Question about Saniflo 002/005/007 Saniplus Toilet with Macerator Series Pump in White Elo
Hi, I had my sani plus for a year now , the shower doesnt work
However de toilet does, I take it out and cleaned but still doesnt work.
I lost receipt and warranty I been locking everywhere but i cant find it
  • Roscoe007 May 11, 2010
    Hi Im not clear on what your problem is? I take it out and cleaned but still doesnt work ?Thanks
    Scholar:
  • 44 Answers
So the wc works but notthe shower, where the shower connects in on the saniplus is a not return valve which could be stuck in the closed position??
Have you checked thatthe shower trap isnt blocked with hair etc.
If the wc works & the unit is pumping away then the motor is working ok, so it could be a flow switch problem or as i said thers no flow through the shower waste pipe-work due to a possible blockage
Posted on Dec 20, 2008
Sani flow won't empty so shower toilet n sink all fill up
Most likely is the capacitor/condenser that has gone bad, if there are no blockages in the blade or impeller then the capacitor will need to be replaced. The capacitor is located inside the pressure chamber. Refer to the installation manual to locate it and call Saniflo to order the part.
Feb 27, 2013 | Saniflo & Saniplus& Macerator Pump
How can I adjust the water level inside my Saniflo Sani-Plus toilet bowl? There were no instructions with the toilet tank or bowl. Thanks, Eddie
you cant it is set by the bends in side the bowl all toilets are this way it is a trap design that keeps fumes from septic from comming in
Nov 26, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
My saniflo plus is making a humming noise but not draining any water away the sink has filled with water and so has the toilet and shower tray help
My saniflo-plus system is about 12 years old..recently it stopped draining the toilet, etc. I pulled the cover off the pump and checked for blockage and spun the cutter blades...The motor just hums....do I need to replace the entire encased pump assembly?? Help
Jul 07, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Saniflo Plus
Soak it in descaler and cold water for 24hrs then try again (may take 3-4 attempts) or remove pump/motor from the tank, find oval black rubber membrane, should be able to hear click of switch underneath when membrane is pressed, new membrane required if it is not flexable.
Feb 14, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
My sani slim system smells when i use the shower
Your main branch drain or stack is plugged. Call rotor rooter
Sep 25, 2009 | Home
Pumping stopped
Well it sound likes you have 2 problems. 1st is the float switch is set to high,and pump wont come on till it raises higher then tray. 2nd. sounds like empeller came lose from shaft. I hope this help. :)
Jul 05, 2009 | Saniflo & Saniplus& Macerator Pump
Master toilet burps when flushed plus the shower drain smells bad
It is a vent pipe. It will be the one on the roof, closest to the problem. Sometimes, squirrels will drop nuts in it and stop it up. If that is the case, you may need a plumber. It could be partially blocked. You should have a trap on the shower but if there is not enough air for it to vent, it could cause what you're saying. If you don't want a plumber, you can figure out where the vent connects to the pipe, cut in the wall or cabinet, and check it there by cutting into it. Most plumbers have a cleanout that will clean this pipe out though. Hope this helps.
Jul 03, 2009 | Home
Sani-Plus
float switch of level control is defective. replace same with new part
Jun 05, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Sanishower operated for short time and then just went to a buzzing noise - first time operation - any suggestions
It needs cleaning out regularly - at least once a year! We have one fitted to a shower that is used daily. The small amount of hair - that falls out every time hair is washed under the shower - builds up and clogs up the pump. We are on our second pump, the first installed just over 10 years ago, this one is under 3 years old and it already looks like it will have to be replaced.
Mar 03, 2009 | Saniflo & Saniplus& Macerator Pump
Saniflo 002/005/007 Saniplus Toilet with Macerator Series Pump in White Elo Logo
605 people viewed this question
Top Saniflo Home Experts
Paul Carew
David Ellis Rhea
Are you a Saniflo Home Expert? Answer questions, earn points and help others
