Question about SanDisk Sansa View 8GB MP3 Player - Black
How do you place a podcast (MP3) into the podcast folder on the Sansa View?
Make sure you're Sansa is in MSC mode (go to settings/options, then "system settings", then "USB Mode", then MSC -- this option is available if you've updated your firmware to v01.03.02a). Connect your Sansa via USB cable and then open "My Computer", double-click on the Sansa View icon and create a new folder called "PODCAST". Place Podcasts in this folder, then close the window and "safely" remove your Sansa from the USB port. After the Sansa refreshes itself, go to "MUSIC" then "PODCASTS" and you should see your file(s)!
Posted on Jan 15, 2009
Am getting very frustrated with my Sansa Clip. I download a podcast or music onto my Clip, yet the Clip tells me that the folder is empty, but when i plug it into my computer again, all the downloads are...
what is the size of the podcast mp3? Many podcasts don't actually send you an mp3 of the podcast, but a link embedded in the mp3 that streams the podcast to your player of choice. (twit does this, fairly frustrating) if the mp3 is not very large, that is probably why.
Mar 06, 2011 | SanDisk Sansa Clip MP3 Player
I am running Windows XP. I have 2 problems. (1)I rip CDs using itunes having set the default format to MP3. Then I use windows explorer to move the albums to the music file of the sansa clip. However, some...
1) You need to set the "tags" in the music files ... artist, album and song name. I would suggest opening up the files in MediaMonkey, which will let you edit the tags.
2) After you download the podcasts with MediaMonkey, you need to find out where they exist on your disk. Then, copy them to your Clip using Windows Explorer.
Jan 27, 2010 | SanDisk Sansa Clip MP3 Player
I have a Sansa View i beleive and..............
Plug the view into the computer via usb and find where your music files from frostwire are downloaded to (most likely your Shared folder) and copy or drag the destined files to your Views Music folder and then unplug when your view is done transferring and all the songs you placed in the folder should show up.
Jul 14, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
How do you download a podcast on the sansa mp3 clip?
Hi wyostardust,
There is a workaround to not use iTunes to subscribe to and download your favorite podcasts. This workaround is called Juiced : http://juicereceiver.sourceforge.net/ and it is free. Once you have used Juice to download all your podcasts you can then transfer them (the mp3s) to your Sansa Clip the same way you do with your music.
Regards,
-SHG
Jan 14, 2009 | SanDisk Sansa Clip MP3 Player
Placing mp3 podcasts in the podcast folder
Create a folder on your View (in MSC mode) named "PODCAST". DO NOT put it in your MUSIC folder, but in the root directory. Place your Podcasts in there and disconnect your Sansa. After it refreshes you'll find your Podcasts under "Music\Podcasts" on your View :)
Dec 18, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Podcast folder does not appear in menu
I didn't realize this Sansa player had a podcast folder - strange. At any rate, switch the USB mode on the player to MSC and see if they show up:Turn on then press and hold the rewind button while plugging to the PC
-Tha Mp3 Doctor
Dec 05, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Podcast
JOHN, IS THE IPOD FULL?ALL OF YOUR POD CASTS MAY NOT FIT.BUT YOU CAN PLACE THEM IN A PLAYLIST FOLDER AND RANDOM PLAY THAT WILL CAUSE IPOD TO SYNCH.DIFFERANT ONES EACH TIME.ALSO CHECK YOUR SYNC SETTINGS.RICHARDM69
Oct 28, 2008 | Apple iPod classic MP3 Player
Sansa dioesn't recognize audiobooks
Maybe the new firmware will fix this.
"OGG placed in Audiobook or podcast folder shows up in Music directory." (see below)
(http://www.anythingbutipod.com/forum/showthread.php?t=30954)
01.01.30
Enhancements:
  • FLAC decoder support
  • Allow Podcasts to skip episodes using FF / REW
  • New startup and shutoff images
  • Improved the time to rebuild the metadata
  • Improved M3U playlist support
  • Enhancements for sorting Podcast contents which do not have their track number ID3 tag information
  • Separate missing license error message for Audible and generic Audiobooks. Message changed to instruct the customer in how to resolve the problem
Bugs Fixed:
  • OGG placed in Audiobook or podcast folder shows up in Music directory
  • Delete song from a long playlist causes the device to hang
  • Selecting “Back to Music List” while playing FM/Voice recordings will display double “Play All” on screen & will cause device to hang upon selecting “Play All”
  • Certain tag information for mp3 files will cause the device to hang or freeze
  • Made OGG file Tags not case sensitive
  • Noise problem on voice recording
  • Device in MTP mode will jump back to AutoSelect mode after UI format
  • Device behaves erratically when file extension got changed (i.e. .txt to .mp3, .jpg to .wma)
  • All Audiobooks should show 1/1 if Chapter Mode is OFF
  • Certain Rhapsody tracks show clicking noises
  • Deactivation message “Synchronize to listen to your Audiobooks” for Audible is uninformative and irrelevant
Oct 07, 2008 | SanDisk Sansa Clip MP3 Player
Synchronizing mediafly with sansa e200 series
U can either use wmp or yahoo music player works or u have to change the files to mp3 or wma files
Apr 01, 2008 | SanDisk Sansa e260 MP3 Player
Can't find downloads on Sansa player
get rid of podcast you want wondows media player or a shared folder
Apr 03, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa View 8GB MP3 Player - Black Logo
234 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
