Question about Dell W3706MC 37 in. LCD HDTV
DELL LCD TV WITH A ROLLING LINE IS IT A DUFFER?
Hi I have a 37" lcd tv with a problem. It has a line from left to right...a bit of a hazy line. It works its way from the bottom to the top...then starts again. Tried another tv on the arial to see if it was that and the other tv is fine. Its not TOO bad on a brightly coloured pic (but still visible) but worse on a dark background. Can you HELP !!!
  • AMBER VARNHAM Mar 29, 2007
    UPDATE !
    The line sometimes goes top to bottom now too !
    and there appears to be 2 lines, plugged playstation into it (tv runs of arial playstation off scart) and no pobs with playstation.
    factory reset the whole tv last night and re tuned it....still doing it.
    THANKS WILL DEFINATELY TRY THIS,
  • 97 Answers
I agree with tvtek, problem is cable lead to set. If you use a line amplifier and it is going bad over over gaining signal, this could be the problem. Replace your cable. Multiple pieces of equipment attached to line inputs can cause a ground loop and produce same problem. Use a true line conditioner, such as a UPS for a computer to filter the AC and hook all the equipment going to set to it.
Posted on Mar 31, 2007
    President:
  • 1,284 Answers
It sound as if you have a grounding problem with your antenna system. The lines sound like A.C. leakage getting through to the TV. If there is a way to connect another antenna to the TV try that and see if the lines dissapear. If they do then there is your problem, that antenna lead.
Posted on Mar 29, 2007
We have a 3 year old olevia television. the other day, a horizontal line appeared on the screen. it is in the middle and goes from the left side to the right side about three quarters of the way. what can...
I'm sorry but nothing can be done to fix the problem because it is defect of lcd panel (screen) that will be replaced but it would cost you approx new tv price so new tv is better choice instead of lcd panel replacement in this tv.
Again, I feel sorry for the bad news.
Jul 09, 2011 | Olevia LT37HVS 37 in. LCD HDTV
Hi i have 37 inch silver lcd tv when iput it on a green and yellow line appears but after 10 minutes it goes away
try unplugging it for about 30 minutes to reset the settings let me know if that helps. i have to do that with my isignia
Mar 16, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
Small green line on right side of screen
This is an easy fix using the Philips remote control that came with your tv. On the center of the remote is a dial that has left right up down controls. Stand in front of the tv and using those controls you can recenter the screen and get rid fo the green line. I had same problem when we hooked up hd satellite reciver to philips 37 plasma
Feb 18, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Black line on screen
your lcd panel is failing and will need to be replaced
Dec 04, 2009 | Sylvania LD370SS8 37 in. LCD Television
My Samsung LE32R738D LCD has a green line down left side and dark coluors esp.black go hazy can you help
Hi my name is Roety,
I can help you with your issue ,
 If the line is present on all inputs, and shows in the menu then that means the panel is bad, The panel is the front screen section. A new panel would cost more than a new TV
If I have helped you with your issue please click accept.
If you have more questions you can still respond,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Oct 11, 2009 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
Aug 21, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Lg 37lp1d tv
Press the menu button on the LG remote. If you see the line affecting the menu, then the LCD panel needs to be replaced. If not then you have a signal issue.
Dec 03, 2008 | LG 37LP1D 37 in. LCD Television
Toshiba LCD 37" with gray band and blue line
Unfortunately you are right it is the display panel going bad. You can either live with it or buy you a new tv as the panels usually cost as much or more than the tv. Sorry.
ladytech
Nov 01, 2008 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Faint Black Line down the middle of TV
Sounds like it could be pixel problems or board problems, this depend on the location. Most are mostly to the left or right, or going across the set to the upper or more to the lower side. For more info visit ctechnicians.com
Jan 06, 2008 | Sharp LC-37D7U 37 in. HDTV LCD Television
Dell W3706MC 37 in. LCD HDTV Logo
161 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
