-   My oven should self-clean but doesn't!!!-   6458
Aug 05, 2008
-   Is there another way to clean a selfcleaning oven without using this feature? Mine is not working.-   Guest
Jul 06, 2008
-   I used easy off oven cleaner on my Kenmore self-cleaning oven. The next day I started to use the oven, and thr code -F3- cames up twice when I was setting the temperature. I thought I needed to use my curcuit box to reset everything. I did and then the oven door locked and I can open the door. What is the solution to getting my door unlocked so I can use my oven again?-   muriel587
Best Solution
posted on Aug 08, 2005
Bray - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Most manufacturers recommend not using oven cleaner on self-cleaning ovens. Check your owner?s manual for specific details.
We have a self cleaning oven that our maid used bar keepers friend on inside the oven on the bottom...
(More)(More)
We have a self cleaning oven that our maid used bar keepers friend on inside the oven on the bottom - how do we get it off?
Posted. Thank You!
Congrats on your 3 solution. You're helping others! Someone may even thank you with a Testimonial.
I would like info such as a diagram on how to change my sodir pz 330 115 volt pizza oven from 115...
(More)(More)
I would like info such as a diagram on how to change my sodir pz 330 115 volt pizza oven from 115 volt to 230 volts. Sodir has a 230 volt pizza oven i would like to make mine like that one
Posted. Thank You!
I have a GE electric stove with a self cleaning oven. Is the self cleaning automatic shut off or do...
(More)(More)
I have a GE electric stove with a self cleaning oven. Is the self cleaning automatic shut off or do I have to shut it off . How long should it take?
Posted. Thank You!
my oven had 2 be fixed because it would lock and not come undone it was 2 hot when cleaning and the...
(More)(More)
my oven had 2 be fixed because it would lock and not come undone it was 2 hot when cleaning and the plastic inside would melt so can i use canned oven cleaner
Posted. Thank You!
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
