Question about Toshiba 32AF41 32" TV
Toshiba 32" HDTV 2002
I have a 32" Toshiba HDTV i bought in 2002 at Best Buy. I have had it service 4 times in the last 3 years. The last 3 times the power shut off and my local repair man has replaced numerous parts but the problem has occurred again. This is the WORST TV I have ever owned. It now turns itself off as if it blows a fuse. Sometimes after minutes, sometimes after hours. Has anyone else had this problem. I can not justify putting any more money into this TV
    President:
  • 3,130 Answers
The power regulators are famous for going bad. The big problem with this TV set is that unless you use the exact regulator from Toshiba, this set will fail time and time again. Even if the regulator IC has the exact same number, it will not hold up. We used to have a shop that was authorized by Toshiba, and we seen this problem many times when customers would say that they had their TV fixed by some local shop and the same problem occured several times. Good Luck
Posted on Mar 28, 2007
My Panasonic TV HDTV Model PT-56TW53 - 52 inches / 1080i I bought the projection TV in October 2003.
This TV has reached well beyond its normal lifespan for the TV type and size. The new LED/LCD displays are so much better that you will wonder why you haven't replaced before now.
Jun 29, 2017 | Televison & Video
How do you change the time zone on 2007 Toshiba Regza 42HL67?
the manual doesn't mention anything about setting the time, so I am wondering if it comes from the cable or satellite box connected to it.
this is how it is done on another Regza model
Setting the time zone
The Time Zone setup will allow you to specify the
correct time zone for your region. This feature will
allow the TV status information to show the correct
time zone information for your viewing area.
From the SETUP menu, highlight TV Settings and
press T.
Press B or b to select Local Time Setting and press
T.
Highlight Time Zone and press C or c to set your
desired time zone.
If you want to activate the daylight saving time,
highlight Daylight Saving Time.
5
Press C or c to select On and press O.
Toshiba REGZA 46SV670U Owner Manual Setting The Auto Input Feature Setting...
your model manual
Toshiba 42HL67 42 LCD TV Service Manual
Jul 24, 2017 | Toshiba REGZA Televison & Video
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Samsung LN-T4665F 46" HDTV Screen is BLACK - NO PICTURE
I am a Samsung certified Tech, they do have problems but when the LCD screen was replaced and the main board, they sould have replaced the FR board also
Sep 26, 2009 | Samsung LN-T4665F 46 in. LCD Television
Toshiba LCD TV AV500E Turns off then on every 5 minutes
It sounds to me that the Main board is causing the problem. But I would get in touch with Toshiba for a warranty repair. It has a one year parts and labor warranty. It makes it a lot cheaper for the pocket.
Good Luck,
Skyassoc
Jun 01, 2009 | Toshiba 32AV500U 32 in. LCD HDTV
Resetting Screen Resolution
call best buy if you bought it within the last 30 days. they will send a technician out at no cost to you
Feb 27, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
SAME PROBLEM WITH SAME SET! THIS IS A MANUFACTURES DEFECT. LAST YEAR I BOUGHT A SAMSUNG LCD TO HANG ON MY WALL IN BEDROOM TO REPLACE TOSHIBA. THIS TV COST ME $900 IN 2002, WHAT A WASTE OF MONEY! I HAD TWO...
make sure all other applances are ok not a line buffer are spike problem,maybe too high voltage coming for power company check with meter do you have a lot of bulbs going bad
Feb 22, 2009 | Toshiba 32AF41 32" TV
Toshiba 56hm66 New lamp worked last night, wont boot up again
You now have a defective lamp ballast board. It sometimes is the root cause of lamp failures in these sets. The problem here is that Toshiba does not sell the ballast board independently from the larger, more expensive light engine assy. Call Best Buy back and get a servicer out there. He may have to take the ballast board out of your TV and send it out for rebuilding.
michtech
Feb 12, 2009 | Toshiba 56HM66 56" Projection HDTV
32" Toshiba Television suddenly quit working
by the age of the unit it sounds like cold solder connections, on the main board
Mar 27, 2008 | Toshiba CZ32V61 32" TV
Toshiba 32AF41 32" TV Logo
173 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
