Question about Dell PowerVault 110T LTO-2 Ultrium Tape Drive
Flashing lights I am having a status light flashing and then it changes to the error light flashing, I am unable to do anything, what can I do.
  • Yuriy Beznos
    Yuriy Beznos Mar 18, 2008
    I have the same problem where LED is flashing and error code is 2. I tried to power off and on with no luck. This unit is out of warranty. I'll appreciate any suggestions.
I had this issue and fortunately my tape drive was under warranty.
First off rang Dell and the technician tried fixing over the phone.
There are two types of flashing light (apparently) if the light is flashing slowly then the tape drive is telling you it needs cleaning, if the light is flashing fast then it is telling you that the tape (not drive) needs replacing.
The technician then said that if the tape drive was relatively new under 12 months then is was likely a software issue/conflict. My drive was nearly 3 years old, but he tried the software updates and restored the original defaults anyway and had no success, so they sent an engineer out.
When the engineer came out he replaced the drive immediately, i asked him what it was and he said when the drives get older or are used a lot they get clogged up with the metallic oxide ("DUST") from the tapes over time and they get to a point where they are so clogged they think they need cleaning all the time.
I asked if you could clean the tape heads yourself, he said you can but it is a real pain in the ***, so they don't, they just throw them away.
not much of a solution i know but this is whats happening, if your drive has done a fair bit of work then its a fair bet its knackered.
BTW: engineer did say you should only use good quality tapes as the cheaper ones give off more metallic oxide ("DUST") than the good ones.
Posted on Apr 06, 2009
  • 624 Answers
I have several of these, what you do depends on if it?s an external or internal drive. External drives you can simply power down and restart using the power switch on the back of the drive enclosure. Internal drives you need to shutdown, physically turn off (I prefer to unplug as well) and restart. If this is an ongoing problem then you should call Dell for a warranty exchange, I?ve had two of these drives do the same thing, n exchange did the trick.
Posted on Jul 28, 2007
Blue status light flashing rapidly
this mean that your printer waste pads are full and you need ro reset the printer for it to work again send me the model of your printer and i will see if i have the software for it
Feb 25, 2013 | Epson Stylus Multifunction Inkjet Printer/...
My NEC vt 595 was working fine last night and today i went to turn it on the status and power light started flashing red and orange and there is no picture
if Power is flashing orange - then it's cooling down
if Status is flashing red - then there are 4 flash combinations.
1 cycle (0.5sec On, 2.5sec Off) lamp cover or housing error
2 cycle (0.5sec On, 0.5sec Off) temperature error
4 cycle (0.5sec On, 0.5sec Off) fan(s) error
6 cycle (0.5sec On, 0.5sec Off) lamp error
Which is your condition?
Mar 18, 2011 | NEC VT595 LCD Projector
There is a yellow light flashing which i think is stopping my printer from working.it is the symbol furtherst to the right out of the 4 symbols any ideas
The rightmost LED is the Error light. How fast is it flashing?
If the light is flashing 1 long flash every 4 seconds (no other lights flashing), then either the image drum needs to be changed or the toner is low.
If the flash is one blink a second, then you have a paper problem or a cover open.
If you installed the OKI software with the driver, you can use the Printer Status monitor to identify the problem and order the consumables if you have a slow blink error. (Open the printer control panel (Start >Programs > Status monitor) and Maximize the window to see the Printer status.
You can find the manual for the OKI B4100 here: http://my.okidata.com/PP-B4100.nsf?opendatabase . View all manuals on the right. If that link doesn't work, see the support site: http://my.okidata.com/Home.nsf/Welcome?OpenFrameSet and select the B4100 in the Color/Mono Page Printer drop down menu.
I hope this helps.
Feb 14, 2011 | OKI B4100 Laser Printer
Have changed inks which were low and now have left and centre red lights flashing and printer will not operate.
Check for epson status monitor : General error or reach end life service ? Flashing alternately mean printer need to reset waste ink counter.
Mar 15, 2010 | Epson Stylus photo C87 InkJet Printer
Brother 5250dn and all light are blinking
That series of lights indicates a main circuit board failure. You will need a shop to replace the main logic PCB. Could be caused by anything, static shock, bad input power from power strip or power failure, just plain CPU failure. If it's under warranty, 1 year since purchase, you need a Brother service center, out of warranty a new printer would cost less than repair.
Feb 02, 2010 | Brother HL 5250DN Laser Printer
Power light flashin orange, status light flashing red on WT610 NEC
if the status light is flashing .5 seconds on and 2.5 seconds off - you need to replace the lamp cover correctly.
if the status light is flashing .5 seconds on and .5 seconds off in 2 - 6 cycles the error is: 2 cycles - the projector is overheated. Move the projector to a cooler location, or/and remove dust in the light path. 3 cycles - the power unit is not working correctly. 4 cycles - the fans are not working correctly 5 cycles - lamp fails to light. Wait a full minute and then turn on again.
Jan 25, 2009 | NEC WT610 DLP Projector
Unable to print
plz check the ink status and any paper jam
Jul 08, 2008 | Epson LQ-2180 Matrix Printer
Error light and no printing
What does the status monitor message say? The red light is the most general error. It's bit like taking a 747 back to Boeing and saying there is something wrong with it.
If you do not have the status monitor installed, download it from Konica Minolta and run it. Once the status monitor is running it will read the error from the printer.
Sep 05, 2007 | Konica Minolta magicolor 2300DL Laser...
Dell PowerVault 110T LTO-2 Ultrium Tape Drive Logo
3,671 people viewed this question
Clive
Clive
Alun Cox
