Pilot light will not light
My Comfort Glow gas heater has a manual striker that I have to keep pushing while the dial is set to "pilot". I see a spark but it doesn't ignite right way. I have to keep pushing the button about 20-30 times before it takes (or not at all-today, not at all). Any suggestions?
  • pineyconstru Dec 18, 2008
    Yes, I do have to push the dial in at the same time pushing the striker button, but it still doesn't want to ignite the pilot light
  • 24 Answers
You should have to push the dial or a seperate button in to manually open the pilot gas valve. If you find this not to be true and you have a spark either the pilot burner assembly needs to be pulled and cleaned.
Posted on Dec 18, 2008
  • Brian Markstahler Dec 23, 2008
    if the piezo spark generator is providing a spark every time you push it then the only potential cause for the pilot not to lite would be a dirty piot assembly. It would need to be pulled, disassembled, cleaned, reassembled and reinstalled. If the generator does not provide a spark each time it is pushed then the spark generator would require replacement.
Pilot light doesn't light on room size ComfortGlow propane heater. We have no heat and it is 20 degrees. mariettahallam@aol.com
Posted on Jan 21, 2011
We have a gas wall heater product number 4690011 and we do not know how to start it;
Remember if you smell gas, turn unit manual gas valve off and open a near by window, wait until smell is gone then proceed with these directions,turn manual gas valve back on, turn thermostat down.1.) turn combination gas valve knob to the pilot position and press down knob, if unit has a striker button, push striker while holding down knob until pilot lights, keep knob held down in the pilot position for 20 seconds then let up on knob and turn to the on position, turn thermostat up, main burners should light.
Mar 04, 2010 | Heating & Cooling
I bought a comfort glow vent-less space heater model # CJ18NL. It had a natural gas valve on it and the guy said I could put on a propane valve, which I did. It's not lighting. Is this model only good...
According to the Comfort Glow Website, this is a Natural Gas unit. If you use propane you will need
a minumum 100# LP Cylinder and a pressure regulator. I have a Comfort Glow unit and went through the same process.
If you have it hooked up to a 30lb cylinder without a regulator I would think that if you purged the gas line
of air you should be able to light the pilot.
On a new unit you can expect to push the spark ignitor button at least a dozen times while holding
down the gas valve button.
Good Luck
Feb 19, 2010 | Desa International GWP20T GLOWARM Wall...
Pilot won't light
You may have to bleed some more air out of the system.
Your ODS pilot may be clogged with dust or lint and needs to be blown out with air(less than 30 psi).
Your regulator or gas valve may be faulty.
Dec 09, 2009 | Desa International Comfort Glow Infrared...
The pilot on my Comfort Glow Gas Logs CLD3924PTA won't stay lit. Can anyone help me with this problem??? Thanks
You must have some kind of flame sensor and it sounds as though it is not working correctly. If the pilot lights and then goes off, I would look there first. Good luck...Lee
Nov 04, 2009 | Desa International Comfort Glow Infrared...
My pilot light keeps going out on my comfort glow infrared propane heater what could be making it go out?
The thermocoupler is faulty. It is that bulb that sits i the pilot flame. It controls the gas valve so you won't get any gas if the pilot goes out.. So, the thermocoupler needs to be replaced. Inexpensive and easy fix. Good Luck _Ned_
Oct 19, 2009 | Heating & Cooling
I have a Comfort Glow propane heater connected a 20lb tank. The pilot has a hard time staying lite but when I do get it lite ang turn the hearter on low it will shut off in a minute or in some cases 20...
If you have a pilot, you have a thermocouple. I would start with the thermocouple. The thermocouple is supposed to be heated by the piolet and to keep the pilot gas on. If it is faulty, the pilot will quit and the heater will not reignite until you light it again. Good luck...Lee
Sep 21, 2009 | Desa International Comfort Glow Infrared...
Have Model CGP30TB Copmfort Glow propane heater. Pilot light won't stay lit. Flames also coming from what seem to be air vents just below flame on pilot light.
sounds like an obstruction in pilot assembly.try using canned compressed air to blow directly into pilot. this technique is successful about 70%. if not,pilot assembly must be removed and cleaned thorougly
Sep 10, 2009 | Desa International Comfort Glow Infrared...
Comfort glo propane ventless heater won't light
I have several of these heaters in my rent houses and love them. The most problem I have is not being able to ignite the pilot with the user control igniter. Remove the screws that hold the front cover in place along with the front cover. Hold the pilot control down and ignite with a lighter. Keep the pilot engaged until thermocouple is warm enough to keep pilot gas flowing. If it will light this way then you need to blow out the pilot orifice. It seems that every year I have to go in after the summer season when the heater is off and clean the pilot/orifice lines with high pressure air. I believe spiders/bugs/dust block pilot orifice when it is not in use. You can also tell that orifice is blocked when you don't get a good blue pilot flame with pressure behind it allowing the flame to submerse the thermocouple. If the the thermocouple is not getting enought heat it will turn pilot gas off for safety reasons.
Nov 16, 2008 | Desa International GWP20T GLOWARM Wall...
Comfort Glow Vent-free Gas Heater CGN18B
the pilot light is operated off a millivolt generator. that is the small tube directly in the pilot flame. its purpose is to generate a small dc current which is connected to the pilot valve inside the main valve. setting the control to pilot opens just the pilot gas supply. when operating normally the millivolt generator keeps a small electromagnet pulled in that keeps the pilot gas supply open. if it don't work the pilot gas supply valve closes. replace the thermocouple.
Dec 04, 2007 | Heating & Cooling
Heating & Cooling Logo
294 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
