Question about Fuji FinePix A203 Digital Camera
Not snapping pictures
Camera is not taking pictures, I can view old pictures on the screen I have a red box in the left hand corner with a little white box and a large A other items on the screen when I wnat to take a picture on the right it show 617 2M-N. I no longer have the manual
philipp
  • 217 Answers
SOURCE: Fuji S5000 will not diplay object on LCD Screen or Eye View
Defective ccd imager!! company will replace this ccd imager free of charge. Year 2002 up to 2005 released unit has a factry defect ccd imager. the company recalled these unit and replaced with a stronger version of ccd imager. check it out.
Posted on Sep 08, 2007
cammedic
  • 667 Answers
SOURCE: PURPLE LINES SHOWING ON SCREEN WHEN ATTEMPTING TO TAKE PHOTOS
Your camera likely needs a new CCD imaging sensor. It is a cute little thing and is very expensive to replace. I've seen deals to repair any digital camera on eBay and I would check for a local repair person in your area. You can use the search on this site to see who might be close by. I have an A310 doing the same thing.
Posted on Jan 05, 2008
Steve5
  • 423 Answers
SOURCE: fuji Finex 800 camera
If it's pink/purple and "streaky", you have a bad CCD sensor. The only fix is replacement of the sensor. This is the main image capturing sensor in the camera. The situation is well documented on the web. It's usually the end of the camera, unless it's under warranty (or just a little past). Approaching Fuji's repair department can sometimes yield a sympathetic rep who'll have it fixed at no charge to you. If you are on the hook for the repair, expect to drop about $100 US.
Posted on Mar 28, 2008
  • 13433 Answers
SOURCE: Fuji E510 Screen
These are a real pain to fix by yourself.
you can get a free repair estimate from
http://www.advancecamera.com/repair/
Posted on Apr 25, 2008
zohail
  • 1223 Answers
SOURCE: Blank Screen
dear sorry to tell u but ur FUJI S5000 have a CCD HR failure which is due to the manufacturing fault in these CCD'd thats y fuji now adays stopped working on these CCD's and got tons of recalls for that it occurs after 4 to 5 years of use and this fault was present in all cameras manufactured between 2002-2005 , the ccd offcourse u can check with fuji try hard to get it replaced free of charge other wise consider buying a new one it is not that much expensive there new model as compared in those days it is around 250-300 $ a better version of this , pls vote me generously if u think i helped u
Posted on Feb 23, 2009
When taking a picture a message pops up that says "cannot be written to SD card"
Checks to make:-
1) Is there an SD card in your camera?
2) Is the SD card compatible with your camera?
3) Is the SD card write protected (Check notch top left hand corner of card)
4) Is the SD card full or nearly full?
5) Are you trying to write a file type (.raw) which is bigger than the capacity of the card or the remaining capacity on the card.
Nov 01, 2011 | GE X500 Digital Camera
Google maps: street views keep going to a split screen with street on top and satellite on bottom. Also street views in full screen mode disappear after a second and the split screen mode reappears.Very...
When you go into the split screen, and you don't want to be there, just click the little arrow in the lower right hand corner (the arrow pointing down and to the right). This will reduce the bottom map portion into a small overview box in the lower right portion of the screen. It only takes a second to get out of the split screen that way. To get back into split screen, click the arrow in the upper left corner of the overview box (the arrow pointing up and to the right).
Aug 15, 2011 | Computers & Internet
How do i get my phone camera to switch to the front camera rather than the back. i have tried messing about with the camera settings but cant get anything to work??
Switch to camera mode, as if to take a picture. Then in bottom left hand corner, press little cog/wheel. 12 boxes will appear, press 11th box!
Aug 31, 2009 | LG KU990 Viewty
Cant view photos on the big screen of my camera
I think you must have pressed the EVF/LCD button which changes the review area to inside the tiny view finder.. the EVF/LCD button is found on the back of the camera at the top left hand corner.. it is a little silver button. Hope that helps.. :)
Jun 01, 2009 | Kodak EasyShare DX6490 Digital Camera
Hello i have canon ixus 960 is camera. it is one month old.
I think you are in manual mode or one of the special scene modes, and the camera sounds like its set for low light conditions. Look at your mode dial on the back of your camera in the upper right corner. Rotate this dial to the first little red camera selection "Automatic" position (the one with no letters beside it). Now try taking a picture.
Feb 01, 2009 | Canon IXUS 960 IS Digital Camera
A red image pops up when I take a pic
I chose the DMC-TZ3A since I didn't know what the letter was at the end of the model number for your particular camera. If this is the camera
Here is a link to the manual
If not
Here is link to the Lumix series cameras
Pg 25 indicates that flashing red in the upper right corner is the battery needing to be recharged. If the battery was recently recharge and its turning red on the screen, it could be that the battery isn't holding a charge and may need to be replaced.
I didn't see any other error messages on the screen indicating that icon unless b,c, or d models have a different error message in that area of the screen.
Jul 11, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Red eye button when I try to snap a picture
I believe that's your flash setting. Just press to the left of the Menu/OK button to change the flash setting.
Apr 03, 2008 | Samsung Digimax S630 Digital Camera
Wont take photos outside
The symptoms you're describing could be caused by either the "Fireworks" special scene selection mode, or manual mode with too much exposure compensation. Look at your mode selector (back of the camera, upper left hand corner). Is the mode set to the still image setting (pointing at the liittle red camera)? Or is it set to special scene selection (SCN)?
If you are unintentionally in SCN mode, to get it out of "Fireworks", just turn the mode selector dial to select "still image" (pointing at the little red camera). Or you can also select an SCN mode more appropriate for outdoors. Just turn the dial to SCN, press the FUNC button, then press the left/right arrow buttons to select Portrait, Beach, Snow etc...
But if your mode selector is already in still image selection, then check to make sure that you're not in "Manual" picture mode. Turn the mode selector dial to "still picture mode" (pointing at the little red camera), then press the "FUNC" button. Now look at the bottom of the screen. If it says "Manual", press the "left" button controller once to select and put the camera in "Auto" still picture mode.
Feb 29, 2008 | Canon PowerShot A400 Digital Camera
Fuji FinePix A203 Digital Camera Logo
15 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
