le Glacier - lost instruction book
Magimix 2200 Gelato Chef 1.03 Quart Ice Cream Maker Support Magimix 2200 Gelato Chef 1.03 Quart Ice Cream Maker Support. Manual for ice cream maker ... Need Instructions/User Manual. Magic chef ice maker model MCIM30TW ... fixya.com/support/p519941-magimix_2200_gelato_chef_1_03_quart_ice/rss
best regards mike
Aug 17, 2009 | Magimix 2200 Gelato Chef 1.03 Quart Ice...
My newair A1200ss stopped making ice. i tried recycling the unit and it has ample water, but the ice tray just stays in the down position. thanks.
I have had the same problem with two different portable ice makers, the ice tray inside is broken so you will have to send it to them and get it fixed. Hopefully eventually they will make the tray out of a stronger plastic.
Nov 29, 2008 | NewAir AI-200SS Ice Cream Maker
Magic chef MCIM30TS table top ice maker shovel breaks
I took 4 small nails, cut them to the proper length, heated them up with a lighter, and pushed them into the plastic creating 4 metal posts that the motor could push against. Just did it and it is working. Not sure for how long.
Nov 21, 2008 | Eastern Tabletop 7002 Stainless Steel 24...
Aug 11, 2008 | Ice Cream Makers
Go to this link:http://www.magimix.com/index.php?rid=60&cid=990&lg=502 and click on "Instructions for use" above the picture. Then download the pdf file. Its free and in English!!!
Enjoy making ice cream!!!
Jun 23, 2008 | Magimix 2200 Gelato Chef 1.03 Quart Ice...
Jun 21, 2008 | Polar PIM15W Ice Cream Maker
Ice Cream Makers Logo
200 people viewed this question
Top Magic Ice Cream Makers Experts
Marvin
Marvin
ray gallant
Ruth summersides
Are you a Magic Ice Cream Maker Expert? Answer questions, earn points and help others
