Question about Asko Dishwashers
I have an Asko Model 1473/1503 with the word excellence on the front door panel. It is approx 14 yrs old. I noticed that the main switch has been failing and that I have had to giggle it about to latch. It has now completely given up the ghost and there is zero power to the dishwasher. The CB is on . I believe I have to change the main switch but I have no idea how to get at it to remove and replace it. Any ideas?
  • Jeff Dubin Apr 27, 2012
    I have a fire in a 1505, can you call me 800-837-0109 ext 5014? My name is Jeff
  • 679 Answers
Call these guys, ther may be a diagram on their site, but I have called them several times in the past and they knew almost immediatlly what I needed and sent it right out. These dishwashers are like toys they all snap together, you may have to remove the front panel, but it's just a ,matter of a dozen or less screws, and the switch more than likelly has two more in it, it's really easy once you have the parts, and you will save a couple hundred dollars. After having one of the touch sensor machines, I now get the simple ones that I can fix myself, good luck, Gym
Posted on Dec 18, 2008
  • Asko Master
  • 19,396 Answers
You need to give us the model number printed on the service plate.
  • Ginko
    Ginko Dec 18, 2008
    First of all tell me what you do intend for main switch, that main switch is usually all in one with the thermostat switch, and it is quite easy to remove.
    If this is the door latch, let me know the model number, so that I can give you schematics, see help finding the model number on your appliance
Asko washer door won't close. Worked it manually fine with screw driver flicking latch switch but door wont connect with latch. How do you get behind switch panel to replace switch or see whats going on??...
you would start at the top back by losening the screws that hold the upper cover on the machine and when you remove these screws you would then slide the panel to the rear of the machine. nest you will see the rubber gaskey along the door has a metal ring simply use a screw driver without ripping the rubber boot to remove the ring. After this then u can remove the screws which hold the front panel which also has the door on it the part you are describing sounds like the door hasp or the catch the holds the door closed. because it is an asko your probably better off going to manufacturer to order your parts because this is a foreign model. please remember to rank how this opinion has helped in your appliance situation and if i can answer anything further please message me back
Thanks again
Nov 28, 2010 | Asko W6021 Front Load Washer
Dryer has power - we can hear the timer ticking and the light comes on when the door is opened, but when we push the start button nothing happens model # leq9558ko 8 yrs old electric
does the light close when the door is closed??? poosible that the door switch has gone bad. or a bad thermal fuse behind the unit is also a common culprit of this.. its a white thermostat on back of unit behind the panel (-----------------------) approx this long ad white,,
Oct 13, 2010 | Whirlpool LEQ9858P Electric Dryer
Start switch is gone and strip across top of door needs replaced
Hello, Welcome to FixYa.
The part`s you`re looking for, the power switch/on-off switch is Asko original part number 80-575-47. Check "" part number 763255, retails for approx. $20.
The overlay/decor insert across the top of the control panel is Asko part # 80-708-88 (- 0 for white or -33 depending on the color ). Check "" part number 764259, retail for approx. $80.
Hope that answer`s your question. Let me know if I can assist you further.
Thank you for choosing FixYa today. Please take a moment to rate the answer I provided for you and a testimony if you fell it`s warranted.
Good luck.
macmarkus :)
Jul 14, 2010 | Asko 24 in. 1805 Built-in Dishwasher
Dishwasher not completing full cycle
Hi i too have the same problem matrix mx194 approx 4 yrs old.On near completion of cycle the 3 center lights out of the 4 on the inside of door flash and a ringing tone indicating a fault. When the door is open there is approx 1'' of water in base of machine and the inside is extremely hot and full of steam.
Can anyone please help
Nov 21, 2009 | Dishwashers
DVD Player stopped working... will not LOAD/PLAY dvds
DVDs will not load / play... problem just started... TV approx 14 months old. Recently DVD was working and the TV just "SHUTOFF"?
Mar 03, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
How to remove main pushbutton switch from asko d1716 dishwasher
Hi I read your enquiry of how to remove the pushbutton swith.
You have to open the door, and remove the back panel of the door to release the front protecting cover panel. This is the only way to release the pushbutton. Do not forget to disconect the mains to avoid an electric shock.
Hope I have been of help
Nevd Fixya.
Feb 15, 2009 | Asko D1716 Built-in Dishwasher
Need manual for t14 gardena water timer 12 yrs old approx
Program Cycle Duration (minutes)
man On Once 30
1 4 times a day 3
2 Twice a day 3
3 15
4 Once a day 3
5 5
6 30
7 60
8 Every 2 days 5
9 30
10 60
11 Every 3 days 30
12 60
13 Every 7 days 60
14 120
Can't believe I saw this...don't usually go on the hunt on the net, but wanted to see if I could source some more of these. I, too, have had my timers for 12 years and swear by them...Excellent product...just happened to go out to the shed today and found the last surviving box, with instructions !!! Good luck, Fiona
Jan 16, 2009 | Hardware & Accessories
Asko W6761 Front Loader
check the fuse on the back panel if thats ok check to see where theres power it may be a display board fault.
Aug 27, 2008 | Asko W6761 Front Load Washer
Open Questions:
Dishwashers Logo
64 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
