Software raid/ide i have a Asus p5k64 ws motherboard that has six sata ports on it, i have four hard drives and one cd/dvd burner pluged in and the hard drives are on software raid 5 that was already on the motherboard, i reasently stuck another hard drive on the last sata port to use seppartly from the raided drives. now i have two OS, xp 64bit on the raided drives, and xp 32bit on the single hard drive, right now i unplugged the raided hard drives and have the sata configuration set to IDE enhanced in the bios, the problem is the single drive wont boot up if i have the sata set to raid, i want to know if i plug the raided drives back in and leave the sata config on ide enhanced if it will destroy the OS on the raided drives. (booting up on the single drive not the raided ones) i cant risk loosing the OS on the raided drives
  • Eric Jones Dec 19, 2008
    i have five hard drives 4 are on raid 5, and the 5th one is by itself, i installed xp 32bit on the 5th one by unpluging the other four drives and setting the sata config in the bios to ide enhanced, if i plug the other four hard drives back in and leave the bios setting on ide, and boot up from the 5th hard drive will it mess up the raid hard drives, or will it just have to rebuild will i change the setting back to raid?
  • Eric Jones Dec 20, 2008
    thanks, that helps, ill back up everything just to be safe (i was going to at some point anyways) and then ill try it.
    Problem Solver:
  • 17 Answers
It won't touch them, it should ask you which partition you want to boot from, or which version of windows if your boot.ini files are on the same drive.
Posted on Dec 19, 2008
  • Tyrone Martinez Dec 19, 2008
    im sorry, to clarify if your boot.ini files are on the same drive then it won't let you boot from them. boot.ini files are made when formatting so you need to think back to which harddrives you formatted together.
    It won't affect the raid like i said, just make sure that the RAID is not set higher than the EIDE in your boot priorities, if your raid even shows up in IDE mode. you will be able to copy files or whatever you need to do without affecting anything on the raid.
Want to know whats the maximum hard drive i can put in my pc it as a bv cuba ms-7301
Generally, you can put 2 devices (hard drives or CD/DVD drives) per IDE chain and 1 device per SATA port. It appears there are 2 IDE chains and 2 SATA ports, so theoretically you could have 6 hard drives hooked up (assuming you don't use an optical drive). Four would need to be IDE, two SATA.
Mar 27, 2011 | Packard Bell (181368) Motherboard
Suggest Hard drive for ASUS K8N Motherboard
ASUS K8N Motherboard support: -
2 x Serial ATA cables - 2 x UltraDMA 133/100/66/33
1 x 2-port SATA power cables - 2 x Serial ATA, support RAID 0, RAID 1, RAID 0+1, JBOD
Your mainboard support both "IDE & SATA" interface, so you can use IDE or SATA Hard Drives.
Hope it helps.
Nov 14, 2010 | ASUS Computers & Internet
ASUS K8S-MX Motherboard, but when I connect IDE
How were the partitions created on the SATA? Are they RAID configured from the other system? Does the new motherboard have the same support for your HD as the other system? Check the setup in the BIOS screen on both systems to make them identical as much as you can. According to Tom's Hardware: "In the SATA port configuration place you have up to four "mode" choices: IDE (or PATA) Emulation, native SATA, AHCI, or RAID." Check this section. Circe@pctechsonline.com
Dec 13, 2009 | ASUS K8S-MX Motherboard
IDE Ports not working on ASUS P5LD2-VM Mobo
Good Day sir, hi, Have you tried to enable the IDE on BIOS setup. If the Bios setup did not solve the IDE problem, check the IDE port of the HARD drive, check if there are bent pins.
If still wont work, you can buy a PCI to IDE/SATA card, this is an expansion card in PCI format with IDE and SATA port.We use this card incase the IDE or SATA on the motherboard gets bad. Connect it on the available PCI slot. Then connect the IDE cable of the Hard disk to this card. Thats it.
Nov 10, 2009 | ASUS P5LD2-VM Motherboard
ASUS P5S800-VM Motherboard set up
Hi m_k_bishop,
You must connect the CD-RW drive to the Secondary IDE connector on your board.
It can not be connected to the Primary IDE port.
(All SATA drives are seen as master drives in the bios).
With that in mind there shouldn't be any data cable connected to the Primary IDE slot.
When you first load the Bios menu screen you should see your CD-RW listed & you should see your SATA drive listed. Go to the title, " BOOT " in your bios.
(If your system has a floppy disk drive connected your Boot menu should read as follows);
First boot device [Floppy Disk]
Second boot device [Your CD-RW drive]
Third boot device [Your SATA drive as shown from the main menu]
No need for a fourth device.
Save the bios & exit. The system will auto restart.
(At boot up re-enter your bios).
Next change the [RAID Mode] to SATA or Enabled anything but RAID.
Once completed save & exit the bios. If everything is connected correctly & you made the changes above your system should see your SATA drive & windows should install.
(Load the windows CD into your CD-RW drive).
The Asus manual lacks the proper information needed for you to make the correct setting changes in the bios.
Good luck m_k_bishop!
Post back if still have trouble... You shouldn't!
Mike
Mar 21, 2009 | ASUS P5S800-VM Motherboard
Dvd drive replacement
Get a PATA also called IDE drive.They are cheap and will work great in your box.You don't need the speed of SATA for a DVD drive.Even though they make SATA drives. Pata's data tramsission rareis much faster than even the fastest DVD. You have a four device potential for you IDE on your motherboard and only a two device potential for your SATA. Save the second SATA port in case you want to add a second hard drive some day
Nov 28, 2008 | Abit NF8-V Pro Motherboard
Sata DVD burner
This is happening because the DVD SATA is booting like a first drive instead of the IDE Drive.
Be sure that your SATA drive is connected to a right port on your motherboard.
Go to your bios and into the boot options be sure that the IDE drive boot first than the SATA DVD.
Another way is connecting an adaptor SATA to IDE and connect your SATA DVD Drive as second IDE on your motherboard.
This will be fixing your problem.
Have a great day
Pablo :-)
Oct 22, 2008 | Computers & Internet
Cables
i had to buy the asus cables yes it worked
Sep 27, 2008 | ASUS P4S533-MX Motherboard
HOW TO CONFIGURE RAID
I needed to see your board & can at this site. http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=493&DetailName=Manual&MenuID=1&LanID=0
This is good for you as well. It shows me & you that your board can handel 4 each DMA/ATA-133 (Ultra) IDE Hard drives/ CD/DVD drives IDE-1Primary & IDE-2 Primary Slave. Each can run 2 IDE drives. Also 4 each Serial ATA SATA's. Two separate SATA controllers with integrated PHYs, each supporting two
drives in master mode. In your manual on pg.32 & 33 will help you to setup a RAID if you wish. Or you can also set the RAID to IDE which will allow you to use all your SATA hard disks as a single drive without setting up a RAID system. The site above supplies all your drivers needed & manual. If you need more help please let me know here.
Luck!
Please vote......
Jan 13, 2008 | EliteGroup NFORCE4-A939 (NFORCE4A93910)...
Computers & Internet Logo
637 people viewed this question
David Payne
David Payne
